Question about Zenith A27B43W TV
Screen blacked out, no sound or pix
TV was on and screen became very thin and shut off. Smoke appeared from the back and a smell of burnt rubber emersed. A buzzing noise remained if the TV is plugged in, but nothing else.
    President:
  • 3,130 Answers
The set had a bad vertical output IC and when the IC heated up it took out something in the power supply. Most likly in the sweep supply, that supplys the voltage to the vertical IC. If your not a tech, Please call one, as A TV set is not a place to experiment with. A good tech may even be able to repair the module as Zenths are made to replace the entire board when theres a service problem.. Go to http://ptscorp.com, click on technical assitance then finding the board you need by putting in the model # and this will come up with the board price to give you an idea on the replacement cost for parts and see if you want to invest that as well as the labor cost. Good Luck
Posted on Jul 31, 2006
Washer squealed, gave off black smoke in spin cycle
For sure change the belt. Clean the pulleys with a solvent to remove anything oily or like melted belt. The machine probably was overloaded. If it's a front loader, check the bearings.
Nov 24, 2013 | Washing Machines
Screen is black
sounds like it was enough to pop something in the tv, smell the back of the tv smell if anything smells burnt or hot. unplug the tv and let stand for about a hour unplugged then trying it again but if it does smell chances are you will have to see if your still under warrenty and have the unit replaced.
Aug 09, 2008 | Mitsubishi VS-50605 50" Rear Projection...
My LG LCD flat screen tv shut off one night and smelt like burnt rubber. It turned back on fine but I'm worried it will catch fire
You are safe. :) It may have shut off from a voltage spike or brown-out on the line. There are several fuses inside of the TV that are supposed to blow before anything catches fire. If it starts smelling again, then unplug it and take it to a service center.
Mar 06, 2013 | LG 47LE5400 47 in. TV
Screen is black and it smells like something is burning, but we cannot see any visable burnt wires or anything...we have removed the back of the tv, and looked at the circuit board...where exactly sho
Unless you know what you are doing you are playing with fire, Unplug the set and have someone qualified take a look at it. Smoke and a burning smell and you still have it powered up?
Apr 11, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Green screen, no picture. tv shuts off by it self after 30 sec
This is a simple fix and not hard to do, first you must get the speaker grill off, usaly two screws on the bottom and they might be hidden under to caps, then remove the acsess cover from the front. From there you should see a control box with six controls, three on top of three,,,,One part label "screen" the other "focus" now turn the set on and tune to a input that HAS NO SIGNAL this should give you a black pix, probley not now but it's supose to be black. Now turn the ones marked screen , one at a time counter clockwise just a little to get the pix compleatly black, now starting with one color turn the control slowly clockwise till the color just appears then turn it back down till it just disapears (Black) do this for all three colors Now the set should runn
Dec 26, 2009 | Sony KP-51HW40 51" Rear Projection...
Rubber smell and slight smoke
a rubber smell?? the best thing you can do is diagnose it properly by blocking it up high enough of the ground and let it smoke then slide yourself under there and see where it originates ... check for witness drip marks on the exhaust first??
Dec 04, 2009 | 2004 Honda Accord
A thin line appears on the screen,when turned on
we bought a new set, the tube on the old one was burnt out
May 14, 2009 | Philips Magnavox 24MC4306 24" TV/VCR/DVD
Picture is dark
sitnlisten - yes it does appear your pix tube is getting weak,but we may be able to turn up the flyback alittle to brighten up the picture.If you take the back off you will see the flyback-large black unit with a wire going to the round rubber cap on the back of the pix tube.Look at the flyback there are usually 2 adjusters one marked focus the other screen,just turn up the screen a little bit at a time.If you turn this up too much you will wind up with retrace lines on the screen.You may also want to check the pcboard ass'y for a sub bright adjust,and same thing small adjustments.If this don't help your pix tube may be too far gone.I hope this helps. cooltek Feb.1/08
Feb 14, 2008 | Zenith C27A24T 27" TV
Watching TV and then POP!
ok, your tv is still on repairable condition,smoke that came out from your unit due to an ic that burned,I'm sure it's the vertical ic replaced with a new one.same part number.
Oct 23, 2007 | Zenith A32B43W 32" TV
IMac Monitor
What type of monitor is this? If it is an LCD screen, you may have some dead pixels. Please reply with some more details about your specific monitor.
Sep 05, 2007 | Apple iMac G5 Desktop
Televison & Video Logo
44 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
