Question about HEALTHRIDER Exercise & Fitness
Healthrider S250i slows and stops when load on belt.
I have replaced motor control board, power board, motor, and double lubed the belt. The problem continues. The original motor would not caibrate to the required 10mph after replacing the motor control board (it only got to 1.7mph), but the new motor calibrated easily to the required 10mph, but will not hold up under a load. I do notice that if I have the treadmill inclined, it will accept weight, but not when it is flat. Time to scrap? I don't want to throw more money into parts. Any idea if I should do more to repair?
  • 43 Answers
SOURCE: healthrider s5001 treadmill stops during workout
check manual for maintance on walking belt lubercation- mtr shutting down to over heating-pulling too many amps to rotate rollers/belt and to move you. Friction problem
Posted on Jan 08, 2010
outfield502
  • 79 Answers
SOURCE: need help belt adjustment on healthrider 550i
in the back of the treadmill you will find two screws allen, if the belt is loose, you should rotate in the direction of clockwise until a point of tension,should not be too tight because it will do is it will break
Posted on Feb 05, 2010
  • 103 Answers
SOURCE: Just replaced the motor controller on my treadmill
You have one of three things wrong. Either a bad console, bad motor or a bad wiring harness.
If you have a flashing light on the controller when you attempt to start the machine then you more than likely have a bad motor. (this has a long warranty may be able to get one for free, check the back of your manual)
If there is no flashing light on the console then you will need to check the wire harness. This unit is known for pinching wires at the lower section where the upright connects to the lower frame. To check this you will need to remove the console. Three screws on each side and the wire harness on the right side will need to be unplugged. Then remove the right upright by removing the two bolt located on the bottom of the frame. Then do a visual inspection for pinched wires especially where the upright connects to the lower frame.
If the harness looks ok then you will more than likely have a bad console.
If you need parts you can go to http://www.iconservice.com/CustomerService/parts.do
Good Luck! Tim
Posted on Mar 28, 2010
  • 3 Answers
SOURCE: My Healthrider 400se Treadmill slows down after 10seconds
Use only a single-outlet surge suppressor that is
UL 1449 listed as a transient voltage surge suppressor
(TVSS). The surge suppressor must have a
UL suppressed voltage rating of 400 volts or less
and a minimum surge dissipation of 450 joules.
The surge suppressor must be electrically rated
for 120 volts AC and 15 amps. There must be a
monitoring light on the surge suppressor to indicate
whether it is functioning properly. Failure to
use a properly functioning surge suppressor could
result in damage to the control system of the
treadmill. If the control system is damaged, the
walking belt may change speed or stop unexpectedly,
which may result in a fall and serious injury.
Posted on Apr 15, 2010
bwinton
  • 83 Answers
SOURCE: Belt slipping on treadmill
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Posted on Apr 30, 2010
My Horizon CT 7.0 treadmill slows down when i step on it
LUBE THE deck belt and rollers bearing . This happen because you must lube about 150 miles aprox. See the video and fix it. However if the problem persist. Time to replace the old board deck.
God bless you
Jan 25, 2013 | Horizon CT7.0 Motor Control Board
Repair dc motor controls on Treadmill Lifestyler mod, 831,296462
No. this happen because had been lack of maintenance LUBE. Lube the deck belt, you must do it every week of use normally. Use 100% silicones or wax instr. manual.
2) LUBE the rollerer bearings too.
3) Test the input voltage motor, if there are Voltage the motor need repari.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Dec 03, 2012 | Exercise & Fitness
Start R-60
see the video and proceed according. God bless you
2) LUBE the deck belt
3) LUBE the rollers bearing too
4) Test the drive belt motor
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for troubleshooting HELP.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block diagram
God bless you
Nov 30, 2012 | HEALTHRIDER R60 SoftStrider Treadmill
I have a Healthrider R65, engine works wellbut when I step on it skips and stops for afew seconds my husband adjusted belt on each side but is till not going smoothly please adviceI bought from my fri
1) Lube the deck belt, this produce enough friction between deck vs deck belt, and shut down for to protect the electronic system
2) lube the rollers bearing very well.
3) Test the drive belt and replace
4) Test the motor input voltage, if there are the motor need repair.
5) test the output voltage board, for input voltage motor, if there are not the board is faulty.
God bless you
May 11, 2012 | HEALTHRIDER R65 Treadmill
Healthrider S500i HRTL12990 belt won't run
HI,
If you can then before replacing the Motor control board do one thing. Replace the IGBT on the control board. Igbt is the component which drive the motor. It will not cost a lot. The only thing is you should be very careful while working on the motor control board because there you can see two capacitors which is capable of store charge for a long period of time even the treadmill is unplugged. Before doing work on the control board you have to discharge the capacitor. If not it will lead to serious electric shock. You will get many pages on web to know how to discharge an electrolytic capacitor. I have add the picture of the motor control board with the igbt marked. You can find the part number written in its frond side. Replace the IGBT first.
Ajin
Jan 19, 2012 | HEALTHRIDER Exercise & Fitness
I have a Healthrider Softstrider s300i treadmill and it will shut off with no warning after 35 min or so. I take out the safety key, reinsert it after a few min and it will go again.
1) you have 3 problems: mechanical+ electrical + electronic.
2) adjust the tensions from deck bel + drive belt motor
3)test the main motor without load and see what happen.
4)test the main motor board and see what happen.
see block diagram
Jun 27, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
The treadmill runs fine until i step on it then it stalls and stops running
There is a motor which spins the treadmill belt.When you start the treadmill, the motor starts running and belt spins smoothly.But when you step on the treadmill, the motor cannot take the load and it stops working.In your case, the motor and motor control board is got weak and this is causing the problem. ---------- Or the other possibility is the treadmill belt, the belt on which you step.That belt should be smooth, there is grease in the inner side of belt to keep it lube and run fluently.If that oily grease gets dried up then belt gets bit stiff or jammed up, when a load is on belt.So get this both possibilities checked.First try lubing the belt internally and then try check the motor and motor control board.To locate motor control board its simple.On the side of motor you will see a electric plug in connector, the other end of that connector gets connected to motor control board.Remove that connector , clean it and reconnect after 5 minutes, then check.In some cases this resets the internal control system and everything, works normally.But its not always possible then removing and reconnecting connector helps.In other cases the motor or control board needs to be replaced.If the motor gets weak, then internal coils in motor gets burned up.----------- This will help.Thanks.Helpmech.
Mar 26, 2011 | Proform Exercise & Fitness
Belt is not the correct speed when you put ypur weight on it...slows down.have to put on 5 to get a 3 walk?
If the walking belt is overtightened, treadmill performance may decrease and the walking belt may become damaged. Remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts counterclockwise, 1/4 of a turn. When the walking belt is properly tightened, you should be able to lift each edge of the walking belt 3 to 4 in. (8 to 10 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened. . If the walking belt still slows then lubricate running deck the lube may be purchased from iconfitness.com
May 04, 2010 | HEALTHRIDER S600 Treadmill Motor Control...
Jan 23, 2010 | HEALTHRIDER Pro H500i Exercise Workout...
Exercise & Fitness Logo
85 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
