I need drivers for AOC L20W Monitor.
I have AOC N20W monitor, and when I connect it to my Samsung R530 laptop and change the settings to "Show monitor only" I get black screen on the monitor with a message saying "Input Not Supported". When I change setting to "Duplicate monitors" it shows the screen but only with my laptop monitor's resolution with "Input Not Supported" message. I have been looking for drivers on official AOC website but it didn't have the drivers for my monitor. If you know how to fix it please help.
SOURCE: Input not supported
1. Restart the computer.
2. When the computer begins to reboot, press the F8 key repeatedly in one second intervals until the "Windows Advanced Options" appears.
3. Select "Enable VGA Mode" and press ENTER.
4. Select your operating system from the list and press ENTER
5. Follow your normal log on procedure.
6. RIGHT CLICK with mouse anywhere on your desktop.
8. Select SETTINGS then select ADVANCED.
9. Select ADAPTER then select LIST ALL MODES.
10. Refer to your monitor user's manual or Quick Start Guide for the recommended resolution or mode for your monitor.
11. Select OK then APPLY then OK.
12. Depending on your computer setting, you may need to re-start the computer for the changes above to take effect.
Hope its useful!
Posted on Aug 20, 2008
  • 120 Answers
SOURCE: AOC 17" CRT monitor
Change to the lowest settings you can on the other monitor, then connect the 17" CRT. If you can see anything, go to display settings and slowly bring the settings up. If you lose the display, press "n" (there is a dialog box asking if you want to keep the settings, y or n). Most likely it is a refresh rate that is set to high. Try setting this to 60 Hz for starters.
Hope this helps.
Posted on Dec 12, 2008
  • 585 Answers
SOURCE: No 1440X900 Resolution Option in Display Settings
Windoze is not detecting the monitor correctly. Right click the desktop as you had before to get to the display settings. Click the "advanced" button at the lower right, on the next window, click the "Monitor" tab, and remove the check from the box from "Hide modes that this monitor cannot display". That should add to the settings the 1400 X 900 resolution you are looking for.
Posted on Jan 24, 2009
  • 126 Answers
SOURCE: aoc monitor set up
re install the drivers for garphic card or video card of your computer
thankyou for using fixya and dont forget to rate the solution
have a nice day
Posted on Feb 19, 2009
  • 39 Answers
SOURCE: "Input Not Supported" after adjusting screen resolution
What resolution are you trying to run? The native resolution for your monitor is 1440 x 900, setting to that should fix your issue
Posted on Jul 13, 2009
How do I attach this monitor to my laptop to use it as a second screen Please?
How do I connect my laptop to an external monitor - Page 2 ... > Laptop & Notebook > Video/Touch
May 6, 2013 - 10 posts
I have a pavillion dv5 2070us and the screen is cracked and I can't see ... I have a pavilion dv6, can someone please tell me the order of the menu ... 06-01-2013 08:19AM ... Once I connected my laptop to the extra monitor, the screen on my extra ...Connect your second monitor while the computer is on. 2.
The HTG Guide to Adding an Extra Monitor to Your Laptop
Aug 7, 2014 - Adding extra screen space to your laptop, however, can be quite a bit trickier. ... If you're looking to do the same, to add a little space to your laptop ...Playing Minecraft on the second monitor was a smooth experience with no drop in FPS. ... Because the AOC does what it does so well, we'll use it to highlight ...
AOC E1649FWU 16-Inch 1366 x 768 16 ms LED LCD Monitor, Inc.
Rating: 3.8 - ‎1,067 reviews
Jan 04, 2016 | AOC 936sw 19" Widescreen Lcd Monitor -...
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
Screen+ application that came with my AOC monitor isnt working when I try to change the configuration to multiple on display 1 or display 2. What happens is "AOC grid screen executable file has...
This sounds like a computer problem and not really a television problem. Check your driver files.
Try removing your driver files. Then disconnect your AOC monitor. Reboot the computer and login. Shut down the computer and reconnect the AOC monitor. Start the computer. Now install the monitor drivers.
Jun 27, 2011 | AOC 23 E2343fk 23 LCD TV
My Samsung R530 Laptop`s screen does not come on. There is a red indicator light on 2nd from right (next to the blue light that indicates the power is on) What does the red light mean?
first cut the power of ur laptop and ,disconnect the battery ,
again connect battery and connect adptor and power on u laptop
if problem is not solve,
connect crt/tft monitor through vga port,
if laptop give display , then chk ur function of laptop with fn button.
Sep 16, 2010 | Samsung R530 Notebook
Resolution problem with AOC TFT 185W80PF
Monitors don't need drivers to function. Either you need to configure it or it's dead.
Mar 16, 2010 | AOC 19" LCD HDTV Monitor
AoC 913 W Monitor driver. The monitor was the last in a show room and the seller didn't have no more the accessories, including the install CD! Now, the windows 7 only says I have a standard monitor, and I...
I don't think it matters whether or not you install the monitor. In fact I don't even think the monitor has a specific driver. The monitor should still display fine with a standard monitor driver. You should still be able to use all of its features. The more important driver is your graphics driver on your PC. That will determine your ability to change things like refresh rate or screen resolution.
In any case, if you would like drivers, the best place to go is to the manufacturer's website. This is the link for the manufacturer's Brazilian support page:
This is the North American one:
Usually you have to go to downloads and select your monitor and the driver you want. Although honestly, they don't even have drivers on the American site, they just have the manuals and the technical specifications of the monitors. In general, monitors don't need drivers, and they usually aren't packaged with them. The install CD that you are referring to that would normally come with the monitor usually only has the user manual for the monitor in different languages.
Feb 15, 2010 | Computers & Internet
I have aoc monitor the problem is out of range
Describe your AOC S7M51, 17 in. CRT Monitor Problem. with external TV Tuner card connected, Message shows "Warning, Not Support, Out of range" and with CPU connected, the same message shows from the booting... ??? are AOC monitors trusted for the efficiency ?
Dec 04, 2009 | AOC CT720G 17" CRT Monitor
Installation of aoc monitor
hmmm ok your resolution is probably set to high for that monitor you should start at 800x640 and go up from there you will probably have to borrow a newer monitor and set it lower
Oct 29, 2009 | AOC Monitor
Bought Samsung 2233BW Monitor, hooked the two plugs, power and DV1 cord started computer and switched on monitor, NOTHING HAPPENED. Silly thing just unhooked Samsung and hooked back up the AOC monitor no...
You might need to go into the monitor's setup menu and select the digital input. (That's DVI, by the way, for Digital Video Input, and not DV1.) Some monitors automatically detect the input but not all of them. Obviously, this doesn't apply if the Samsung has only a DVI input. It might also be necessary to tell the video card to turn on the DVI output. You can do this with your old AOC connected and use the video setting utility supplied with the video card.
May 22, 2009 | Computers & Internet
Mac PwerBook G4
go to display setting on your computer change the screen size to 1024x768 keep settings then retart your computer you should be able to see them normally after that
Oct 06, 2008 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
