Question about Canon PIXMA MX860 All-In-One InkJet Printer
My canon mx860 printer squeaks after print job completed
This squeak is intermittent
SOURCE: Canon Printer i950
is this still a current issue?
Posted on Aug 20, 2008
pineworks
  • 4041 Answers
SOURCE: can the squeak from the pro9000 MarkII canon
Yes just open up and spray with WD40 it not harm it but clean off over sprays or get on you paper
Posted on Jan 24, 2010
pineworks
  • 4041 Answers
SOURCE: Canon MP600 Printer - How do I fix error code 5100
Hi Whitey621
Error code 5100 Try
Solution 1:
Look inside for a tiny object like a piece of paper, a staple...
Solution 2:
There is a thin plastic strip running across the width in front of and below the drive belt: there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence.
Gently clean this strip with a damp lint-free tissue
Hope It Helps: Pineworks.
Posted on Jan 27, 2010
Grubhead
  • 5342 Answers
SOURCE: Do I have to reset chip on the Canon Pixma MX860
If you can yes!
Posted on Feb 13, 2010
  • 102366 Answers
SOURCE: find on line manual for mx860
Take your pick from http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18121
Posted on Mar 03, 2010
Printer is making a squeaking sound whenever I print. What do I need to do?
Toner Cartridge is the most common cause of squeaks and easiest thing to try first. Try a different cartridge.
Feb 15, 2016 | Canon ImageCLASS MF4350d Laser All-in-One ...
Canon pc-921 squeaking noise
1- might be the scanning rail -- if you can open and lube LIGHTLY slide scanner back and forth ( w power off)
2- caould be Drum, some make a whistling/ hollow sound
Sep 05, 2012 | Canon PC-921 Black and White Copier
Canon MX860 is out of ink and wont let me use the scanner. I have tried what this man suggested, "After you get the Error Message, press "OK" just to the right of the LCD screen on the MX860...
Call Canon Printer Support Number 1-800-243-0019 for Canon Inkjet, Pixma and Laser Printer Drivers. Contact Canon Business Support Number for your Business Printer.
Apr 19, 2017 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Canon Imageclass D661 printer is making a squeeky noise when printing. Sounds like whatever is turning is squeaking. Any suggestions?
How old or how much use does this machine get? The older/more use it gets, the more likely it is to start making random noises and squeaks. It could be a lose belt or just need some lubrication, but it's hard telling where exactly it would need the maintenance. As long as it's printing and copying fine, I wouldn't worry too much about it since it doesn't sound detrimental.
Hope this helps!
Aug 25, 2011 | Canon imageCLASS D661 Digital Printer
MAV-3 top load washer makes loud squeaky noise during the wash cycle.
Is it a constant squeak or does it go squeak-squeak - squeak as it agitates? It is a squeak that is intermittant then usually your brake is losing its hold. You will need a technician to do this job. It requires special tools that they should have. I repeat a technician should do this job. You can seriously hurt yourself attempting this repair. Also see if the inner tup is turning as it agitates, if it is then it i definately the brake. But one more time do not try this repair it is a dangerous repair that should be left to technicians. There is a spring that is under heavy compression that requires a tool to release it.
Dec 28, 2010 | Maytag MAV6200 Top Load Washer
My Canon MX860 always defaults to FAX not PRINT
Use your operating system to choose the printer rather than the driver.
For Windows XP, go Start, Settings, Printers and Faxes. Right click on the printer and choose Set as Default Printer.
Mar 28, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Printing 4x6 on photo stock about a 50 picture job
Your printer should be serviced in a shop, The Canon spec's tell us where and what lubricant to use, and how much.
Aug 10, 2009 | Canon i9900 InkJet Photo Printer
Canon PIXMA MX860 All-In-One InkJet Printer Logo
82 people viewed this question
old marine
old marine
