I purchased a Tower Quartz Heater about 16 or 18 months ago from Lowe's Home Improvement Store in Austell, Georgia. Now the weather has changed and I pluged it up and it will not work.I have tried the reset button and it still will not work. What do I need to do?I really would like to keep the heater. 1Touch The model #9200099004162. I really need this heater ASAP because I have a small baby in the house. Thank you for your assistance in this matter. My name is Elizabeth Maddox 4620 Hamlet walk Conyers, Georgia 30094 (404) 732-3873
    Top Expert:
  • Heating & Co... Master
  • 52,175 Answers
Sadly not having the capacity of HANDS on we can not guess what might be wrong with it . suggest you go buy a spare heater .
Posted on May 06, 2017
bobotfel
  • 236 Answers
SOURCE: 20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Posted on Jan 12, 2008
  • 124 Answers
SOURCE: Fan won't come on, either when heater or air-conditioner is turned on.
you have lost all control voltage. that is generated in the furnace. either the transformer has failed or the fuse in the transformer board has blown or the circuit breaker to the furnace has tripped or you have an open circuit to the furnace in the high voltage wiring. grab a volt meter and start with checking high volts at the furnace and back to the panel. if you have volts then start checking to see if transformer is generating low volts. as a side, if this is a furnace be sure the door is on secure and the door safty switch is depressed or guess what! no fan no volts no nothing. if any lights on board are flashing etc then you have power and it becomes a control problem. be sure your low voltage is getting sent to the stat via red and common on the furnace terminal board. good luck
Posted on Oct 30, 2008
  • 659 Answers
SOURCE: Rudd furnace
You have a safety limit switch that is either bad or needs to be manually reset. Some have little buttons between the two wires going to the switch that you can push to reset. If not they are automatic switchs then one is bad. You have to do an ohms test to see if each switch is bad or good.
Posted on Jan 05, 2009
cactus bob
  • 267 Answers
SOURCE: RUUD AIR CONDITIONING SYSTEM: HEATER DOESN'T WORK
there is no reset . some part somewhere has gone bad it had nothing to do with the bad filter ........ troubleshooting a hvac unit is tricky thing to do and if you want someone here to talk you through it , thats just a bad idea . i have spent years learning how to troubleshoot and spent lotts of money on the tools of the trade . i think you should call in a hvac repair person to check out your heater and find out the problem , its money well spent .......if this answer helped please rate this 3 or 4 stars . the high rateing will keep me in the paid answer department thank you
Posted on Apr 04, 2009
  • 4 Answers
SOURCE: Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
Posted on Jul 26, 2009
I need a pair of 4 wheels for my large Murano suitcase..where ??
Hey Carol, You might get them from Ebay...I hope this helps...
Apr 02, 2016 | Luggage & Travel
Heater element burnt up. I need replacement part.Do you sell the replacement part (heater element?)
We don't sell anything, we just provide information.
It is a Sears badged product. I think it is unlikely you will find the part, but phone them and complain. you might get a new one under warranty.
Parts Repair Home Improvement Services
Dec 02, 2015 | Tower Dryers
Enerzen customer Service address ... website phone number anything. I can find a remote?
New Enerzen 2000 Sq Ft Infrared Quartz Electric ... - eBay
www.ebay.com > ... > Heating, Cooling & Air > Space Heaters
eBayNew Enerzen 2000 Sq Ft Infrared Quartz Electric Portable Watts Heater in Home & Garden, Home Improvement, Heating, Cooling ... Duraflame Colby 1000 Sq Ft 1500WInfrared Quartz Electric Portable Heater Cherry ..... (1) Owner's Manual ...
Enerzen pro heater manual - Fixya
Nov 29, 2015 | Heating & Cooling
I have neptune parma toilet, which was purchased 6 months ago. It was working fine but now it has a problem with filling up. It takes a minute before it will start filling up then it makes noise like...
This is usually the fill valve. Try adjusting the water height. If that doesn't work, you can replace the fill valve fairly inexpensively with a new one at any home improvement store
Aug 27, 2011 | Neptune FB1625 Parma Toilet
Hello, I have been given an Admiral fridge. I can't seem to see an obvious model Nos but on the back 2 numbers: R134A and GC2227SDFW. Do these mean anything, as we would like to know if there is a...
HI,
The model number you gave was correct. I looked up the model and it does not list a filter, so you can use any in-line filter you find at the local hardware store or home improvement center. Just ask a clerk for a 1/4 in-line filter which should be installed between the water supply (valve on wall or source) to the fridge itself.
Not very expensive or time consuming task to do.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 27, 2011 | Admiral 26 cu. ft. Side-By-Side...
Need replacement quartz tube <17" for my Presto
If Presto longer manufacturers or stocks parts for your heater, there may be a good reason for it. Other than they now have a better heater. My best advice is to scarp the heater and purchase a new one, Your model may have had a safety issue.
Jan 27, 2011 | Heating & Cooling
I purchased a mini tower HP computer about 2 months ago from your store. I am happy with the peformance except for a couple of problems with internet. With comcast norton is provided and so McAfee was...
I would install the 'Windows Live Messenger' and use hotmail or another service linked to it. That's what I do.
I also would use a 'gadget' that has the weather on it which you can change the zip code on to get your local weather.
I wish you luck...:)
Aug 03, 2010 | Office Depot Computers & Internet
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
