Question about HP LaserJet 2840 All-In-One Printer
52 scanner error
Hi how can i fix 52 scanner error on my hp clj 2840 all in one i have changed the whole scanner assembly but the fault still shows up help
  • eddietee Oct 24, 2008
    hi how can i fix 52 scanner error on my hp clj 2840 all in one i have changed the whole scanner assembly but the fault still shows up help
  • t d
    t d Oct 23, 2017
    I just cleaned the mirror inside the laser case after error 55.0000 which was having high speed rotation mirror [like a jet engine].
    Works fine now!!!
  • 4 Answers
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Posted on Nov 03, 2008
    Habit-Forming:
    New Friend:
  • HP Expert
  • 75 Answers
Here are some steps :
Step 1 :Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize. Make sure that the flat, flexible cables (FFCs) are properly connected on the formatter and on the laser/scanner.
Step 2 : Check the FFC connection between the formatter and the scanner. Note Do not bend or fold the FFCs during the removal or reinstallation process.
Step 3 : Try connecting the product to a different power source or surge protector. If the error persists, replace the laser scanner assembly.
Get Online support for HP scanner is just one call away from you just need to pick your phone and call us to get complete HP scanner support by HP Scanner Support Number 1(844)355-5111.
HP Scanner Support Number 18443555111 Scanner Repair
Posted on Dec 05, 2017
    New Friend:
  • 31 Answers
If it helps someone....
I was fixing a problem with the carroussel solenoid, and, because to test it , you have to assemble the machine again,i decided to try to put the machine working without covers. The error code 52 showed up almost imediately.Reason? I pressed the "cover closed" switch but forgot to press the locking laser mechanism (a lever at his right side). Beeing working with copy machines all my life, i remembered that even a dirty mirror can cause the same problem ( its called LD,Laser beam detect). The lever interrupts the beam.
Im specialist in Ricoh but i do all the other machines too.
So, even a tech man can make mistakes, rsrsrs...
NOTE!!! Dont you dare to look inside the machine directly, This small lasers can do eye damage.
Posted on Sep 17, 2016
    New Friend:
  1. Had this problem before and replaced all of the parts listed above. Did not fix the problem...turned out to be a bad Toner Cartridge.
Posted on Apr 13, 2016
    Sergeant:
  • 260 Answers
Unfortunately there's not a lot you can troubleshoot with a 52 error. As it implies it's usually the scanner bad. It sits up top- under the top cover. It connects to the Formatter Board on the left side. and there's 2 connector s at the scanner itself.
for more help visit CBR Tech Solutions
Posted on Oct 13, 2015
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
Hp 2840
This printer has the rotating carousel assembly and therefore it is susceptible to becoming misaligned very easy and this could be the source of your scanner errors. More than likely of an inserting the wrong cartridge into the carousel...it can be fixed but judging by the age of this printer and the amount of labor to repair I would just junk this because of the time and labor involved ..plus there are definitely more productive and efficient models for a very low cost that will do you some justice.. that's just my opinion.
Jun 23, 2014 | HP LaserJet 2840 Printer
I have an HP 2840 and I have constantly been getting a scanner error 52 code. Per the text and research they say power it on and off, which did not work. Other experts say to replace the scanner...
hp 2840 error The device HAS Experienced 52 year internal hardware error. theoretically not initialize the scanner, to be replaced after that piece or set of diagnostic scan (logic board or motor, etc.
Apr 12, 2011 | HP LaserJet 2840 All-In-One Printer
Scanner error 5 on HP Color Laserjet 2840
Scanner Error 52 is a hardware error. If turning the power off , waiting 30 seconds and turning it back on does not solve the issue the the scanner assembly might need to be replaced. Another thing to try is make sure the printer is plugged into the wall not into a surge protector. Aside from that you may need to have the scanner assembly replaced.
Dec 09, 2010 | HP LaserJet 2840 All-In-One Printer
Scanner error 5
Based on the service manual the Error: Scanner Error 5 doesn't exist. However 52 Scanner Error exists. If the scanner doesn't function anymore the recommended solution is to replace the scanner assembly.
Oct 20, 2010 | HP LaserJet 2840 All-In-One Printer
Hp color laserjet 2840 error 52.
I noticed that this was posted in Oct 2010. If you are still waiting for an answer,
the printer has a scanner error. Power off for about 30 seconds. Power on, if
error persists, the scanner assembly will have to be replaced.
I hope that you got it fixed by now!
Oct 04, 2010 | HP LaserJet 2840 All-In-One Printer
52 scanner error on HP Color Laserjet 2840
The device has experienced an internal hardware error. Recommended Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If the error is still unresolved, contact Hewlett-Packard for technical support to troubleshoot the problem. Call HP for telephone support
Mar 22, 2009 | HP LaserJet 2840 All-In-One Printer
For my hp color laserjet 2840
You have a bad scanner assembly. Very expensive to get fixed
Mar 02, 2009 | Office Equipment & Supplies
Need to order a replacement FUSER it's located in the rear of the printer. If you live in the USA you need 110V if you're in Euro 220V see below for the part number you need to order.
RG5-7602-000
RG5-7603-000
Fuser ***'y, 110V, CLJ 2820/2840
Fuser ***'y, 220V, CLJ 2820/2840
CLJ 2820/2840
Aug 06, 2008 | HP LaserJet 2820 Printer
Hp clj 2840 scanner 3 error
hi how r u sir
m mohin raza lahore pakistan
my laserjet 3055 is error scanner 2,3
Jul 24, 2008 | Office Equipment & Supplies
HP LaserJet 2840 All-In-One Printer Logo
7,606 people viewed this question
Seeker5211
Seeker5211
