Question about Epson Artisan 800 All-In-One InkJet Printer
Remove the print head from an epson artisan - Epson Artisan 800 All-In-One InkJet Printer
gremlin11
  • 78 Answers
SOURCE: Cleaning Printhead on a Epson RX650 Printer
Truely, this is a job best left to the professionals. I have been doing these for a few years now and I can tell you that it is fiddly and tricky. The best solution for cleaning a printhead is through software. This is how the professionals do it and it is the only successful method. Removing the printhead in these unit is only ever done when they are replaced and this is not something that can be done without the epson service software as there is a printhead number that must be entered into the eprom to make the head work.
If cleaning of the head through the soft ware has failed, try moving the head to the left of the unit. where the head parks is the ink system assembly, also known as the purge unit. Make yourself a solution of dishwashing liquid and water, about 70% water. Fill the small pad area that the head sits on to almost over flowing and move the head across to park position. Leave the printer for 24 hours and then conduct the deep clean from your software. If you are still unable to clear the heads, than the head is faulty and will need to be replaced. Again, there is codes to enter through service software that is unavailable to all except registered epson warranty service centres, so it will be something to be done by the professionals.
I hope this is helpfull.
Gremlin11
Posted on Dec 13, 2008
sherlyn c
  • 134 Answers
SOURCE: trying to scan to email on Epson Artisan 800
If you are scanning wirelessly, you have to launch the epson scan software from your computer and scan to e-mail from there. You can scan using either professional or home mode.
Please take note that scanning from the printer only supports direct connection, which means you have to plug in the printer to your computer via a usb cable.
If you cannot launch epson scan, please let me know. And include the operating system that you are using too.
Posted on May 03, 2009
efs_perpends
  • 1996 Answers
SOURCE: epson stylus photo 2200 print head removal
Replace the cartridges.
Otherwise, it's unorthodox, but some users have found that this works in your situation. Remove the cartridge, cover the nozzle with a paper towel and use the pointed attachment of a vacuum to clean the dry ink from the cartridge. Be careful not to get ink all over. Then reseat the cartridge and print...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 26, 2009
  • 164 Answers
SOURCE: print head clogged
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
Testimonial: "thanks v much for the well detailed procedure. If this works it will have saved me a few hundred pounds"
  • 1382 Answers
SOURCE: Epson Artisan 710 won't print black
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results..
Thank you!!
Posted on Jun 09, 2010
Doesn't power up
There is a possible short circuit over the printer head system due to moisture content caused by the previous action. Remove the printer head, power the printer, check the what happen.
Apr 05, 2015 | Epson PRINTER,ARTISAN 730
Epson artisan 810 prints vertical black lines on all documents
this problem is usually fixed easily. this commonly occurs when print head is clogged. I use a facial tissue and alcohol to clean the head with the ink cartridge in an upside down position (if possible) then i print one or two test prints to get it back to normal.
Jul 06, 2014 | Epson Artisan 800 All-In-One InkJet...
Epson Artisan 800 won't print with ink in the cartridges.
Have you run the head cleaner function under the maintenance section? You may have to run it several times. Then make sure that you print something that uses the colors every week.
Aug 06, 2013 | Epson Artisan 800 All-In-One InkJet...
Epson Artison 837 printing a blank piece of paper.
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Dec 31, 2012 | Epson Artisan 837 All-in-One Printer
Artisan 810 will not print black
i have same model need to clean head of catridge then used air spray to clean heads of printer then install back again if this don't work then need to get new cartridge
Oct 13, 2012 | Epson Artisan 810 AllInOne InkJet Printer
Print problem artisan 725
Have you visited Epson's website Trouble Shooting guide?
Here is a URL for their site. Good Luck!
http://tinyurl.com/8kv476p
Oct 03, 2012 | Epson Artisan 725 USB/Ethernet/Wireless-N...
My Epson Artisan 810 prints horizonal light blue lines on all printed materials. How to remove the blue lines?
To resolve this issue, you need to print a nozzle check pattern and then determine if print head cleanning is need.
To print nozzle check, follow the steps below.
  1. Turn off the Artisan Series and your computer, if connected.
  2. Disconnect any connected USB cables.
  3. Load plain paper in the main tray.
  4. Press the On button to turn the Artisan 800 Series on again.
  5. Press Setup.
  6. Select Maintenance.
  7. Select Nozzle Check.
  8. Press Start.
  9. The Artisan Series begins printing the nozzle check pattern.
  10. If there are no gaps, select Finish Nozzle Check.
    If there are gaps, select Head Cleaning.
If the nozzle check pattern page prints correctly, the problem may be with your software settings, the interface cable, or your computer.
Oct 31, 2011 | Epson Artisan 800 All-In-One InkJet...
Is it ok to remove the print head from an epson artisan 810 printer to clean it? Will allignment be a problem?
yes you can remove it. and dont worry about allignment you can software manually re-align it will recoginize it immediatly
Mar 22, 2011 | Epson Artisan 800 All-In-One InkJet...
I have an Epson Artisan 800 Printer with a bad print head. This print head is beyond any more attempts at cleaning it and I would like to find out where I could find a replacement. I have found that this...
ihave found a solution that you only have to insert vinaigar...? alcool in the ink line wait about 30 to 60 min and it's done.
Some cies sold cleaner for printing heads
Louis
Aug 24, 2010 | Epson Artisan 800 All-In-One InkJet...
I have an Epson Artisan 810 printer. All of a sudden, the printer will not print the black color. I just changed that cartridge and that didn't help either. Thanks!
Hi you should clean the print head and you need to take out the cartridge and pay close attention as you put it back into the printer because it may not be fitted in place properly.
Aug 08, 2010 | Epson Artisan 800 All-In-One InkJet...
Epson Artisan 800 All-In-One InkJet Printer Logo
1,631 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
