Question about Acer AL1914 19" LCD Monitor
Menu keeps poping up & won't turn off
The Contrast/Brightness menu pops up in the center of the screen (as if you push the menu button on the monitor). The intervals are completely random and the time it stays up is also random. Sometimes it adjusts the cotrast, but usually it just goes off. Also, I can't turn off the monitor with the power button.
I should note that I have dual screens, both ACER 1914 black/silver.
This has happened before (about 4 months ago) and lasted a couple days, then stopped as suddenly as it started. Weird.
Is there a way to reset the monitor?
  • nbwalters Mar 31, 2009
    I have similar problem but with the VOLUME box. I can clear it by unplugging - NO BUTTONS work when box is open. When plugged back in, can use buttons for a few seconds & then volume box opens again.
    My area has been having power failures every few months & likely a surge fried the control board. Bought 4 yrs ago w/ 3 yr warranty so might see if any ebayer wants it for the panel.
Have you found a solution to this problem? i have the very same problem. i have taken apart the back of the monitor and found that if i take the small circuit board that is plugged into the power switch it goes away leading me to beleive that it is this small board but i do not know where to get it at. the number on the board is ar577 vk-583 rev:1. any help would be greatly appreciated. my email address is sachckc@gmail.com
Posted on Jul 27, 2009
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
Change brightness
The second button from the left on the bottom corner by the power button is the brightness button. If you press it the brightness menu is pop up on the screen. With the menu up you just use the three buttons on the left to select the function and the increase or decrease the brightness and contrast on the monitor.
BuddyMc
Aug 07, 2013 | Dell E178FP 17 inch LCD Monitor
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
I purchased my Norcent computer monitor four years ago. Now, the sub-menu Contrast/Brightness selection keeps popping up on my screen. So, I have to either push the #1 button to Exit or the #2 Adjust...
It seems to be a hardware issue with the buttons. They are stuck or the rubber cushion under the button has gone bad. That's the reason they are getting pressed automatically. You may take to a local store for a small repair.
Regards,
Shrey
Jun 04, 2011 | Norcent Technologies LM-965W 19" LCD...
Brightness contrast pop problem
one of the buttons will have dust in it causing it to trigger randomly or it is faulty take it apart and replace the buttons, make sure you do all otherwise it will still do it the work on impedence and they are all in series
May 28, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
The brightness/contrast menu keeps popping up and scrolling through the exit, brightness and contrast options. It is a Dell E173FP monitor. I have tried disconnecting and reconnecting the cables and...
Try pushing the buttons for the brightness if it does the same thing you need to replace it, the buttons might be damaged already by pushing too hard or it got stuck.
If this is just a new LCD monitor about 1 to 2 years old contact tech support of dell so you can get this replaced.
Jan 30, 2010 | Dell E173FP 17" LCD Monitor
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Acer AL1914 19" LCD Monitor Logo
464 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
