Question about Acer Aspire 5050-3242 Notebook
Messenger when i try to sign in to message with my hotmail address is says Our protocol is not supported by the server what do i need to do to enable me to sing in???
  • 1 more comment
  • nicholalucy_ Oct 22, 2008
    im workign on a acer aspire one notebook which uses linux software
  • robert_welsh Nov 11, 2008
    I am using Windows Live Messenger on different Laptop and want to use the ID on the Acer Aspire One... is this possible?
  • CS-Vicky May 11, 2010
    Does your messenger program work with MSN/Windows Live?
  • 70 Answers
I gathered that much. What messenger program are you using?
Posted on Oct 24, 2008
Hotmail pop and smp codes
  • POP server: pop3.live.com
  • POP server port: 995
  • POP SSL required? Yes
  • User name: Your Windows Live ID, for example yourname@hotmail.com
  • Password: The password you usually use to sign in to Hotmail or Windows Live
  • SMTP server: smtp.live.com
  • SMTP server port: 587
  • SMTP Authentication required? Yes (same as POP3 username and password)
  • SMTP TLS required? Yes
Aug 10, 2015 | Google Computers & Internet
How to correct Ox800cccOD error
Sounds like a Proxy Server issue.
  1. Click the Connections tab. Go to LAN settings. Click Settings.
  2. If the Use a proxy server check box is selected, click Advanced.
  3. In the Do not use proxy server for addresses beginning with box, type *hotmail*;*services.msn*.
  4. Click OK three times.
  5. Start Outlook Express, and try to access your Hotmail account.
Source: http://support.microsoft.com/kb/259133
Jan 09, 2014 | Computers & Internet
Im not sign in to yahoo.messenger?
try cleaning system and browsers junk and registry corruption with reginout, this problem will be hopefully resolved: http://www.reginout.com
also try this:
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "Firewall with no proxies" option.
3. Select the correct Internet connection type and country from the pull-down menus.
4. Click the "OK" button at the bottom of the window.
5. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
6. Enter your Yahoo! ID and password and click the "Sign In" button.
The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps:
1. Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
If neither of the above options work, you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps:
2. Enable the "Use proxies" option.
3. Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings.
5. Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the "OK" button.
If you try all of the steps above and Yahoo! Messenger still can't connect, contact your network administrator, Internet Service Provider (ISP), or the person who initially set up your computer to ensure that your firewall and/or proxy settings are correct.
Oct 10, 2010 | Yahoo Messenger
I kept having the same problems with YM. Every time i tried to sign in, it won't let me sign in. it's about yahoo! messenger troubleshooter and It said " We can't let you sign in". I am sure it was not...
6. Enter your Yahoo! ID and password and click the "Sign In" button. use registry cleaner reg in out to solve registry error for messenger
Sep 13, 2010 | Yahoo Messenger
It wont sign in
Hi
This will help, click it to view the solutions
http://www.fixya.com/support/r5025589-easiest_way_solve_yahoo_messenger
Please comeback and rate this.
Thanks
Aug 20, 2010 | Yahoo Messenger
Unsuccessful install of yahoo messenger
Try and install it again. If it unsuccessful.
you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps:Click the Messenger menu in Yahoo! Messenger and select "Connection Preferences."
Click the OK button at the bottom of the window.
Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the OK button.
Aug 19, 2010 | Yahoo Messenger
Msn wont let me sign in but when i go into my emails it lets me
Msn service is different from Hotmail.
Wait for a couple of hours and try again.
Feb 02, 2010 | Microsoft Windows Live Messanger
When I try to sign into Yahoo Messenger 9.0 I get this error message "Messenger encountered a connection problem. Please check the network connection and then click try again. (81003004)" I've changed my...
You might have some options to fix it: firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Maybe, i think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger,check it out, may be it blocked your yahoo messenger. if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.
Or other way, open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger.
thirdly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003004” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful and it works to solve your problems.. Please kindly support me.. Thank You!
Jun 10, 2009 | Yahoo Messenger
I can't signing into yahoo messenger
It may be the server is down, it's been happening a lot lately or your Yahoo! Messenger connection information may be incorrect. Yahoo! will fix it soon. To configure your connection, what you should do? Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." Enable the "Firewall with no proxies" option. Select the correct Internet connection type and country from the pull-down menus. Click the "OK" button at the bottom of the window. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button. Enter your Yahoo! ID and password and click the "Sign In" button. The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps: Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." Enable the "No network detection" option and then click the "OK" button at the bottom of the window. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button. Enter your Yahoo! ID and password and click the "Sign In" button. If neither of the above options work, you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps: Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." Enable the "Use proxies" option. Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings. Click the "OK" button at the bottom of the window. Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the "OK" button. Enter your Yahoo! ID and password and click the "Sign In" button. If you try all of the steps above and Yahoo! Messenger still can't connect, contact your network administrator, Internet Service Provider (ISP), or the person who initially set up your computer to ensure that your firewall and/or proxy settings are correct. Hope it was helpful!
Jun 09, 2009 | Yahoo Messenger
My linux acer notebook won'y let mw on to msn messenger
You need to get remote support if you are not savvy. This fault is a beast
try Mediarx.co.uk on 0845 20 20 118
Dec 25, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 5050-3242 Notebook Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
