Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Sony bravia kdf-50e2010 green band top and bottom
  • 6 Answers
SOURCE: SONY BRAVIA 50IN KDF E50A12U
try to take the bulb out and put it bk in make sure the door on the side is locked or it will not come on
Posted on May 30, 2009
  • 197 Answers
SOURCE: Sony Grand wega KDF-E50A10
bad lamp
Posted on Jun 07, 2009
circuitworld
  • 335 Answers
SOURCE: black frame around picture
Toggle through the "Picture Format" settings from your tv remote.
Flip through cinema mode, too standard....etc
Posted on Jun 13, 2009
vinnyq
  • 157 Answers
SOURCE: Sony KDF 3LCD Screen has a horizontal orange tint stripe at top
This problem is caused by a defect in the optical block. It causes about 1 - 1.5" tint usually green, orange, or yellow at the top of the screen. The part is very expensive, retails around $600-800 usually. You cannot fix it without replacing the optical block. They did have an extended warranties for this particular issue because of a class action lawsuit on certain models. Call Sony to see if your model is one of the ones they extended the warranties.
Posted on Oct 05, 2009
diodeic
  • 1622 Answers
SOURCE: Mode Sony Bravia KDF-50E2010 TV turmed
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this help in solving the problem....
Posted on Jun 12, 2011
I have a Sony Bravia KDF-50E2010 and after changing the lamp the TV stopped working. As i turn the power on the green light comes up for 2 or 3 seconds and changes to the stand by red light. Flashes t
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 02, 2018 | Televison & Video
Sony bravia
I had a different problem with a different model. My HSDI ouput stoped working. I went to SONY Live Chat with service tech. and he had me download new software to my BRAVIA and it fixed the problem. I would check it out. Go to http:esupport.sony.com.
Hope this helps, Steve
Jun 30, 2012 | Sony KDF-50E2010
Kdf 50e2010 pc 60hz
most equipment will not notice any difference between 50 and 60 hz power wise.
Apr 28, 2012 | Sony KDF-50E2000 50" HDTV
Sony kdf 50e2010 cant see picture in daylight
these are not designed to light to be directly on the screen--failing that being the issue the model indicated uses a lamp for the light source.
If another model and older set may require simple cleaning---confirm with comment button here that is is Sony and the model number is.....
Mar 23, 2012 | Televison & Video
TV switches itself off after 1 minute standby flahes red to green
there seems to be a possibility that your ballast might defective.. i recommend you replace it. It might not have enough voltage to keep up with the new lamp
Jul 02, 2009 | Sony Televison & Video
Sony bravia 50 inch projector tv kdf-50e2010
how do you remove the screen from sony kdf 50e 2010 i have removed screws from top and sides of tv but cant see how to release bottom of screen
Nov 07, 2007 | Televison & Video
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
49 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
