Question about Microsoft Windows Vista Ultimate Edition
Windows vista Hi, Recently whenever I boot up my laptop the 'safely remove hardware' icon appears in the notification area and if I go into it I am given a message that it is safe to remove the internal wireless card. The wireless card seems to work fine but obviously I don't want Vista telling me its safe to remove the thing in case I do by accident when removing say my usb memory stick. I have also noticed that when I switch off the wireless card using the switch on the front of the laptop a bubble also appears telling me its safe for me to remove the wireless card. Can anyone please tell me how to remove the wireless card from the sfaely remove hardware list. I dont want to hide or diable the safely remove hardware tool as I often use it for memory sticks etc. The computer is a vye s37 and up unitl recently it has never done this. Obviously the software for the card is what Vye put on when new. I have tried system restore but the restore points don't go back far enough to a point when I can get things working as they should be. Thanks in advance
Hiiiiiiiiiiiiii
plz give the vista theme pack 5.5.
Posted on Oct 23, 2008
How Do I Safely Remove Hardware
First off, some of those icons will never be removed, as they are necessary to be there for verification purposes. Safely Remove Hardware is one of them. Any time you plug in a device such as a flash card or external hard drive, devices that read and write data, they show up in this block. Since Windows does delayed writes to save time,l if you simply unplug these devices without letting Windows close out the write cache may cause corrupted files. Right clicking on the Safely Remove Hardware icon will cause a listing of attached devices to be displayed. Clicking on the device you want to remove (unplug) will tell Windows to close out the file cache and dismount the device. Windows will do this and them notify you that the device is safe to remove.
Now, regarding all those other icons that appear,such as OneDrive, volume control, and others, if you don't want them showing up in the taskbar, you can right click on the "^" caret symbol that expands the taskbar, then choose SETTINGS. This will bring up the taskbar settings menu. Scroll down the page to where is says "Select which icons appear on the taskbar" and select that. You will see a long list of possible taskbar icons. Turn off the ones you don't want to see display on the taskbar. This does not remove them from the system, but they will no longer display on the taskbar,
Aug 15, 2016 | Computers & Internet
My safe to remove icon has dissappeared how can re install it please
Which operating system ?????????
The system tray in Windows XP is the right side of the small blue bar at the bottom of the screen that houses the clock and a few other small icons. You can add icons to the system tray for ease of access, including the "Safely Remove Hardware" icon, which allows you to easily remove hardware from your computer.
Turn on the Windows XP computer and right-click the taskbar. Select "Properties" from the menu that appears. Check "Hide Inactive Icons", then select "Customize" A new window appears with all of the icons currently on the system tray, along with icons also for some programs that don't appear on the tray. Click next to the icon "Safely Remove Hardware," then check the box "Always Show". Click "Apply". Safely Remove Hardware Icon?
http://www.pulpfusion1.com/demotech/e_article000253202.cfm
Mar 13, 2013 | Compaq Computers & Internet
How do I safely turn off my Verbatim hardrive when I shutdown my laptop that it is attached to.
In the notification area you will see an icon with the Safely Remove hardware label - click on it; a small window will appear listing the devices connected to the USB ports (your stick included) . Click on the entry corresponding to the stick, wait a few moment to be unloaded from the Windows and take it out. Now you can shutdown safely.
Feb 06, 2011 | Verbatim VER95327 USB Hard Drive
Hello we have a problem with our laptop the battery charging icon will not appear so we don't if it's plugged in, not charging, Charhing or Not charging?
On Windows Vista/7:
Right-click the taskbar and select "Properties." The list of system icons in the "Notification Area" tab includes the power icon. Check the box next to it to enable this icon in the taskbar.
On Windows XP:
Right-click a blank area on the Desktop and select "Properties." Go to Screen Saver and click on Energy. In Advanced Option you could check the checkbox so the icon will re-appear in the task bar.
Best regards,
Pelu.
Jan 14, 2011 | Compaq Presario CQ60-220US PC Laptop
Hi, I would just like to download a manual so that I can figure out how to use my Seagate. For example, when I tried to copy some photos to save on it I could not. If there is a manual I cn download, that...
To use it all you have to do is to plug it in an USB socket on the pc of your choice - immediately an icon will appear in the notification area signalling the hardware connection and a new disk will appear in My Computer to represent it. Now it's just another partition, use it like you use the others (C, D, etc.)
To disconnect it properly just close all Explorer windows that are opened, click on the icon from the Notification area (a Safely... message will appear) and unplug it from the USB.
That is all.
Jun 18, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Task bar displays
Just right click the task bar and click properties and then click customize , then click restore default Over!!!!
Aug 22, 2009 | Microsoft Windows XP Professional SP2 Full...
Vista wont let my adjust my Volume
try restarting the computer, then go back to the Notification Area for your Taskbar, then verify if the volume icon is active for you to select.
otherwise, check this site
http://helpdeskgeek.com/windows-xp-tips/sound-or-volume-tray-icon-missing-in-windows-vista/
May 12, 2009 | Dell Inspiron 1525 Notebook
Icons disappeared from notification tray windows vista
Try to do system restore first, restore to the point where everything is working fine.
Oct 29, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
138 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
