Miele w435 rinse light flashing - Washing Machines
SOURCE: Washing machine problem
my w830 is doing exactly the same thing.
I am usually pretty good at fixing these sort of things so if/when I solve it I will post back here.
I think it is a motor fault - most likely the motor brushes are worn out.
Posted on Aug 07, 2008
  • 13 Answers
SOURCE: Miele W864 Fault
I have a W844 and the exact same fault occured. I traced it to badly worn brushes on the motor.
Posted on Sep 21, 2008
SOURCE: Miele 2104 Washing Machine
If your model is displaying the same symptoms as the W1930 that I repaired, then the cure is to replace or check the brushes on the main drive motor ($17) and check or replace the bearings ($12). This is much easier on the pocket book. I was able to confirm the presence of drive voltage (25VDC) to the motor terminals prior to the removal.
Posted on Mar 14, 2009
SOURCE: rinse light flashing on miele
Check the motor for worn brushes and or noisy bearings while it is removed for service. Any auto mechanic should have experience replacing brushes and bearings. Much cheaper than ordering a new motor. New brushes and bearings should cost around $30. The shop time should not exceed one hour. Miele charges about $50 for brushes if you can not find a local supplier. The W1930 motor that I rebuilt used a 6202Z and a 6201Z bearing set.
SOURCE: Miele w828
Hey you! I want to Miele w828 Final Spin Cycle 1100rpm Part 1/3 of 3/3 Part 1of3/3 of 3. Do you understand? Great Now let get to work.
Posted on Apr 25, 2009
I have Miele Softtronic W435 Plus. Display showing: check wastewaterpipe. What can I do?
Make sure the discharge pipe/hose from the washer to the house plumbing is clear.
Nov 19, 2016 | Miele Dishwashers
Miele w1918
Link to user manual. Code listed on page 32 indicates internal error Call service department.
Miele 1918 Operating Instructions Manual Page 32
Aug 03, 2014 | Miele Novotronic W1918A Front Load Washer
Rinse light flashes on miele w828
1) the water must be preheated, test the heating element if is defective
2)drain line is clogged proceed to fix it see the diagram
3)some sock must be removed, use plier
4)pump defective, inside with the propeler, replace
5)frozen pulley pump, replace
6)improve the drain, if about 4 inches cut of the diference.
b) if lower , install air/gap siphon break assembly.
God bless you
Jun 25, 2012 | Miele Novotronic Premier 500 Front Load...
Miele w435 soft-tronic check drain check inlet lights flashing have checked all filters and hoses all fine still not working
Hi - Try this empty the trays out of the washer - remove bottom wash arms by pulling upwards - below tha is a steel mesh - turn the plastic handle to unlock & remove the mesh - on the left of the tub locate a steel clip - below this is the housing for the pump - unclip & lift upwards - you will get a rush of water its ok - then clean the foodstuffs etc from in here as the propeller or impellar is found - turn machine on as the machine will a;lways start with a pump run - switch off after 20-30secs - check & assemble - try & see if it will work.
Cheers
Jul 02, 2011 | Miele Washing Machines
Main wash and rinse lights both flashing together and machine stopped
main wash and rinse lights both flashing together and machine stopped
Feb 09, 2011 | Miele Novotronic Premier 500 Front Load...
Premier w500 the rinse light flashes rapidly and the cycle stops. Any thoughts?
Hi just wondering if you got your problem with your miele sorted out yet as mine has done the exact same thing. Rinse light flashing rapidly and cycle stoped. Have cleaned the filter and re started but no joy.Any luck?
Jan 09, 2011 | Miele Novotronic Premier 500 Front Load...
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Aug 10, 2007 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
Top Washing Machines Experts
