Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Actually...it's a Akai PT5299HD
When I try to switch the source to "component 2" (the dvd player, a toshiba) the blue screen shows only "no signal".
I HAVE A AKAI PT5299HD TV AND WHEN I PUT ON THE AUTO FOCUS THE TV KEEPS TRYING TO FOCUS ENDLESSLY BUT DOES'NT FOCUS. IS THERE A WAY TO MANUALLY FOCUS THIS TV-MY WRITING ON THE SCREEN IS BLURRY?
Posted on Jan 11, 2008
AKAI 27 Model #LCT2785TA
The message you are seeing means that the tv is not receiving a signal from the source. Try hooking up a different source such as a DVD player or a Cable Box to that same input on the tv. If you have picture and sound then the problem is with the original source. If that does not work then you have a bad Main bd.
Jul 10, 2009 | Televison & Video
Component cables on HDTV not working
have you tried hooking a different video source upto to the tv to make sure it is not the dvd player that is not giving a signal to the tv?  Like an Xbox 360 or anything else with component output.
May 13, 2009 | Samsung TX-R2678WH 26" TV
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
A/V Signal Outout through Onkyo TX-SR705
Are you trying to record cable programming with your DVD recorder? If so, you might want to try using component cable as HDMI does have a copy protection circuit that might be preventing your recorder from receiving the image. Just try to connect the cable box component (RED/GREEN/BLUE) cable to your DVD recorder. If that doesn't work, then try to change everything over to component cables. HDMI is a great cable to use but it the only required to display 1080p images and the only current source that uses 1080p is a bluray player. Everything else, such as your cable box and DVD recorder is 1080i and component cables are perfect for it.
Mar 14, 2009 | Toshiba RD-XS32 DVD Recorder
Component video signal between KLH DVD8350 & Vizio 32" PlasmaHDTV
If the Visio TV has more than one input, don't forget to use its remote to make sure the correct input is selected. It probably wouldn't hurt to put a DVD into the player, confirm its running from the front panel counters) and let it keep running as you troubleshoot. At least then you'll know there is an active video source once you find it. Another thing you can try is to put in a music CD, if the player accepts these too (most do). Then when you get the TV set to the right input, at least you'll hear music, and can then go back to trying a DVD.
I know you're using component video, so remember that unlike HDMI devices, the TV is unable to switch to the correct source automatically. So it may just be that you've never had to switch the TV's input source before. Good luck! :-)
Jun 02, 2017 | KLH DVD8350 DVD Player
Humm coming from speakers - can't get cable to work
The RF input is the correct one for a cable signal. The other sources use the RCA and other ports which you can connect to other devices, like DVD or VCR players.
If the humm noise only happens when you're on the TV channel then it's likely just the station. Try changing the channel and see if that helps, and make sure the coax is screwed in all the way. Also make sure the other end, if connected to a VCR or other stuff, is tightly attached. If you share cable with many other people and the signal has snow (white spots on the TV), then you may need to buy an RF signal amplifier to reduce the noise.
Source changes the input (RCA versus coaxial versus component inputs), change the channel for different channels..
Jan 31, 2008 | Akai LCT2701AD Television
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
AUTO SIGNAL DETECTING NO SIGNAL
Yes, I seem to have fixed the problem on my Akai using some creative google finds. One of two things worked - not sure which:
1. Leave the set unplugged overnight - it must let the electronics reset when the residual charges clear
2. For my Akai (remotes and models vary), hit in remote's sequence quickly - brightness, freeze, menu, enter - this places you in some screen that offers a hard reset option. That didn't work right away, but i did it before the option above and then the set worked again.
My problem was really odd because it worked for the component inputs and you could see the video and TV signals inside the PIP windows, but not full screen as primary input. Why the TV could 'see' the signals in a PIP windows but not detect them as primary I have no idea.
Oct 13, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Similar Problem with Verticle Lines
sounds like a loose cable inside the set, if not it looks like a logic main board
Sep 04, 2006 | Samsung LTN1535 15 in. HD-Ready LCD...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
359 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
