Question about Samsung SyncMaster 753S 17" CRT Monitor
Samsung CRT Display Problem
This is what my computer desktop shows when i boot.
This comes up automatically and resets my display i.e. brightness, contrast, H-size, V-size etc. I cant change it thru the control panel.
Please give me a solution as fast as possible.
  • Cijo Yohannan Oct 24, 2008
    Actually the display toggles between 'unlocked' & 'locked'.
  • 105 Answers
Easy, simply hold the MENU button down 20 seconds (seriously!) and the message is replaced by "Control Unlocked" and you gain access to your menu again.
Posted on Oct 22, 2008
    Problem Solver:
Hi i have a crt television display problem..when i punch it.the display is good..but when i turn it off..and when i turn it on..again there is no display i only hear the click the switch...there is no display..i want the answer now plzz..txt me 09068863601
Posted on Aug 27, 2011
Display half of screen
screen back light on the other side is busted which need replacement.
Jul 14, 2012 | Computers & Internet
I cant run my gateway GT5676 pc in normal mode with Samsung TV / Monitor
If I'm understand you correctly you said you have the HDMI Cable and the VGA Cable comming from the Computer to the TV. You should only have one cable. Either use the HDMI from the computer to the HDMI to the TV or use the VGA from the Computer to the VGA on the TV. Once you have the cable connect select your input on the TV. If you have the VGA Cable connected your input to select on the tv will probably be PC or Computer. If you use the HDMI Cable your input to select on the TV will be HDMI.
One you connect the cables and select the input try rebooting the computer and the video might show up automatically on the tv. If not you will have to hit the FN (Function key) + the correct (F1 thru F12) key that corresponds to the external display. The correct key will probably have CRT/LCD on it or it might have the icon of a display. Press and Hold the FN key then hit the correct key (F1 thru F12) that toggles the display. The display will toggle on 3 setups (Computer only, TV only, both the TV and Computer).
Now as for not being able to boot up normally that's another issue.
Apr 06, 2012 | Computers & Internet
I need display of 56v samtron monitor
Did you check the adjustment setting on the brightness and contrast?
These two setting can be moved and stop the CRT from displaying,
Please move these two setting to MAX and see is there any image on the display.
Jan 31, 2011 | SAMTRON 55V 15" CRT Monitor
Our computer (SAMSUNG type GH15LS,540N MODEL,COLOR DISPLAY UNIT) CAN NOT DISPLAYED WITH BRIGHTNESS.DO NOT SEE DISPLAY DUE TO LIGHT LACK IN MONITOR.BUT OTHERS ARE CLEAR.KINDLY GIVE A SOLUTION FOR POWER...
The light on display is produced by a lamp over or under the LCD (TFT) display, or by the heated CRT electrodes on CRT display. Your lamp or CRT may have gone damaged.
Jun 05, 2010 | Measuring Tools & Sensors
Brightness display comes on by itself and won't turn off
1. Adjust the LOT screen preset.
2. Trace the G1 path , LOT to neck board. Sum times diode are capacitor problem.
3. LOT sarounds one 10Mf / 450 V capacitor bad
Oct 14, 2008 | HP mx705 17" CRT Monitor
Desktop screen display goes blue
can u boot into the system?if not it can be solved if yes then there is a problem with ur monitor
if u cannot boot intoo the system load default or system restor tht u do ,......savio k frm mumbai savio_k20@yahoo.com let me know if u solved it
cheers
Jul 05, 2008 | HP D2835 17 in. CRT Monitor
Monitor display problem..
Did you recent clean your monitor and perhaps some liquid dripped into the base of the monitor? I have seen the cleaner will contaminate the switchs and cause then to stick. The only way to perhaps remedy this is to dismantle, and visually inspect the button interface board.
Mar 21, 2008 | ViewSonic E70f 17" CRT Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
157 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
