Question about Minolta Office Equipment & Supplies
Spanner reset minolta ep 1054
Is there a reset for c05 error and how to reset it.
  • Minolta Master
  • 6,161 Answers
sir/mam Reset button is located behind the copier remove the rear upper cover you see a circuit board with machine on depress the small black button on the board. If the code comes back then the fusing unit the hot part is broke could be thermistor, heat fuse, heat lamp or the board that controls it. Have a tech look at it. DO not continue to reset or a fire can occur that would ruin a perfectly good day :) Code is for the FUSER!!!! (HOT PART)
Posted on Feb 18, 2015
  • 1294 Answers
SOURCE: COde for ep1054
Service code: Press Stop keys - 0 - 1.
Posted on Jul 30, 2009
  • 1294 Answers
SOURCE: minolta cspro 2010 error code c05
pLEASE DESCRIBE YOUR PROBLEM CORRECTLY.tHE 05 CODE REFER TO FUSING UNIT.Check or change the fuser unit components,clean the thermofuse and thermistors.
Posted on May 22, 2010
SOURCE: Minolta EO 1080 Copier-Error Code C05
Did you do anything to the fusing unit (ie cleaning thermistors or replacing the fuser roller?) That code means you have a temperature problem.  It will also come up if your power cord is loose.  You can check it by taking off the back cover of the copier and pressing in the trouble reset button while the copier is on.  It's a small black button. If the code goes away, you're good to go. If it comes back, you might have to replace some of your fuser components.
Posted on Oct 15, 2007
SOURCE: I want minolta ep 1054 simulation code,please help
stop ,zero,stop,zero,one,one then you enter the F mode programme
Posted on Mar 04, 2011
xptareq2000
  • 1447 Answers
SOURCE: Minolta EP 1054 - need
Hi, I have all spare Minolta EP 1054 copie.But quistion Where you live? If you live in Bangladesh.I will give you.But if you live another country you send money I send it by DHL.Please contact us xptareq2000@yahoo.com or call 08801819879575.
Posted on Aug 05, 2011
How to Fix Error c 05 Minolta ep 1054
Open up the machine, near the heater section, there is a push button on the circuit board.Press it, machine will restart and code is removed.
Feb 07, 2015 | Konica Minolta Office Equipment & Supplies
.EP 1054 does print faint on the page even darkened
Please open the back cover ,see the motherboard it has a reset button press it than machine are reset (Please press the reset button when machine power on)
Apr 24, 2014 | Minolta Office Equipment & Supplies
Minolta EP 1054 - need to change the cleaning blade
Jul 26, 2011 | Minolta EP1030/1030F CS/PRO Copier
Ink fall in down inside minolta cs pro ep 1054
Get the developer replaced. and developer unit cleaned. Have a Konica Minolta tech come out and clean the entire machine replace the required parts such as Developer, clear the counters and run the required F8
Oct 31, 2010 | Minolta EP1083 CS/PRO Copier
Minolta cspro 2010 error code c05
May 12, 2010 | Minolta EP4000/5000 CS/PRO Copier
My copier minolta cs/pro ep 2010 does not function. when you switch it on it displays a spaner symbol and error code 05
This is a C05 error code. This means you have a fuser error. The fuser is the section that gets hot right where the paper exits the machine. Most common failure in the fuser unit is the thermal fuse. The repair requires removal and some dis-assembly of the fuser unit to replace the fuse. Also have to use a special reset procedure to clear the C05 code from the machine after repairs are made. Do you have access to a local repair shop that can repair this for you?
Mar 20, 2010 | Minolta EP4000/5000 CS/PRO Copier
C05
Sir to fix will require you to take the rear panel off with the copier on. the upper rear panel once you have it off. Then find the circuit board on it will be a small black button, lower right side. press it. the machine will reset if it comes back your fusing unit (The HOT) part has a bad lamp thermistor, or thermosat. And will need replacing. The code will not clear by powering off then on. or by opening and closing front door.
Mar 10, 2010 | Minolta EP1083 CS/PRO Copier
Oct 13, 2007 | Office Equipment & Supplies
185 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
