Question about Hotpoint Washing Machines
Where is the filter on hotpoint wf225
Slight water leakage i think the filter may be blocked
barkencoa
  • 3463 Answers
SOURCE: Hotpoint Washer/Dryer
The filter is located behind the removable lower rear panel.
Undo the clip that secures the large black hose to the bottom of tub.
Remove plastic filter and clean, replace , making sure the hose is securely fastened, and test for leaks.
Posted on Jan 04, 2009
barkencoa
  • 3463 Answers
SOURCE: Water is leaking out of bottom of hotpoint aquarius wf445 wash ma
The filter is located behind the removable rear panel of washer.
Remove panel and on the right side you will see a large black hose, undo clip and remove hose, inside you will see the plastic filter, remove and clean.
Be careful, as their will be water run out when you remove hose..
Refit hose and make sure it is on securely..
Check for any leakage before you refit rear panel.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint aquarius wf325 filter problem, Blocked maybe?
You are correct as to the location of the filter.
Remove rear panel, locate large black hose at right lower side.
Remove securing clip and hose, inside you will see the plastic filter, remove and clean filter, note location of plastic ball.
Refit filter and hose, and securely fasten hose back on.
When you remove hose, watch out for water, as there will be some in the hose.
water test before fitting panel back on.
Thanks.
Posted on Jan 08, 2009
hektor1961
  • 70 Answers
SOURCE: hotpoint wma13 wont empty, think pump is blocked
Yes,
The water pump most be clugged and/or defective.
Posted on Aug 18, 2009
barkencoa
  • 3463 Answers
SOURCE: I have a Hotpoint Aquarius 1100 washer dryer and
Remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean the plasic filter inside hose..
Also check the pump for a blockage as well.
Thisn should solve your problem.
Posted on Dec 14, 2009
Where is filter to drain pipe please
I think its up inside the flutted black hose going from mechine to pump
Feb 28, 2015 | Hotpoint Ultima WF865 Front Load Washer
Water won't drain away from the drum. I think I may have a blocked filter. How do I access to clean the filter on a Hotpoint WT960G washing machine please. Many thanks.
Most Hotpoint washers do not have a customer accessable drain cleanout. Also, it may be a full or partial pump failure. Replacing the pump assembly will improve washer performance.
Replacement pump is about 20 Pounds delivered, and can be self installed quite easily.
Link to video
May 03, 2011 | Hotpoint Washing Machines
Hotpoint wma13 wont empty, think pump is blocked
Yes,
Aug 18, 2009 | Washing Machines
CAN ANYONE PLEASE TELL ME WHERE THE FILTER IS SITUATED. Thanx.
They are normally behind the "kick" panel that runs the width of the machine on the front. just pull the panel off, grab each end and pull straight off tilting slightly up as you pull. on the right hand side as you look at it you should see the filter.
May 01, 2009 | Washing Machines
I think the filter is blocked
To make it faster, I will report a good solution from barkencoa, that is one fo our experts.
I quote:
"Remove rear panel, locate large black hose at right lower side.
Plz rate my solution"
From Hotpoint aquarius filter problem
Feb 01, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wf325 filter problem, Blocked maybe?
Thanks.
Jan 08, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Thanks.
Jan 05, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Water leaks from the soap dispensing tray on Hotpoint WMA 56 model
In the sump hose there is a filter, remove the hose and clean out filter insert, water is being forced up dispenser hose because it cannot empty fast enough.
Dec 24, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
81 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
