Question about Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Gas burner hob popping noise
2 of 6 burners popping
4 Suggested Answers
bigg t
  • 640 Answers
SOURCE: Low gas Flame
check the vent plug on the regulator.
Posted on Dec 25, 2007
SOURCE: Ignition on gas hob fails sometimes on certains burners
open the hob covers with a screw driver and check the wires that carry the spark are intact and haven't been chewed by a rodent ie (RAT/MOUSE) like my one had been :-)
Posted on Sep 07, 2008
  • 188 Answers
SOURCE: Burner not working properly
the injector nipple is blocked unscrew nipple antie clockwise and put in a cup of boiling water and sterident tablet then reasemble.
Posted on Mar 26, 2009
Gas hob Luce(hotpoint) gas on glass 5ring burners keeps going out on low flame when pull pan drawer beneath out
Same problem with my hob. I adjusted the small jets to their lowest setting in order to be able to simmer -impossible on the bigger jets. The problem is the vents underneath the hob. These can't be closed off so the problem appears to be in the design. The solution I have to use while I save up to by a decent German model is to open and close the cupboard doors underneath the hob very, very slowly.
Nov 19, 2013 | Ovens
Gas burners have a popping sound when trying to heat food in pans
Make sure you clean them properly, Call a repair man if noise persists.
Nov 06, 2013 | Magic Chef 31000 Gas Kitchen Range
Stoves sterling 1100DF hob burners will not ignite there is no spark to any burner. Gas flows as normal.
More than likely the spark module has malfunctioned and needs to be replaced.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 23, 2012 | Stoves Kitchen Ranges
PRODUCT DETAILS For MSP60SS
Matsui MSP60 Stainless steel Built-In Oven and Gas Hob Package. Matsui MSP60 with Hob: 4 Burner Gas Hob, Fan oven, Minute Minderand B Energy rated top oven. Matsui MSP60 Stainless steel Built-In Oven and Gas Hob.
Product Features
•Dimensions (cm): (H)59.0 x (W)59.5 x (D)57.0
•Ovens: Fan oven
•Timer: Minute Minder
•Hob: 4 Burner Gas Hob
•Colour: Stainless steel
•Energy rated top oven: B
Hope this helps. Your generous rating will be much appreciated.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Oct 20, 2010 | Ovens
WHEN I SHUT OFF MY BURNERS AFTER THEY HAVE BEEN ON FOR A WHILE, THEY POP.I WOULD LIKE TO STOP THAT IF POSSIBLE. WE USE PROPANE.
EXTINCTION POP
(1) Recognition of Extinction Pop. Sometimes a small explosion of gas in the burner head occurs when the burner is shut off. Under these conditions flashback on extinction has taken place. This problem is commonly called "extinction pop." Extinction pop, as the name implies, creates a noise or a "bang." Ordinarily, it is not followed by burning in the burner head or mixing tube, since the gas supply is turned off. The pop occurs at the time the gas supply to the burner is shut off. Sometimes it may be delayed for a few seconds.
(2) Results of Extinction Pop. Ordinarily, extinction pop is not unsafe or hazardous, and will not damage the appliance. It may result in a customer complaint because of the noise created. However, the resultant concussion may blow out the pilot flame. If an automatic pilot safety device is used, it will act to shut off the gas supply to the appliance.
(3) Correction of Extinction Pop. It may be possible to eliminate extinction pop by reducing primary air supplied to the burner. Make sure this air adjustment does not cause yellow-tipping during normal burner operation. Check proper gas pressure and proper gas orifice size. If these actions fail to correct the problem, burner change may be required.
Sep 08, 2009 | Tappan Kitchen Ranges
Minimum distance between diplomat chimney extractor and gas hob
Minimum above a gas burner should be 750mm and for electric hob should be 650mm.
Aug 07, 2009 | Kitchen Ranges
Coleman 425 2-burner white gas stove pops out flame on low heat
There is water in your fuel. Drain the tank and flush it out with denatured alcohol. Refill with fresh fuel.
Jun 21, 2009 | Coleman Sport & Outdoor - Others
Apr 28, 2008 | Rangemaster Proffessional 110 Gas Kitchen...
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
262 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
