Question about Panasonic VIERA Televison & Video
TH-L32C4S brand new, but when plug in with direct cable wire all I get is static picture and sound...please help
salt56
  • 373 Answers
SOURCE: No sound on some channels
Check in the menu to see if the audio is on SAP. If it is change it to Stereo. Hope this helps
Posted on Dec 30, 2007
Scan channels, disconnect cables and connect them back in.
Posted on Apr 29, 2008
stradeteox
  • 88 Answers
SOURCE: 47LG70 static like green pixelation
This is going to be either a voltage adjustment or a faulty control board and/or Y sustain board.
You need to have a qualified technician check the voltages on these boards to determine if they need to be adjusted or else (if the voltages are fine) these boards will need to be replaced.
Posted on Jan 08, 2009
  • 267 Answers
SOURCE: brand new samsung tv. plugged into cable box.
return to seller or take authorized servicer.
Posted on Mar 16, 2009
  • 8457 Answers
SOURCE: I can't get a picture or sound. It's brand new
Ur other tv work with the Fios signal?If yes,ur tv have problems,brand new tv call for warrenty service or return it where u buy it for the replacement.
Posted on Mar 13, 2010
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
I have a Panasonic Viera TH-50PX60U Plasma Picture Problem. The TV picture screen is showing up as purple. If i unplug the blue cable, the tv shows in black and white. If i plug in the cable, the...
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 24, 2017 | Televison & Video
Mother board mixed up ribbon wires
th ribon cables dont need to return to exactly th same port as it came out of ..if u look at th hard drive from th top with th pins facing u make sure th red strip on th edge of th ribbon is on th right,, closest to th middle then plug th other end in th coloured port on th motherboard (usually blue) plug th power cable in next to th ribbon on th hard drive.. thassit.!! absolutely make sure that b4 u touch anything inside th computer to ground ur static electricity on summing metal 1st..or wear a anti static wrist band.. if this is ignored th chances of blowing th components are immense..
Nov 23, 2008 | Compaq (261671-001) Motherboard
Samsung TXG2547 25"inches TV problem
you have damage your tv micro chip, regulator ,or horizontal output with static current when you plug out your tv from th plug,what is clicking is the relay trying to power up your tyv but due too the damage it cannot power have a tech repair your tv good luck
Oct 26, 2008 | Samsung TXG2547 25" TV
Mitsubishi rear projection no picture and static sound
I assume you are using a cable input, such as a box or the main Cable line connected directly to the TV. examine the main Cable Coax, look at the copper wire that sticks out from the connecter, make sure it is long enough, if its to short, gently pull it with a long nose plier until it reaches the rim of the connector. Sometimes when connecting the coax to a source, the copper wire in the coax is to short to make contact, and as a result you get no signal. Hope this solved your problem.
Jul 03, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Had same problem on Viera 3D Plasma TH-P54VT20A
Select Sound from setup menu and ensure SPDIF Selection is set to PCM (not Auto)
Feb 28, 2008 | ViewSonic NextVision N2010 20 in. LCD...
Dec 30, 2007 | Televison & Video
Sound problems
are you sure you have plugged in the speakers properly? maybe u inserted the cable in the wrong port or u just didnt insert the cable property. A loose connection can cause static and obviously it wont play anything. Please check.
Dec 24, 2007 | Harman Kardon HK19.5 Computer Speakers
Picture, No Sound from HDTV Box
CON-YOU'VE DIAGNOSED YOUR OWN REPAIR.GET A NEW CABLE BOX.JOE TV
Apr 20, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
New TV - no picture at all
Try pressing input on your remote and make sure the source is selected to what you have it plagged in. For example cable box plugged into hdmi1 set input to hdmi 1. Also can you access tv setup at all? If not your tv might be bad to begin with.
Apr 26, 2017 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
Televison & Video Logo
82 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
