Question about Xerox Office Equipment & Supplies
I want a very best quality A-3 size color laser printer anyone guide me please
  • 2,574 Answers
5 Suggested Answers
  • 547 Answers
SOURCE: Dell 3100cn laser printer poor print quality
It sounds like you've got contamination on the drum cartridge or on one of the toner cartridges.
I'm actually going to be installing black toner in my 3100cn in about 8 hours, so I'll inspect and clean each of the carts, and write up the process for you tonight.
Posted on Jan 27, 2010
Testimonial: "Thanks! I have gone through all the instructions on Tech support for the printer. All cartridges have been cleaned and drum has been cleaned. Guess "
SOURCE: I purchased a Samsung CLX-3175FN All In One
I contacted Samsung service. Turns out my Printer is still under warranty. Samsung set up a service order for an in home service call. I am still disappointed with the printer since I have owned HP inkjet printers in the past and used HP Laserjets in the office in very adverse conditions and NEVER had a problem over the years. I think this will be my last Samsung printer. It was an experiment; I chalk it up to another learning experience along with many others I have been taught over the years.
Thanks,
Tom Pilz
Posted on Feb 28, 2010
seeker5211
  • 1089 Answers
SOURCE: My HP 9500 hdn color laser printer is printing in
Run the PQ Troubleshooting and from the Print Quality SubMenu you should have all the adjustments you need.
Posted on Sep 22, 2010
  • 23 Answers
SOURCE: I have Epson Color laser
Well, just googling for "epson cx11nf toner" gave me several results.
I personally like lasertechservices.com service and prices. They have "compatable" Epson cx11nf cartridges for $30.2 (black) to $33.95 (Cyan, Yellow, Magenta). If your a little more technically skilled, they also have toner refill kits for your printer for only $93.95 (all 4 colors, includes reset chips). Some printers don't allow you to "refill" the starter toners that came with it, so you may need to buy the cartridges the first time around (ask them, they will know).
I only mention the above site because I have used them myself for my printer(s), but there are many other companies doing the same thing. Try to choose a supplier with good technical support, in case you happen to run into any problems (as in, do they have a phone number to call, because "email only support" sucks).
Posted on Jun 16, 2011
6600 colour laser. Printing contact sheets from Lightroom 3. Quality is unsatisfactory. How can I improve quality?
Laser printers in general are not extremely good at photos. You may be able to increase the contact sheet picture size. If you've not already set "best quality" mode, try that.
May 05, 2015 | Xerox Phaser Office Equipment & Supplies
Tip
How to Differentiate Between Laser Printers & Inkjet Printers
You require a new printer but you do not know whether to buy an inkjet or a laser printer, as you are not aware of the differences between the two. Each user or organisation is faced with the dilemma while buying a new printer. Most customers operate under strict budgetary constraints and it is only normal to consider initial purchase costs and space limitations. However, it is prudent to take into consideration the long-term operating costs associated with the particular printer.<br /> The choice of printer will, largely, depend on your requirements. Inkjet printers are usually ideal for home users who have limited text and photo printing needs. Laser printers are better suited to larger office environments with high-volume and high-quality printing requirements.<br /> The differences between a laser and an inkjet printer are generally categorised into a few broad segments, namely, cost (initial and maintenance), speed, quality, space and networking facilities. It is also essential to understand the technology behind the manufacturing of the laser toners and ink cartridges as this is a major contributing factor towards the cost.<br /> <b>Difference in Technology & Networking Facilities between Inkjet and Laser Printers</b> -<br /> The technology used for inkjet cartridges is simpler and the parts are less expensive than the laser toners. The black inkjet cartridge has only black ink. The color inkjet printer contains two main ink cartridges, for black and other primary colors respectively. The primary colors are then divided into three compartments for cyan, magenta and yellow ink. The primary colors are consequently mixed to produce all other colors. The cartridge contains a reservoir which has compartments with metal plates and a number of tiny nozzles on the print head of the cartridge. The number of holes or nozzles depends on the resolution of the printer. It is usually 21 - 128 nozzles per color. The ink gets heated, when the current starts flowing through the metal plates, after the print command is given. The heat causes vapor bubbles to form inside the cartridge and make the ink swell up. The ink then flows out in droplets from the nozzles onto the paper in a few milliseconds. A vacuum is created (once the ink droplet flows out) which draws more ink into the nozzles ensuring a steady supply of droplets as required. This common technique is called Thermal Inkjet and the coinage of the name 'BubbleJets' by Canon has been due to the bubbling vapors.<br /> The Laser toners use a more elaborate and complex technology. A powder called Toner is used by laser printers, fax machines and photocopiers to print text and images on laser and photo paper. Initially carbon powder was used but now manufacturers use disposable cartridges which can sometimes be refilled. For the laser toners, individual carbon particles are mixed in a polymer which melt in heat. This binds to the fibers in the paper. The laser printers consist of the printer toner and the drum. The positively charged toner gets attracted to the negatively charged drum. The toner is transferred to the paper by the drum. The toner contains special wax that melts and dries in milliseconds. When the toner is transferred, the fuser applies heat and pressure to make a durable image. The fuser system is made up of the hot-roll and the back-up roller.<br /> The high-end laser printers generally come with networking facilities for you to connect to your computer network directly. This cuts down additional costs associated with networking, as is the case with ink printers. The ink printers cannot be linked to a network directly. Networking has to be via a computer, therefore more expensive.<br /> The laser printers are larger in size than the inkjet printers. The latter is, therefore, space saving and ideal for the home and small office users.<br /> <b>Difference of Quality & Color between Laser and Inkjet Printers</b> -<br /> Since Inkjet Printers spill out tiny droplets of ink to print, the resolution is lower than the laser printers. Laser Printers printer better quality text, as their resolution is higher. High resolution also helps the laser printers create precise fonts without fuzzy edges. However, the cost-effective inkjet printers are usually recommended for inexpensive color printing. These can print high quality text, large photo prints, graphics, banners and greeting cards at less than half the price of a color laser printer. Nevertheless, it should also be seen if the cost of ink and paper suits your maintenance budget. Laser printers are capable of producing good quality prints on all kinds of printing paper but the inkjet printers will require inkjet paper to produce good quality prints without any fuzzy edge brought about by 'bleeding'.<br /> <b>Difference in Speed between Ink and Laser Printers</b> -<br /> If laser printers lose out to their inkjet counterparts on account of price, they are way ahead when it comes to speed of printing. Users who need large volumes of printing also prefer the laser printers. Laser printers are more suited to general office use than the inkjets. The least expensive laser printer can print around 10 to 15 pages per minute. The inkjets are usually rated on the speed of draft or quick printing mode, which is suitable only for proofreading purposes. The HP Deskjet 5650, which is a fast color inkjet printer, prints at a speed of 21 ppm Black, 15 ppm Color in the draft mode. However, the speed drops considerably when high quality black text is printed and it also takes longer to print a letter-sized quality photo.
on Nov 10, 2010 | Office Equipment & Supplies
I want to print onto a 3 x 5 card. it dosent want to go through the envelope feed. Is there any way to print onto a 3 x 5 card with this printer
1.Click 'Print' in your application, click 'options'
2. On the Paper tab or the Paper/Quality tab in the printer driver, specify the size of media (eg 3x5in)
3. On the Paper tab or the Paper/Quality tab, select your media type from
the 'Type is' drop-down list.
4.Load the media with the narrow side forward and the side to be printed on facing up.
Adjust the side and rear media guides to fit the media.
5. Print the document.
Aug 21, 2011 | HP P3015 Laser Printer
Hello I have an HP 2600n and would like to print on 5x7 paper, is this a possibility with this printer? it seems that it will pull the paper through but nothing is printed
Copied this from the specification on HP site.
It would appear not to take 5 x 7. It's the 7" is to small, 8.5 is the smallest.
Media sizes, std.
Letter, legal, executive, No. 10 envelopes, Monarch envelopes
Media sizes, custom
Tray 1, 2, 3: 3 x 5 to 8.5 x 14 in
Media types
Paper (plain, letterhead, prepunched, bond, color, rough, preprinted, recycled), HP Color Laser Glossy Photo Paper, HP Color Laser Glossy Brochure Paper, HP Color Laser Matte Brochure Paper, HP Color Laser Matte Photo & Imaging Paper, HP Color Laser Soft Gloss Presentation Paper, HP color laser transparencies, labels, envelopes, cardstock
Nov 30, 2010 | HP Color LaserJet 2600n Printer
LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
May 17, 2010 | HP LaserJet 2605dn Printer
Won't print at all
I have the same printer. It can be hooked to a network using an RJ-45 cable - which looks like a wide modular phone jack - or a USB cable.
It can be hooked up such that both cables are installed, but it is much better to pick one type of communications method and stick with that.
If you use USB, it is better, simply because you need to choose a network (IP) address for the printer.
Follow the installation guide, and don't plug in the USB cable until that step is called for by the install guide.
Best of all, you can also plug it into an earlier USB link, like 1.0 or 1.1 and, of course, 2.0.
I have mine plugged into an older computer which uses a 1.1 USB jack, and the communication is perfect, and prints without any problems.
So, I would say that you may have missed one simple step in the install procedure which, when remedied, will allow that printer to work like a charm. You will love the quality of the output, especially when you use a good quality photo paper, either glossy or matte.
Make certain you choose a paper specifically for a color laser jet printer. Color paper for an ink jet printer, when used on a laser jet printer, may cause unnecessary smearing of the image.
-a.
Nov 23, 2009 | HP Color LaserJet 2600n Printer
Ricoh prints everything in left Margin
Check the printer properly and see what size paper the printer thinks is in there, or check at the controll panel.
-Carl, please let me know if this helps.
Jun 25, 2009 | Ricoh CL3500N Laser Printer
Color laser printers. Costs for toner vs. initial costs for ptr
Have you thought about having your printer cartridges refilled? There are huge savings to be made in doing so and the quality can be just as good as the original cartridges (depending upon the refiller). Another option would be for you to purchase an older color laser printer such as the HP Color Laserjet 4500 or 4550. I use one myself and couldnt be happier with it. And as its an older printer, you can get the cartridges relatively cheap.
Jan 24, 2009 | Xerox 4500 Laser Printer
It is time to clean or change something?
Best printer I have ever owned!!!!!
In your HP toolbox Icon on desktop/start menu or typically located via web browser at: http://localhost:3910/ you can select troubleshooting tools to try using a cleaning page This has worked for me. This process cleans the paper path. You may have to run this 2 times if it is really bad.
Facts about laser printers: you need DRY paper for best print quality. laser paper is reccomended. as toner sticks to it better
Cleaning Page
Use this process to maintain optimum print quality. See the user guide for more information.
1. Click the "Print" button to print out the Cleaning Page. 2. Remove the Cleaning Page from the output bin, and load it printed side down in Tray 1. 3. Click the "Clean" button to complete the cleaning process. (Note: You may also need to press the "GO" button on the device.)
You can find more information about this here:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=446153&prodTypeId=18972&objectID=c00314469
trust me using airdust on the spillage can create bigger problems
Mar 31, 2008 | HP Color LaserJet 2600n Printer
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
