Question about Numark ttUSB Turntable
My turntable is playing too fast,
Just unpacked the TTUSB and set it all up, played a record and its playing way too fast. I switched to 33rpm and its still way too fast?
4 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: converting to itunes
Have you recently upgraded any software (iTunes, Windows, etc)
- OPTiC
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Posted on Aug 08, 2008
  • 104 Answers
SOURCE: Numark turntable records record AND sounds in the room
the mic is in the computer somewhere, there will be a way to mute the microphone either in the vinyl software or in the system settings of the computer!
Posted on Feb 11, 2009
caroldon
  • 17130 Answers
SOURCE: When i play a record,
This can be due to a bad head as when the ANGLE changes as the head moves closer to the center it could be changing in the angle due to counter weight on the head.
Try and adjust the position of the head, make sure there is no dirt, check the connections of the head and finally try with another good LP record.
Posted on Sep 22, 2011
BOTH SPEEDS PLAY WAY TOO FAST
Drive belt may have slipped, check speed on record, check if switch has another position or is not moving all the way, check if turntable is seated correctly.
Jan 03, 2015 | Numark ttUSB Turntable
MY TURNTABLE START PLAYING ON THE SECOND SONG OF THE 33" VINYL, WHAT IS THE PROBLEM
Do you have a switch to select the size of the record as well? We had a record player that could play 7" singles at 33rpm (floppy vinyls given away by Sunday papers). We had to select 33rpm and also 7" on a separate lever for this to work.
May 23, 2014 | Marantz Audio Players & Recorders
Pitch is off--too slow before, now too fast.
The speed is set by a synchronous motor that drives the turn table. There may be a small adjustable resistor (pot) that will do the trick.
May 31, 2013 | Audio Technica AT-PL50 Turntable
My Jensen JTA 450 is playing LPs too slow even though 33RPM is already set. The songs are slower than usual. Please help me.
The record that you are trying to play maybe a 45rpm recording. Some 45's were released in album size recordings.
Jun 20, 2012 | Audio Players & Recorders
When I play an Album, it will play say 2 songs then on the 3rd song it will come up 'Finished Recording' it seems to only do this when it feels like it. Thanks Erika
what exactly are you trying to do just play records or dj with this? and what software are you using thats saying finished recording? Are you even Recording anything? please let me know
May 17, 2011 | Numark ttUSB Turntable
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
Nov 25, 2009 | Crosley Audio Players & Recorders
Sony ps-lx250h belt-driven turntable runs too fast.
Is there an adjustment knob? if so use that! if not it will have to be adjusted from under the turntable!
this should fix ya!
Dec 12, 2008 | Sony PS-LX250 Turntable
Converting to itunes
- OPTiC
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Aug 05, 2008 | Numark ttUSB Turntable
Numark ttUSB Turntable Logo
161 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
