Question about Siemens 24 in. SL84A305UC Built-in Dishwasher
Dishwasher won't drain all the way
New Siemens dishwasher, istalled and hoses connected with no kinks or bends in them. Ran the cycle fine but at the end when we opened the machine, the bottom was still full of water. Closed and it drained a bit each time we closed it, but it still never fully drained.
  • 5 more comments
  • jameboz Apr 24, 2008
    same prob. 2 year old siemen model...goes through cycle fine, then still has water on the bottom. Cancel/Drain...a little will go down at a time, but because water is still in bottom, it stinks and nothing dries
  • guy241 Jul 30, 2008
    I have a 3 years old dishwasher and washes great. Now for the fisrt time I opened the door and found it full of water. Try to cancell wash and nothing happens. Still washes just fine. Just won't drain. Does the pump run backwards to drain and forward to wash
  • thehills_ca Aug 10, 2008
    Dishwasher does not complete drain and dishes have film, like dirty. How do you drain the unit?
  • Craig Olson
    Craig Olson Nov 05, 2008
    I have the same problem. 3 year old unit, runs all cycles, does not drain. Lines are totally free. Appears we paid a premium for a piece of junk.
  • Anonymous Nov 19, 2008
    water wont drain anymore
  • afwas machine Dec 27, 2008
    Same problem here. Washes fine, but does not drain water out of tub. Drain hose has been checked for clogs, none found. Machine can be drained manually by switching on and pressing the 2 buttons marked "cancel drain" until "clean" light turns out and closing the door. This may need to be repeated a few times for a full drain.
    So it would seem that the impeller works fine and even the drain pump works to some extent, but just not good enough.
  • afwas machine Dec 28, 2008
    Update: opened up machine, checked drain hose, no obstructions except some debris in air gap/water inlet. Applied power straight to pump: pump works. So, issue is not the pump itself. The pump is partially controlled by the water level module, but that seems to work fine.
  • 3 Answers
After cleaning the air gap thingy my machine works fine again. This thing sits on the left lower back side of the machine (left when you are standing in front of the machine). It is a transparent plastic box with 3 hoses attached (drain hose from pump, drain hose to the outside and water). Inside the box is a black plastic float. If debris gets caught in there the float gets stuck.
Solution is to remove the part by pulling the 2 drain hoses out (there is a small black clip holding them in) and unclamp and remove the water hose. Rinse and shake the housing until the float moves freely again and reassemble.
Posted on Dec 28, 2008
  • 6 more comments
  • afwas machine Jan 03, 2009
    Update on my last solution: machine ran fine for 3 cycles then did not drain completely again. Although I thought the drain was not blocked (I checked the part from the under sink knock out to the machine) on closer inspection I did find an obstruction. In my case it was an apple stem caught just behind the back flow prevention valve.
    Here is how to check: open machine and remove the round filter and larger flat filter from the bottom. Inside the white plastic tub on the left side is a plastic cover over the entrance to the pump held by a single star (torx) screw, size # T20. Remove screw, pull cover and now you are looking at the light blue pump wheel. Check if it runs freely and remove any debris. Just behind the wheel is a black rubber strip. This is the top of the back flow valve. Pull it out, check its integrity and check for anything preventing the valve from opening all the way. This is where I found my problem; the stem was wedged behind the valve so it could not open all the way. This caused the machine to drain incompletely.
    For good measure you can unhook the drain at the under sink knock out and counter flush it now you have the back flow prevention valve out to make sure there is no other debris blocking the machine. Reassemble in reverse order.
    In retrospect I should have done this first before pulling the machine from underneath the counter and opening it up.
    Update: after cleaning as described above the machine worked fine for 3 cycles then again drained incompletely. I thought I had no blockages and checked the hose from its connection to the machine to the under sink knock out.
    What I found later was an apple stem caught behind the back flow prevention valve in the machine. This prevented the valve from opening all the way, causing incomplete draining.
    This is how to check: remove filter (the round and flat part on the bottom of the machine. In the white plastic tub on the left side is a cover held with 1 star (Torx) screw size T20. Remove screw and cover; you are now looking at the light blue pump wheel. Make sure it runs freely. You can also see a small black rubber strip; this is the top of the back flow prevention valve. Pull the valve out, inspect for integrity and check for any blockage behind the valve. This is where I had my problem.
    Once the valve is out you can disconnect the under the sink hook up and reverse flush the drain to check for any other debris; it will wash back into the tub of your dishwasher. Once satisfied that the WHOLE drain is free assemble in reverse order.
    In retrospect I should have done this before pulling the machine from under the counter.
I have a siemens Model SL34A and it will run the whole wash cycle but at the end it is still full of water and will not drain . Tried drain declogger and checked all the hoses for clogges and dose not appear to be the probblem.
Posted on Feb 13, 2008
Siemens SR65E000EU dishwater check water supply indicator flashing, wont power off. Any ideas on the issue? Water supply seems fine. Thanks.
Sounds like no water going into the machine. If you have already checked the stop tap and the hose isnt kinked, then you probably need a new solenoid
Jan 31, 2018 | Siemens Dishwashers
We ran the dishwasher the other day, it wnet through its entire cycle, but never had any water enter the machine. What part might be bad?
1 check that the hose is turned on 2 Check for kink in the hose 3 check the actuator/electric vaklve is getting power or try jumping it and see if it opens
Jul 12, 2011 | Microwave Ovens
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
My Dishwasher will not drain, it works fine, but when gets to drain cycle it just does not let water out
most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely if your model has access to this.
Hope this helps.
Jan 25, 2010 | Sears 24 in. 14181 Built-in Dishwasher
Will not empty water, and stops before end of cycle. Doesn't appear to be any blockages. Filters have always been in place, and appear clean on inspection. No twists or sharp bends in drainage pipes.
most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Jan 25, 2010 | Bosch Dishwashers
Water left in the bottom of a hobart (kit aid) dishwasher
Drain valve not opening, kinked or blocked drain hose. Remove the hose from the sink plumbing and look for debris. try running the drain hose into a bucket to eliminate a domestice plumbing issue, but hold onto it when it starts draining, or you will have a wet kitchen. Timer contacts may not be opening drain valve.
Sep 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Hi! We just installed our LG LDF8812WW built in dishwasher. We ran our first cycle and after the wash cycle the dishwasher displayed error code OE. I read that it meant there is a problem with the...
I actually own an LG LDF8812 myself, except mine is stainless steel, not white. So be it. :-)
Anyway, it sounds like you have just unboxed the unit and it is brand new, not just new to you. I am also assuming that you have this dishwasher connected to an Air Gap valve which is connected to the garbage disposal. Please reply if I am wrong.
Because it is (apparently) new, the first thing I would check is that any water is draining from the unit. A common problem on new installations is that the knockout inside the neck of the garbage disposal unit. A quick way to test that is begin the dishwasher filling, then open the door and press the two buttons that give you Cancel. Hold for three seconds and the DW will begin to drain. Being careful of the hot water that should be draining into the kitchen sink via the disposal, but watch for water to come flowing with a healthy stream - not wimpy.
Please reply with what you have found and correct my assumptions that I got wrong. Good Luck!
OH, if the problem is not something at the end of the drain hose, before you try to crack the unit open (and possibly void your waranty) dial the number on in the user guide and schedule a service call asap. Have your proof of purchase available.
Mar 31, 2009 | LG LDF8812 Stainless Steel Built-in...
My bosch dishwasher gets stuck in wash mode. We have to turn the dial to move to the next cycle. When we check inside soap suds are built up on the bottom. We use less than a 1/2 of an Electrasol tablet,...
Have you checked it is draining properly? Partially-blocked drainage would likely be detected and cause the dishwasher to stop mid cycle, with soap suds left behind. I would check (1) the drain filters inside the dishwasher and (2) that the hose is not kinked (3) that all the S-bends etc where the dishwasher hose connects to the drain under the sink are clear.
Jan 30, 2018 | Dishwashers
Frigidaire Dishwasher
A common problem with dishwashers is the non-draining machine. If you are having trouble, check to see if the drainpipe and sink trap are clogged. If you still have drainage problems after doing this, check your drain hose to make sure there are no kinks or bends. if the hose looks worn out you can replace the hose pretty inexpensivley. if your have thoughly checked from dishwasher to trap under the sink where your dishwasher should drain to and it seems clear you may have to call in the repair man.
Jun 18, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Siemens 24 in. SL84A305UC Built-in Dishwasher Logo
4,958 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
