Question about Brother HL 5250DN Laser Printer
Connect 5250 DN by LPT1 and USB?
Since I'm having problems with my network, I want to connect a second computer to the printer by USB; the first is already connected by LPT1. This is a temporary workaround. Can I do this? Will I be able to print from both computers?
Thank you.
  • 1,124 Answers
Sure you can.
But you have to share your new USB printer on the network if you want to use this print (usb) from the computer that has LPT1 printer connected on it.
Posted on Oct 22, 2008
  • 1 more comment
  • Pablo Csaky
    Pablo Csaky Oct 22, 2008
    Sorry, I thought that you had two printers instead of one.
    You have to read the manual of your printer to use at the same in the same network the same printer with differents ports.
  • Pablo Csaky
    If you have problem with your LPT1 port, Unplug that port and You can set your printer via USB and share with the other computer and this will be fixing your problem
  • Pablo Csaky
    I assume that you have a working network.
    If not you need a router, or a cross cable connected between computers via ethernet card.
Where is LPT1 USB port on Lenovo H430 for printer
Few computers use LPT1 connections, most use USB .Use a Printer cable with a USB to laptop. Your printer should have a cable that has a printer connection to a USB laptop connection? What is the Printer?
Dec 13, 2012 | Lenovo H430-2558-1CU Desktop PC
Trying to connect 4 MACs to all in one Kodak 5250 printer and will not connect via wireless. I had to set up so that the other pc's have to print from one location via hardwire. I tried installing...
If you have one PC connected to the printer via USB you can share the printer to your Mac computers easily:
If the printer is connected to a Macintosh computer via USB:
1) Open System Preferences
2) Click on Print and Fax
3) Highlight the Printer and Check the box Marked "Share This Printer On The Network"
If the printer is connected to a windows computer via USB:
1) Download "Bonjour Print Services for Windows" from Apple's website
2) Install it on the PC connected to the Printer.
3) After Installing the Above, Run the Bonjour Printer Configuration Utility and select the Printer you want to share and it will share it over the network to all your apple devices.
Mar 02, 2011 | Kodak ESP5250 All-In-One InkJet Printer
How to use HP Laserjet 2300 dn offline. This printer is a network printer
Thank you for contacting FixYa with your inquiry.
This printer can work very well via a standard printer cable directly connected to your computers LPT Terminal. Most of Microsoft's current Operating Systems already have the LaserJet J2300 drivers built in and will automatically install when connected.
To confirm your connection to go to your computers printer setup and ensure the driver is configured to print from LPT1 port and click on print a test page. (Start/Settings/Printers/LJ2300 - Right Click on properties then click on the tab for ports. The general tab should have a button to print test page)
The network card that comes with your printer (Jet Direct Card) will not be used with this method nor will the Ethernet cable be required.
Hope this helps helps. Please keep us updated and remember to rate this answer.
Dec 14, 2010 | HP LaserJet 2300dn Printer
I have Windows XP. I was finally able to connect the Kodak ESP 5250 with the USB cable and print. However, I can't get my computer to print wirelessly. The printer is connected to my wi-fi. Do I need to...
In Windows XP:
Start/Settings/Printers and Faxes
Right click /Properties
Check Port tab
If the printer port connect to USB, install another instance of printer, connected to WiFi
Nov 07, 2010 | Kodak ESP5250 All-In-One InkJet Printer
I need to connect my hp 1115 printer to my windows 7 computer and I don't have disc to install it. Please help!
We can use generic drive of deskjet 550c to install this printer. Just follow the below simple steps to fix the problem.
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers,select HP deskjet 550c and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Thanks and Regards,
Feb 01, 2010 | HP PhotoSmart 1115 InkJet Printer
Unable to connect Dell 3000cn to wireless network (cable from printer to Linksys router). Printer shows ICP address, laptops set to share files, but computers do not "see" printer at all. Ideas?
The printer driver needs to be installed and the printer port changed from LPT1 or USB to a TCP/IP port.
Please refer to my tip on Setting up HP network printer. the principles are the same for setting up network printers with a print server.
Dec 02, 2009 | Dell 3000cn Color Laser Printer
I would like to connect my laptop to my home printer... is this possible? If so, please advise. thank you
need to know make and model of laptop because the connection is either usb or lpt1
Nov 21, 2009 | Office Equipment & Supplies
Switch to LPT1 from my computer
Go to start - settings - printers and faxes
Right click on your printer - click properties
At ports tab change from tcp-ip to LPT1
Click apply
Don't forget to connect your printer with parallel LPT cable
Jul 24, 2009 | IBM 6400 Matrix Printer
Brother HL 5250 DN status shows "error". Won't print.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 26, 2008 | Brother HL-2070N Laser Printer
Printer time out error!!????
is your printer connected with a serial cable, if so, you may have to install the printer and software again, but if you are connected via usb and this is the given error then there is a connection fault as, you may already know that LPT1 is not a usb connection but serial cable.
Apr 29, 2007 | Canon S400 InkJet Printer
Brother HL 5250DN Laser Printer Logo
79 people viewed this question
James Cagle
James Cagle
Jim Keysor
