Question about Scosche Industries Scosche High Performance Amplifier Car Audio Amplifier
Need mannual aftermarket radio installation on 07 silverado gm21sr mannual
  • krazieklown8 Oct 22, 2008
    all I need is to know is which side to plug audio input to w/out bose middle or outside?
  • 4 Answers
Should only fit on way but if not plug it in BOSE
Posted on Oct 25, 2008
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
Radio will not come on no lights fuses look good 03 silverado
factory or aftermarket radio? I really cant help much on factory, if its aftermarket check your power and ground wires have good connection and in proper places, also check fuse on the back of your stereo
Mar 22, 2014 | 2003 Chevrolet Silverado 1500
Silverado radio wiring
Some trucks and gm cars have two kinds of systems one without a amp,and one without so judging by what you're saying you probably have one with a amp so yes you can but it is complicated and you would need to bypass amp so just get the kit that's required for your vehicle.
Jan 14, 2018 | Cars & Trucks
Installing aftermarket stereo in 99 silverado which wires from stock harness connest to aftermarket harness
connect the wires as indicated below
1999 Chevrolet Silverado C1500 Wiring, aftermarket stereo wire colors
Car Radio Battery Constant 12v+ Wire: Orange, yellow
Car Radio Accessory Switched 12v+ Wire: Yellow, red
Car Radio Ground Wire: Black, black
Car Radio Illumination Wire: Gray (Tape off) not used
Car Stereo Dimmer Wire: Brown (Tape off) not used
Left Front Speaker Positive Wire (+): Tan, white
Left Front Speaker Negative Wire (-): Gray, white/black
Right Front Speaker Positive Wire (+): Light Green, gray
Right Front Speaker Negative Wire (-): Dark Green, gray/black
Left Rear Speaker Positive Wire (+): Brown, green
Left Rear Speaker Negative Wire (-): Yellow, green/black
Right Rear Speaker Positive Wire (+): Dark Blue, purple
Right Rear Speaker Negative Wire (-): Light Blue, purple/black
Oct 22, 2011 | 1999 Chevrolet Silverado 1500
Just installed aftermarket radio and the engine shuts off after a few seconds after hookup. why
if this is 99 up truck security system is shutting it down trucks are very hard to change radios in even with radio from same year from salvage yard your radio and bcm must match vin #. say with factor radio or take it to radio installer
Sep 19, 2010 | 2005 Chevrolet Silverado
1992 Chevrolet Silverado radio wont turn on, fuse is good and ignition is good also, trying to install aftermarket radio and cant figure it out!.
check the connection to constant (usually yellow wire). Also check the remote wire (usually red) make sure they are both hooked up to where they need to be
Sep 27, 2009 | 1992 Chevrolet Suburban
04 silverado fm radio works but cd player dosen't or any info
Had the same problem with my 2004. Replaced the stock radio with a aftermarket pioneer unit. If you replace it make sure you by the aftermarket harness so it will plug right in and all your chimes will work.
Jun 28, 2009 | 2006 Chevrolet Silverado
2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Good luck
Aduz
Mar 21, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Scosche Industries Scosche High Performance Amplifier Car Audio Amplifier Logo
229 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
ravie__s
Level 1 Expert
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
