Question about Apex Digital AT2702 27" TV
Cannot make horizontal and vertical size and position adjustments
I believe my APEX TV is beginining to "bloom" and I am missing some of the picture on the sides and the bottom. I would like to simply adjust the horizontal and vertical sizes but there are no external adjustments. (It used to be these controls stuck out the back of the TV, but no more.) I opened up the chassis (CH-10C) but could not see any pots to adjust, except for two on the YOKE. Can anyone offer me some ideas as to how to adjust or correct the horizontal and vertical deflection? thanks Basil
  • 5 more comments
  • Anonymous Feb 11, 2008
    I have the same problem as the one described. My TV (Apex PF 2720) quit and when I checked out the fuse, I found the fuse to be blowed. I also found one of the bridge rectifier diodes to be shorted. After replacing the rectifier diodes, the TV now works but the screen is narrowed by 2 inches on the top and on the bottom. How can I increase the vertical size? Also, the FULL button on the remote has no effect. My son-in -law also bought an identical TV (same model) and has had the same problem. I need answers. My E-Mail addy is as follows:ke2dk@yahoo.com
  • rbowman Apr 28, 2008
    I have a 27" apex TV and have the same problem! the picture is cut off at the top, bottom, and both sides. I have tried and tried to fix, but there is no adjusting it.
    Soooo annoying! I cannot see scores, tickers at the bottom, etc. Now that i have upgraded to digital cable, i cannot read the channel numbers on the side of the screen when I go tot the channel guide! Luckily I was given this TV, but I will NEVER buy an APEX tv. I can't believe multiple people have had the same problem and APEX hasn't fixed it or offered a recall, etc.
  • gooze329 Dec 27, 2008
    I have the 20" Apex and I am having trouble adjusting the horizontal picture, e/w wide doesn't seem to do anything and h-shift just moves the picture from left to right, it doesn't help the problem.
  • Anonymous Jan 04, 2009
    I'm having the exact same problem as everyone else with the aspect size!
  • royaloak913 Feb 26, 2009
    My discrepancy is the scroll on the bottom of news channels such as FOX and CNN that carries information for viewers to read. I am unable to read it because there are no adjustments for the horizontal and vertical. I agree with one consumer who has a similar problem that APEX should recall these televisions or at least fix it for free.
  • Anonymous Mar 05, 2009
    Does anyone know how to reset the t.v. settings back to factory. I do not have the manual to my Apex AT2702 as i bought it in 2002. I screwed up the Volume settings so now no matter what number it states for volume...the volume stays at the same level...does not get lower or louder. Please help
  • Downcycle May 11, 2010
    deafbyipod can you email me the manual?  When I press mute with 0 volume the mute doesn't turn red.  So I can't get it to work.  Thanks for any help.
OK...I paid a whole $50 for an Apex AT2702 that had [undisclosed] vertical zoom, horizontal shift, vertical shift and width issues. Before I raised hell for the person who sold it to me, I decided to first exhaust all alternative solutions.
I found that in order to tweak these settings, you have to be in service mode and must have a service manual which I can email upon request.
BE SURE TO DOCUMENT YOUR CURRENT SETTINGS SINCE ANYTHING YOU CHANGE WILL AFFECT YOUR SET'S PERFORMANCE !!!
1-Reduce your tv volume to 0
2-press the MUTE button on your original tv remote [you'll see "Mute" in red on the screen]
3-AT THE SAME TIME, press MUTE on the same remote and MENU on the tv controls.
This set your tv into service mode [there will be a red "S" at the top-center of your screen.
You'll need the table in the service manual page 47 where there are V-SHIFT, H-SHIFT, V-ZOOM, E/W WIDE default values that will need to be changed. WATCH YOUR SCREEN as you change the values to ensure you don't over do it.
If you have news ticker and sports scores issues, you'll want to be tuned to CNN, FOX, ESPN or whatever to see how your changes are applied.
If you have tv guide problems then tune to that channel or press info and see what happens when you make the changes.
BE SURE TO DOCUMENT YOUR CURRENT SETTINGS SINCE ANYTHING YOU CHANGE WILL AFFECT YOUR SET'S PERFORMANCE.
This has worked for my set and you may attempt this solution on yours at your own risk.
I'm no longer pissed off that I got a bogus tv because it now works just fine and I can see everything!
Good Luck!
Posted on May 22, 2008
  • apexhater Mar 31, 2011
    this was EXACTLY what i needed! thanks a ton bro... now i can play the games i want
I took the advice of Deafbyipod and ran with it. It is true, you have to make sure your tv volume is all the way down (to 00), then hit the mute button (and see MUTE at the bottom of your screen), then simultaneously hold the mute button on your remote and the menu button on your tv to access the service menu. Then while the Menu 00 button is highlighted, hit the right arrow on your remote, this will take you through different options. Keep arrowing over until you find the V options. Arrow down to the V Shift. hit the enter button and use your remotes' up and down arrows to adjust the picture. The V correct option moves the screen also, we changed several of these options to make it look right. As Deadbyipod suggested, you need to have something at the bottom of the page to see where you're at. I also found it helpful to pull up the Guide to adjust it too (since by adjusting the vertical it cut off the top of the guide). And finally, I couldn't figure out how to get back to the tv, I simply shut the tv off and back on.
Posted on Mar 07, 2009
After much frustration and tinkering i found the solution in my case..
My APEX AT2702s was cutting off the screen about 2 inches on all sides.. I read much documentation and was having trouble getting my TV into service mode. The way I did it was,
reduce volume to 0
press mute on tv
then press mute again on remote, while at same time pressing menu on the tv, not the remote.
the tv will flash the normal menu for about 1/2 a sec then will go into service mode. I thought I was to press mute and menu on the remote, which did nothing. Hope this helps too and good luck
Posted on Jan 19, 2009
Http://worldwideelec.com/apex_asc_site/apex.html Download the service manual.
Posted on Dec 31, 2009
    President:
  • 3,130 Answers
There are no adjustments that you can adjust to make the size and width larger. Your need to the power supply fixed as the B+ is lower then it should be. These adjustments your asking about are tweaking adjustments and if they are not on the board then they are preset or in a service menu. They do not make any major changes in the picture. If all of a sudden theres a change in the height or width, its not an adjustment. Good Luck
Posted on Jul 31, 2006
To whomever it may concern,
I have an Apex PF2720 with the same problem. The TV quit, so I checked out the fuse and found it to be blown. I also found one of the rectifier diodes to be shorted. After replacing all the rectifiers an the fuse, the TV now works, but the verticle size is reduced by 2 inches on both the top and the bottom. My son-in-law bought an identical TV and has had the same problem. I need some answers.
Thank You,
Doug
Posted on Feb 11, 2008
SOURCE:
On my Apex TV screen, some of the picture is cut out. How can i adjust the TV resolution?
You cannot adjust the resolution in CRT TVs. Its not like a monitor that is compatible with a number of resolutions from a computer for example. CRT TVs resolution's dont work like that.They take an input usually from a composite, Svideo or coaxial source and display it on the screen.
When you say the picture is cut out is there a black bar on top/bottom/middle of the screen? In older CRT TVs that usually means a problem with the TV itself and would need to be taken in for repairs or replaced.
Mar 05, 2011 | Apex Digital AT2708S 27" TV
Help
My television has a picture of a red key at the bottom left side. I can not unlock this, does anyone know how?
Sep 16, 2009 | Apex Digital AT2008 20" TV
I HAVE A SONY KLV-40U100M IS THERE AN ADJUSTMENT FOR HORIZONTAL AND VERTICAL. MY PICTURE IS MOVING ACROSS THE SCREEN FROM LEFT TO RIGHT. THERE ARE GRAY BARS SEPERATING THE PICTURE. COLOR IS ALSO MISSING.
You've got more happening than an adjustment. There is an IC that handles the sync and my guess is that is bad. You'll probably need a pro if you're not familiar with TV circuits.
Feb 18, 2009 | Apex Digital AT2702 27" TV
Apex pf3225 picture is to wide for the screen
I was able to get a good picture by doing the following. Using your PF 2025-3225 remote:
Press the volume to zero
Pressmute on the remote and hold (tv should say mute)
hold the menu buttuon on the tv
There are 10 menus as you press the arrow buttons, go to the first with anything "H". you will use the "e/wide" and "H" item also Trapzium and the parabolic setting and slowly use these until you get the desired quality.
The go to the "V" menu and adjust carefully until you get the desired quality. Do not adjust anything that is already set to 1 or 0, If you do and you get a blank or lined acreen just press the opposite arrow and it should go back to your picture.
Power off and on after you see a good picture.
You could use your cable guide or DTV Playlist as your picture as they have alot of items in the corners. that is how I did it, it worked for now.
Dec 09, 2008 | Apex Digital PF3225 32" TV
Apex 32 inch tv Model #PF3230
try to reset the settings of the tv. check the manual on how to reset it.
Aug 27, 2008 | Apex Digital PF3230 32" TV
Picture cutoff
i have done some research on this and have come up with this:
1. the tv itself has no manual picture adjustments it is all done automaticaly even if you go inside the actual case of the tv there just is no way to physicaly adjust this.
2. i think it is called "blooming" from what i have been told this is a problem with the high voltage circuits going to your tube
3. it would be more worth it to get a new tv or just deal with the picture loss rather than get it fixed.
i could be wrong on all accounts but that is what i have found through researching the same issue.
if there is a way to fix this i would love to know as well
Jul 05, 2008 | Apex Digital PF3225 32" TV
Over projection on apex hd 51"
try to go to menu using ur remote and adjust the v-size/vertical size....
Jan 29, 2008 | Apex Digital GB51HD09 51" Rear Projection...
SCROLLING LINES AT BOTTOM OF TV SCREEN
need replace the capacitors at side of the ic vertical marked on the , init to the big first.
Jan 11, 2008 | Apex Digital AT2708 27" TV
Tv too bright
This problem might be caused by a problem called blooming. is the picture fuzzy and does the picture look to be streched out. Since you do not have contrast and brightness control this would almost completly point to the HV section of the TV either the control and screen grids of the CRT are going bad or the HV power supply is about to go bad, I would suggest that if you have a background in electronics that you check the HV at the anode of the picture tube and make sure the voltage is from 20Kv to 40Kv using a high voltage probe. You will need a schematic to aid you in your troubleshooting
Nov 07, 2007 | Apex Digital AT2008S 20" TV
Picture too wide for screen
your problem is called blooming as you might be aware of very high voltage in tv. you can check 1 high output voltage fron power supply. 2 if it is ok then the problem is in horizontal section.you can check cap.in hor. section at last flyback transformer. hope this will help.
Sep 25, 2007 | GE 31GT659 31" TV
Apex Digital AT2702 27" TV Logo
2,042 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
