Question about RIM BlackBerry Pearl 8100
I need help with my blackberry 8100
I got a blackberry 8100 i keep geting an error come up sayin jvm error 102 reset. wot can i do thanks.....
  • amber977 Nov 29, 2008
    I have the same problem JVM error 102 - thanks
  • nena_azul171 Mar 16, 2009
    jvm
  • 3 Answers
Try restoring it with desktop manager
Posted on Apr 13, 2009
Hi I haven't used my phone for a couple of years. when I switch it on now it say.. error 102 reload software... what do I do?
You need to do a Factory Reset, AKA a Hard Reset. This removes everything on the phone and reloads the operating system. Your phone is a Blackberry?
  • Error 102 Reload Software - BlackBerry Support Community ... https://supportforums.blackberry.com/t5/BlackBerry-Device-software/... Hello, I've just had a problem with my Blackberry 9930 phone. I already tried updating the Blackberry Desktop Software and I also tried the phone,
  • Error 102 - Reload Software - Blackberry Torch 981 ... https://supportforums.blackberry.com/t5/BlackBerry-OS-Smartphones/... Hi. I took the battery out of my phone and when the phone re-booted I now can only see a white screen with the error 102 and states reload software.
  • How to Reload Blackberry Mobile Software - Snapguide snapguide.com > Technology > Explore
    • 3.5/5
    • 10 RATINGS
    • BY TAHANI ALGHAREEB
    i will teach you how to reload your blackberry soft ware when its got error 102 and not working by this steps. all you ... How to Reload Blackberry Mobile Software
  • JVM Error 102 on your BlackBerry? Try this solution BEFORE ... crackberry.com > ... > Classic > Z30 > Z10 > Q10 > Leap > OS 10.3.2 Video embedded · JVM Error 102 on your BlackBerry? Try this solution ... JVM Error 102 on your BlackBerry? Try this solution BEFORE wiping! ... "Error 102. Reload Software ...
  • Terpecahkan: Curve 9360 Error 102 (Reload software ... forumdukungan.blackberry.com/...Error-102-Reload-software/td-p/258111 Terpecahkan: Dear all, Saya newbie disini, BB saya curve 9360, sudah mati 5 hari dengan error 102 (reload software). Sudah coba ikut instruksi dari
  • How to fix an error 102 reload software blackberry torch ... www.askmefast.com > ... > Error How to fix an error 102 reload software blackberry torch 9810? ... How can I fix reload error 102 on blackberry torch 9810? Comment. Reply. Report.
  • ERROR 102 www.blackberryos.com/general-blackberry-issues/38452-error-102-a.html
    • 2 POSTS
    • FIRST POST: 2013-08-12
    2013-08-12 · how do i reload software on a bb 9360?? ... Join Date Dec 2010 Location Gainesville, FL PIN Jarmeling Device Passport OS 10.3.2.2134
  • May 20, 2016 | Cell Phones
    My blackberry keep sayin jvm error 102
    If you get "JVM Error 102" when starting your Blackberry, read this before you wipe everything!!
    I had spent hours searching for a solution to this problem (I even went to my service provider) and all I could find was that I would have to wipe the contents of my phone and start all over again -- tough luck if I didn't have backups for my contacts, appointments, program data, etc.
    What it comes down to is that the JVM 102 error means that a .cod file on your phone seems to be corrupt, so the phone refuses to load it. Why wipe everything for one bad file? You might not need to!
    Follow these steps:
    1. Download JL_Cmder
    2. Connect your phone to your PC using the USB cable that came with it.
    3. Run JL_Cmder and select option 2 (event log)
    4. Scroll to the bottom of the log and look for "JVM Error 102." The line before it should tell you exactly what file is causing the error. It might look something like this. Save the file name; you will need it later.
    5. Go to Start > Run, and type "cmd" then press Enter.
    6. Change directory to the JL_Cmder installation folder.
      e.g., type: cd "C:\Program Files\JL_Cmder\" and press enter
    7. Type the following command to remove the offending file:
      javaloader.exe -u erase -f FILENAME
      where FILENAME is the name of the .cod file.
    8. Disconnect your phone from your PC and restart it.
    This might not be a permanent solution, but it should at least let you boot up your Blackberry so that you can back up all your data before reinstalling everything.
    Jul 24, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
    I have a blackberry 8330 when i put on the phone . theres a white screen that says jvm error 102 reset
    i have a blackberry 8330 when i put on the phone . theres a white screen that says jvm error 102 reset
    Dec 27, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
    Jvm error 102 on my 8230 bb pearl?
    please go to these link if you want to perform this yourself: but please be sure to follow the instructions STRICTLY
    http://supportforums.blackberry.com/t5/BlackBerry-Pearl-BlackBerry-8100/JVM-ERROR-545/m-p/71174
    OR if you cant or dont want to do the steps or just want professional help, go to the nearest authorized balckberry shops, or from where you bought the phone.
    Aug 18, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
    How to reset if JVM error 102 is hown on the
    Try to replace the firmware / system software of your BlackBerry Boild 9700 to fix your initialization errors. The latest BlackBerry Bold 9700 system software is available through here.
    Jan 21, 2010 | RIM BlackBerry Bold 9700 Smartphone
    What does JUM error 102 mean on my blackberry?
    1. According to rim, the jvm 102 error is caused by a hardware issue....(a suspected 3rd party chip in the ptn)....simply loading hh software is a temp fix. it WILL reoccur again and again, sometimes in only days.
    take it to service and repair, once verified that this is the jvm 102 error, they (the s&r dealer) are supposed to give you a refurbished or new ptn. if they have to ship one to you it is supposed to ship within 24 hours. they are also supposed to waive the normal exchange fee of $45.
    if they dont do this, call bb supprt from the store and the rep from tier 2 will talk to the dealer and set him straight for you....
    2. To fix this error, you will have to simply plug your BB into your PC and run the application loader.
    If it is asking you for a password, the old user may have set this via security settings. If you do not know the password, entering it 10 times incorrectly with reset the BB to factory defaults
    Sep 07, 2009 | RIM BlackBerry Pearl 8100
    JVM error 102 on my 8100 blackberry
    cause : software problem
    solu: reinstall software after taking backup.
    May 18, 2009 | RIM BlackBerry Pearl 8100
    JVM Error 102 Reset
    JVM Error 102 (death screen) is going to require that you do a complete reinstall of the BlackBerry OS. Here's a quick FIXYA for the JVM error > here
    ** If you still have issues completing this let we know and we can perhaps provide further assistance.
    Sep 25, 2008 | RIM BlackBerry 7250
    Jum error 102
    JUM error 102..how do i resolved this
    Sep 10, 2008 | RIM BlackBerry Pearl 8100
    Blackberry jvm error 102
    mt blackberry has a problem. it displaysjvm error 529
    Jul 15, 2008 | RIM BlackBerry 8700g Smartphone
    RIM BlackBerry  Pearl  8100 Logo
    189 people viewed this question
    Top RIM Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    David
    Martin Murray
    Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
