Question about Crossfire Car Audio & Video
Crossfire CF3 car speaker
10" 250 Watt 2'8 ohm
SOURCE: 1000 watt amp sony xplod
how do you have your system hooked? What speakers do you have? There is a lot more too it then just wattage.
Posted on Mar 22, 2008
SOURCE: Cobra radar detector speaker replacement
I called cobra support(777-889-3087) and it was around $6 plus shipping for a replacement speaker.
the correct phone number for cobra support is 773-889-3087 and can be found on their website.
Cobra was very courtious and I also got my replacement speaker for my XRS-9500.!
Posted on Nov 13, 2008
SOURCE: Subs and amp problem
2 subs and 1 amp
Posted on Nov 19, 2008
  • 347 Answers
SOURCE: replacement speaker
contact Whislter at 800-531-0004 to order a speaker for your 1660.
Posted on Nov 30, 2008
Just_Bobz
  • 448 Answers
SOURCE: How to hock up two 8 ohms speakers to bridged 90 watt Nad 209Amp?
Depends on output requirement (in ohms) on the amp. Any further questions, don't hesitate to ask. If this is helpful, please post as such. TY
Posted on Jan 24, 2009
I got 2 10in kicker comps and the rms on them each is 150 watts and can i hook them up to a 1000 watt sony xplod 2 channel amp and do i use both channel or just one or bridge them
1st thing is amps outputs have to be properly "loaded" this value is given in "ohms" if your amp says minimum speaker "loading" impedance is 4 ohms ( I suspect it does) then you may load that 1 channel down to only 4 ohms or amp will be damaged , most speakers are rated in ohm's Impedance (look for Greek symbol for omega) look for its rating somewhere on it doing the electrical formula math if you connect two 4 ohm speakers in parallel to one channel ( +=+ / -/- ) this divides down to 2 ohms (not good) but if you take same speakers and connect in series together (+to-/+to-) this gives you eight ohms (better) , the watts rating is a figure for you to determine the amount of power the speakers will take before failure , hence just because you connect 200 watt speakers to a 2000 watt amp is no indication that speaker will take all 2000 watts ( it will fail long before that point ) watts do ADD together like the above example two 4 ohm 250 watt speakers connected to one channel of amp in series will look like ONE 8 ohm 500 watt speaker to amp of course over 16 ohms load speaker volume will greatly diminish and amps have max impedance loads for them as well although there not often published
this is why I love the old TUBE!!! amps they load all the way down to 2 ohms and go up as far as 32 ohms load with no problems , they sound better as well across the board as well
Sep 10, 2015 | Sony Car Audio & Video
Wiring a crossfire vr602 at 4ohm
OK what you are saying now is that your speakers are dual voice coil; models? 4 Ohms per Coil? I have always used single 4 Ohm Voice ciol speakers since amps are mostly based on 4 Ohm outputs. but you can get 8 Ohm dual voice coil subs also. With 8 Ohms per coil you can get 4 Ohms if you parallel the wires. What is best for you and will get you the most stable power and still will be in the specs of that amp is to run the amp in BRIDGED MODE running each subs voice coils in series with each other then run those 2 subs in parallel to the amplifier giving it a 4 Ohm load. So, your will have two sets of wires from your amp 1 for each speaker. Then you will take a short piece of wire that will connect the + to the - of each voice coil then hook up the wires from your amp to each sub What it will be is 4 Ohms + 4 Ohms = 8 Ohms per speaker the 8 Ohms in parallel each speaker to the Bridged amp output using just the + from one channel and the - from the other will give you a total of 4 ohms and power out put of 600 Watts so that ends up being 150 watts per voice coil or 300 watts each speaker
Apr 04, 2013 | Crossfire VR602 Car Audio Amplifier
Are sony xplod 1100 watt 10'' subs 2 ohm stable
No keep on trying end blow everry thing up, Buy some real subs.
Nov 29, 2012 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
What watt amp would be best for my 1100 watt 10 inch xplod?
I have a 1100 watt sony xplode the silver one 4 ohm rms 3 00 with a 3000 watt 400 rms pyle amp? 8 ohm
Sep 16, 2011 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
What is the watts
Hi.
The Jensen XS-1010 is a 450-Watt 10" (450W peak, 150W RMS ) Subwoofer.
Below the full technical specifications:
Tech Specs
Product Type - Car subwoofer driver
Dimensions (WxDxH) / Weight - Car subwoofer driver : 4.7 in Diameter 10.1 in
Dimensions - Diameter - 10.1 in
Enclosure Color - Blue
Localization - English
Speaker Type - Passive
Speaker Diameter - 10"
Nominal (RMS) Output Power - 150 Watt
Max (RMS) Output Power - 450 Watt
Response Bandwidth - 24 - 1000 Hz
Input Impedance - 4 Ohm
Output Level (SPL) - 88 dB
Connectivity Technology - Wired
Speakers Included - Car subwoofer driver - 10" - 150 Watt - 24 - 1000 Hz - 4 Ohm - wired
Driver Details - Car subwoofer driver : 1 x subwoofer driver - 10" - polypropylene - Mid-Q
Diameter - 9 in
Depth - 4.4 in
Sep 07, 2011 | Jensen XS-1010 Car Subwoofer
Put new pa speakers in church 2 1000 watt tied 2gether and 2 300 watt. tied 2gether. the pa amp only has 250 watts with 6 mics connected and a cd player which plays fine. every time the mics are used if...
hi,
You have to check the ohms of the speakers all spekers should be 8 Ohms or above. if not it will overload the amplifier at high level. The minium ohms impedence of the amplifier is 4 ohms. If you connect two 8 ohms speakers together then the effective ohms will be 4 OHMS then the amp will handle the speakers. If you connect two 4 ohms spekers together then the effective ohms will be 2 Ohms, this will overload the amplifier. You will be able to connect two 8 ohms speaker to left channel or right channel of the amplifier. Check the speaker spesifiction to know its ohms. Make sure all the speakers have an impedence of 8 OHMS or above
OK
Aug 19, 2011 | Radio Shack 250 Watt PA Amplifier...
I hooked up a 2-Ohm dual voice coil 800 watt max 12" Kicker CVR subwoofer and 4-Ohm single voice coil 1000 watt max 12" Kenwood KFC subwoofer to 1000 watt Kenwood Ampilifer. After hooking it up, the Kicker...
off the same amp? you have two way different sounding speakers man. you can buy 2 identical speakers from the same company and brand and series and they will play differently every time. you have 2 speakers with nothing in common so you will hear a difference and maybe interference because of the different ohm levels.
Apr 14, 2010 | Kicker CVR12 Car Subwoofer
I need to know the ohm rating for the speaker in a
Judging from the "10D", that most likely means 10 watts. 6.5 inch speaker, probably 8 ohms. Most amps of this nature have 8-Ohm speakers.
Their 12-watt and 15 watt amp have a 6.5". Their 20 watt amp has an 8". The 80 watt has a 12".
Hope this helps.
Mar 28, 2010 | Peavey Pv 2600 Power Amplifier
I hooked up 2channel 500 watt amplifer and 1200 watt 300 rms subwoofer now the protection light comes on when i turn up volume
your speakers rating is too low for your amplifier. 300 watts RMS means the speaker can operate on an average of 300 Watts continuously. the 1200 watt rating is peak wattage input and meant for intermittent intervals only, a like a bass drum beat count. also , your speaker impedance must match your amplifier impedance or the speaker must be a higher impedance than the amplifier. Never lower than the amplifier's impedance output rating. If The amplifier is rated into an 8 ohm load, your speaker must be 8 ohms or higher. in other words you cannot use a 4 ohm speaker or you will damage the amplifier .
Mar 14, 2010 | Car Audio & Video
SHOULD I GO AHEAD AND BUY A 400 WATT AMP?
All amps aren't created equal. More exspense amps put out "cleaner" power. You need to know what the RMS power rating is for the amp at 8 ohms and 4 ohms. Also, is the speaker an 8 or 4 ohm speaker? How you wire a speaker or speakers (series or paralell) can change the ohms (resistence) which will change the power put out of the amp. Also, I'm assuming you are setting it up in mono?
Jun 22, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
Car Audio & Video Logo
96 people viewed this question
Top Crossfire Car Audio & Video Experts
xxxxxx xxx
Rommel Balcita
Are you a Crossfire Car Audio and Video Expert? Answer questions, earn points and help others
