Question about Swatch Irony watch
How to remove the front glass of my swatch irony
4 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: Swatch Irony Aluminium instruction manual needed
hELLO THERE
please go to www.swatch.com and look for you brand and type there will be a online manual that you can use and download and print if needed ok?
best regards mike
Posted on Aug 05, 2009
mcdevito75
  • 1970 Answers
SOURCE: Cracked glass crystal on swatch irony stainless.
mcdevito75 here, Best Bet, Look for a small watch repair shop in your area, crystal may not be able to be replaced as some Swatches are a 1 piece unit.
Posted on Jun 29, 2010
mcdevito75
  • 1970 Answers
SOURCE: Swatch Irony Battery replacement will not work
mcdevito75 here, I am thinking your watch ran fine before the battery change. It sounds like the new battery is not makeing good enough contact, you can try, removeing the battery and cleaning the contacts in the watch carefully with a Q tip, dip the Q tip in anything containing alcohol cologne, rubbing alcohol, perfume wet the Q tip good, then sqeeze most out of the Q tip as not too saturate the battery contacts, also clean the battery itself, the oil on your fingers could give it a poor contact on the watch. The stop watch section doesn"t take as much battery power as the second hand. You may also be able to jump start your watch also, You"ll need a needle and a magnifier glass, With the back off your watch, right in the middle of the movement, just below where the stem (winder) goes, you"ll just see part of a little gear, this is the hour hand gear, see if you can gently move that gear just a fraction, place the needle between the teeth of the gear and try to move it as gentle as possible then se if the gear will move on it"s own., be very carefull with the movement. Swatch watches are collectables. If you don"t feel comfortable doing the above, look for a small watch repair shop in your area for help.
Posted on Jul 17, 2010
Chron startstop button stuck
put a spot of WD40 down the sides of the button then try pull and pushing with tweezers
Mar 27, 2015 | Swatch Irony Chrono #YOS414G Watch for Men
Tip
SWATCH - IRONY CHRONO / DIAPHANE CHRONO settings
Follow this link and see how to set your IRONY/DIAPHANE CHRONO watch:
http://www.swatch.com/templates/zz_en/pdf/manuals/irony_diaphane_chrono.pdf
on Aug 04, 2010 | Watches
I have a swatch irony chrono, but when I stop the stop-watch and push the bottom button, the sweep hand ends up at the 11 o'clock and not the 12 position. My quartz Parnis does this, and its driving me...
Assuming the mechanics work ok (thay all do 360 degree turns) it's just a calibration issue: download from SWATCH support a PDf which describes how to zero the watch hands, it's simple as taking the crown out to 3rd step, the pushing the buttons repectively till they point 12 direction. Exact details in the PDF.
Dec 11, 2010 | Swatch Irony Chrono #YOS414G Watch for Men
Suddenly its stops so i bought a new battery but still it wouldn't work even with a new battery
You are not in luck - Irony watches are not made to be serviceable and therefor you will have to send it back to Swatch or one of their dealers - hopefully it is under warranty.
Sep 20, 2010 | Swatch Irony watch
My Swatch Irony watch has recently been running slow. I thought it might be a low battery, but after a replacement, it still loses time (a few minutes each day). Any ideas?
Thank you for contacting Fixya,<br /> I would have the battery checked again. Sometimes batteries in stores can be past the extended life of battery. Otherwise could be a number of issues. Has it been around water? Dropped? Could need cleaning. In cases of most watches, like Swatch, the cost to have repaired may exceed the watch. <br /> You can contact Swatch at:<br /> <a href="http://www.swatch.com/zz_en/shop.html">http://www.swatch.com/zz_en/shop.html</a>
Aug 24, 2010 | Swatch Irony watch
Jul 17, 2010 | Swatch Irony watch
Cracked glass crystal on swatch irony stainless. How do I replace it
Jun 29, 2010 | Swatch Once again
hELLO THERE
best regards mike
Aug 05, 2009 | Swatch Irony watch
Swatch Irony watch Logo
2,126 people viewed this question
Top Swatch Watches Experts
Ansel Alberto
Ansel Alberto
Tom Chichester
Are you a Swatch Watch Expert? Answer questions, earn points and help others
