Question about JVC TH-S8 System
Jvc ps-pws8 cable problem
WHERE CAN I BUY THIS CABLE BECAUSE MY SUBWOOFER DOESN'T HAVE SOUND
killer_clown
  • 86 Answers
SOURCE: lost the cable that connect from the system to the subwoofer
any electronics store,Radio Shack,Best Buy, Circuit City... they should have a good selection, if you got a best buy - its more recommended they have Whole selection on Home theater systems.
Posted on Oct 16, 2008
drumbanger
  • 1199 Answers
SOURCE: speaker wire to coaxial cable
Yes ! all you have to do is go to radio shack and tell them you want a coaxil to RCA adapter (screw coaxial into wallplate and plug RCA end into sub and your all set!)
Please rate answers and help keep this site FREE!
Thank You
Posted on Dec 28, 2008
Taisha
  • 44 Answers
SOURCE: usb cable
if your unable to find the website that offer the parts for you camcorder the JVC toll free service line can help direct you at 1-800-882-2345
Posted on Jan 01, 2009
  • 24 Answers
SOURCE: Connecting Powered Subwoofer to a Receiver
you will need a line-level converter to use this subwoofer- it is a rectangular-shaped box with wires coming out on one end and red-and-white RCA plugs one the other. The end with the wires coming out will hook to the receiver, and the other end will need to plug into the sub.
Posted on Feb 21, 2009
etirbynnor
  • 655 Answers
SOURCE: Connecting a subwoofer to JVC KW AVX800
Hello pmdharan, It sounds like the subwoofer is not turned ON. Go to MENU ITEM > SPEAKER SIZE >SW (subwoofer) and select ON. Hope this helps.
Posted on Jun 06, 2009
I have a jvc th-m606 receiver and I don't have a subwoofer for it, is there a different way for me to get audio output or a different subwoofer I can use?
You would have to make a cable that goes from the 8 pin mini din of the jvc unit to each individual speaker. A wiring diagram can be found online each pin on your 8 pin goes to a speaker , and one is for power. Find a wiring diagram and find a cheap electric store that can make the cable for you. I had the same problem...
Aug 10, 2012 | JVC TH-M606 System
I have a JVC surround system, I have power to both the DVD player and the Subwoofer but no sound. Wheni plug in earphones to the dvd player there is sound but nothing when unplugged. Could it be the S
You must have an external cable connection from the DVD audio output to the surround DVD input. As well there should be an output from the surround marked subwoofer. Connect them with the proper cable
Apr 04, 2012 | JVC TH-S8 System
Whats a control jack on a sony SS-WG450 plug into if i'm hooking it to a JVC reciever?
That subwoofer is included in the MHC-GX450 system. I have the amp/CD/radio unit. but not the subwoofer. The control cable connects the LED on the Sub to the main unit. When the main unit detects this connection to the LED it switches on its internal subwoofer amp to drive the subwoofer.
Does the JVC receiver use a "control" circuit through its external subwoofer unit to signal that it is connected to the subwoofer? If not, you do not need to use the control jack on the
SS-WG450 to connect to the JVC receiver. Connecting the Sony subwoofer to a subwoofer output on the JVC unit may be enough. Do check the impedance required by your JVC receiver. Sony lists the SS-WG450 as having a Nominal impedance of 6 Ohms. Is this high enough for the JVC unit?
Feb 03, 2012 | Sony MHC-GX450 CD Shelf System
WHERE CAN I BUY A SP PWM505 CABLE THAT GOES FROM MY RECEIVER TO THE SUBWOOFER? ITS A HOME THEATER
  • Here is a list of cables for your unit from Crutchfield's.
  • If your looking for the s pin DIN cable from the sub you can get that anywhere. The 8 pin DIN is a standard cord the same across the board. Here are a couple to choose from.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Oct 11, 2011 | JVC TH-M505 System
I CANT FIND A SP PWM505 CABLE
Regards, Tony
Trying to get sound from a coaxial cable plugging into a LG flat screen. The Tv has no Audio out puts... Only has a optical digital cable out in the back, but my stereo is older and is a JVC RX-400.. Is...
No.
Where does the TV sound REALLY originate? If it's a cable box, THAT is the same as a real audio device and it will have analog audio outputs at the very least.
Nothing is ever gained by routing audio or video through a device that doesn't use or improve it.
May 28, 2011 | Technics SC-DV290 System
JVC - Problem connecting a Powered Subwoofer to a Receiver
Have you set speaker setup configuration to SUBWOOFER YES? Also check SUBWOOFER OUT ON/OFF button on the front panel.
Feb 20, 2009 | Pioneer VSX-D511 Receiver
No sound out of subwoofer
Connection from receiver subwoofer output jack RCA plug male go into your powered subwoofer low level input with other end of cable, then you need to select Subwoofer YES/NO on the JVC receiver speaker setup menu option, select YES if this is a powered subwoofer you are using, should power up the subwoofer, may have to adjust a test tone balance for multi speaker output also, try trimming up on the subwoofer channel to initiate the signal on if the sub has an auto-on feature.
Feb 07, 2009 | JVC RX-5020VBK Receiver
Lost the cable that connect from the system to the subwoofer
Oct 16, 2008 | JVC TH-C5 System
Subwoofer jack not working
Try using another cable. Such as a spare Component cable. As a general rule if the cable is large in diameter it will do the job. You dont have to buy a Woofer cable specifically, as stated above a Component cable will be more than enough.
Jan 02, 2008 | JVC TH-A35 System
JVC TH-S8 System Logo
148 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
