Processing File on a KIP 3000
We have a file that is processing on our KIP 3000..but it appears to be "stuck"...we cannot delete it but it is not actually processing. We had a paper jam, and somehow in the process of clearing the jam, the file stopped processing, but can't be cleared. Any ideas how to get it out of the queue...we've deleted all the other jobs that we had queued up, turned the machine off, unplugged, etc...no luck. Thanks for any help you can give.
dg9dotorg
  • 151 Answers
SOURCE: HP Deskjet 3845 print queue not clearing
Have you tried going to safe mode, turning off the printer and manually opening it at the control panel>printers... try and delete or cancel prinitng at these settings...
Posted on Dec 09, 2007
nitinbabbar
  • 55 Answers
SOURCE: wont print
u better uninstall n reinstall the driver
Posted on Jan 23, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: hp laserjet 4250
This happens when the printer is printing duplex job. i.e. trying to print the other side of the page.
However check the functionality of the printer by performing Paper path test.
This would help us to know whether the printer as a stand alone ... is fine or not.
From the control panel of the printer, scroll to Diagnostic > paper path test.
Select the following in sequence.
Source: All trays
Copies: 10
Duplex: ON
Print Test Page
Check if you get the same error.
If yes, upgrade teh firmware of the printer.
Let me know the end result. We still have more depending on the above test.
- Nikhil
Posted on Nov 04, 2008
leroyal
  • 2120 Answers
SOURCE: HP Laserjet 4050 hangs on processing job
Unplug printer cable.
turn off
turn back on and wait for READY
turn off
connect printer cable
turn on
Posted on Jan 05, 2009
  • 62 Answers
SOURCE: printer document in queue will not delete
1. First, try turning printer off and on.
2. Next, on the computer side, this is how you manually clear the printer queue.
1. Go to Start, Control Panel and Administrative Tools. Double click on Services icon.
2. Scroll down to the Print Spooler service and right click on itand select Stop. In order to do this, you need to be logged in asAdministrator. At this point, no one will be able to print anything onany of the printers that are being hosted on this server.
3. Next you need to go to the following directory: C:WINDOWSSystem32spoolPRINTERS.Delete all the files in this folder. This will clear all print queues(it’s a good idea to first make sure there are no other print jobsbeing processed on any of the other printers on the server becausedoing this step will delete those jobs also)
4. Now you can go back to the Services console and right-click and choose Start for the Print Spooler service!
You can also go to a command prompt and type net stop spooler or net start spooler to start and stop the service.
I hope this helps. If you have more questions, let me know.
Posted on Jan 09, 2009
71:06 error code
hello,
Description:
Out of Memory problem. This Error Code only appears in HP DesignJets 800 Series, or in the HP DesignJet 500 Series with an
HP-GL/2 card installed, when processing either a PostScript or HPGL/2 file.
Corrective Action: Try the following:
Check the amount of RAM in the Printer using the Front Panel
(use the Printer Information utility aPage 4-27). If necessary,install more memory into the Formatter.
If the problem continues, try processing the file in the PC instead of the Printer (select Avoid out of memory in Advanced options in the Driver).
hope this helps
Mar 03, 2015 | HP DESIGNJET 500 InkJet Plotter Printer
Tip
Epson Printers - Slow Printing Under Vista & Windows 7
I had been trying to resolve a slow printing problem for months. The client had an Epson printer and a Windows 7 iCore duo computer that slowed down to and absolute crawl while printing photographs.
Nothing seemed to work. Not clearing the drives of temporary files, or updating the drivers.
Then I ran a program called Process Monitor. I kept seeing the SPLWOW64.exe spike the CPU usage to 100%. The file it was processing was an Epson file called EPAUDF01.AUD.
After updating the Progam used for printing to a 64 it version, SPLWOWO64 went to 34%, but the system was still taking three minutes for each step of the printing process, loading, selecting size and selecting orientation.
When I did a search online under the Epson file name, I found out that this file is a temporary audit file and should be removed.
"Epson printers create an audit file called EPAUDF01.AUD in C:\ProgramData\Epson\Printer."
Once the file was deleted, printing was fast again.
Each time the printer is used, this file is created, but, it doesn't slow down. Somehow the old audit file got stuck in this folder and gummed up the works.
If your Epson is printing slow, fimd this file and delete it.
I created a shortcut to the folder on the desktop "just in case".
on Apr 16, 2010 | Office Equipment & Supplies
How to back iertutil.dll when i delete from the recycle bin
you will have to install some software
http://download.cnet.com/easeus-deleted-file-recovery/3000-2248_4-10867160.html
EASEUS Deleted File Recovery is a powerful and free file undeletion solution for Windows 2000, XP, 2003, Vista, 2008, Windows 7. It is capable to recover lost files even after a deletion or even when recycle bin has been emptied. It can undelete files on any valid logical disks visible by operation system. In the case of damaged disk volume or partition, please use EASEUS Data Recovery Wizard. EASEUS Deleted File Recovery is an easy-to-use program with a Graphical User Interface without technical skill requirement through the whole recovery process. Simply launch the software, specify the disk where lost data located, click "Next" button, all the deleted files will be listed. Bonus its free
Hope this helps
Jul 01, 2012 | Computers & Internet
I have no idea how this file appeared onmy EXT HD, but I want it gone. I am running Windows XP Home Edition on my Laptop. When I try to delete the file from my EXT HD, the belwo error message...
I would recommend shutting down and restarting your computer to make sure that no instance of this file is up or running. You can also check the status of this file to see if it is in use by pressing ctl + alt + del. This should bring up your task manager, look through the processes and see if this file is being used, and if it is you can right click on the file and select "end Process", or "end process tree". If it does not appear here, or you still can not delete the file from this point, you can download a tool called Unlocker. This tool does what it's name specifies. Once downloaded you can delete the file, and if there is an issue deleting it, a window will pop up asking what you want to do, select delete and the file should be able to be accessed for deletion! Hope this helps
Sep 21, 2011 | Microsoft Windows XP Home Edition
I got prob on when virus attack my laptop my assignment file has corrupt have any solution?
Have you removed the virus from your computer? You can read my tech article on removing viruses by clicking here. There is a chance that if the file itself was infected, and the virus is removed, the file maybe deleted.
If you are using a Word processing program you can see if it saved an older copy of the file, or maybe you have a backup. These would be your only options at this point.
Regards,
G33k
Jun 24, 2011 | Dell Vostro 200 PC Desktop
When i right clich any file send to option its hanging
Change the view of your files to details, as this will use less processing power. At the moment your laptop is trying to load all the thumnails and then calculate copying information.
Your timely rating of this soloution is much appriciated.
Thanks
Nov 01, 2010 | Computers & Internet
Computer does not recoznise images file
.Nef is Nikon's RAW image identifier. See if there's an update for iPhoto at Mac website. Perhaps your camera (if it's new) is not yet set up to upload to iPhoto. You didn't indicate what camera you're using.
Sep 25, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Kip 3000 plotter
voltage error 031-034 on the kip 3000
Jul 05, 2008 | Office Equipment & Supplies
Raw file quality not as good as jpeg
RAW quality will always be at least as good as JPEG quality. The reason your JPEGs are coming out sharper is that the camera is actually doing post-processing on the RAW data, performing sharpening, white balance, contrast and brightness adjustment, etc., before saving the JPEG. The RAW data, as the name implies, is taken straight from the sensor, without the sharpening and other post-processing applied to it.
May 04, 2008 | Konica Minolta DiMAGE A2 Digital Camera
847 people viewed this question
jasbo
jasbo
