Mouse problems my mouse stops working when i plug up things to any usb port
  • 749 Answers
Usually this happens whenthe software for the usb ports' controller is not as current as it should be.
check your computer manufacturers' website for and updated driver. USB 2.0 is what you are looking for. This can work in reverse also , if you are using a legacy USB device (mouse) and try to use USB 2.0 devices on the same controller it can cause problems as well. A new USB mouse is inexpensive, but always check the BIOS and make sure all USB ports are running and that the controller is enabled for them with current drivers.
If you post the computer make and model number i can be more specific with my advice.
Please post again if you need further assistance & thanks for using fixya..
Regards.
Posted on Oct 22, 2008
Hi, Ausus Laptop Gaming. Use to use Logitech wirelewss keyboard and mouse over 3 years no issue. Just today only the mouse stop working, change battery, restart comp., not even the laptop mousepad...
Make sure your mouse and keyboard are close to the receiver (the thing you plug into a usb port). Also make sure you plug the receiver into another usb port because maybe some of those ports are incompatible with the receiver or some ports may be failing. Last, make sure you install the driver (program that came on the cd for your equipment) on the computer.
Aug 28, 2011 | ASUS Eee PC 900HD Netbook
My usb ports suddenly stop working...i plug and unplug my mouse and it works for seconds...then again stops...and again and again and again the same thing...
make sure the battery is good ((has full charge))also you make sure the usb device for the mouse is inserted correctly into the usb port (if applicable) or if its a lead
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable)) if this fails to fix the problem you could try it in safe mode
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x right click to update driver
if your computer came with a motherboard disk the driver could be on it
hope this helps
Aug 04, 2011 | ASUS M2N-Plus SLI Vista Edition...
Suddenly my mouse stopped working and the red light stop on it as well. What shall I do?
dear mario
it seems to be a problem with the mouse cable.
shutdown your computer and remove the mouse cable and replug the mouse again.
now start your computer and see is it working now
if no , then if you have a USB mouse try using it on another USB port
else you have to purchase a new mouse and plug it in.
thanks
Gagan
Mar 17, 2011 | Ideazon Reaper ZMS 1000 Mouse
Ok i have this mouse that does not work when i plug it into the usb port. the mouse dosent light up or any thing... what do i do?
First thing to do is to determine which one is at fault : is it the mouse, or the other way around?
Here's how :
  • Try another (known working) USB port
  • Try the mouse onto another known working computer
  • Try another known working mouse
  • Try another known working USB device (flash drive, etc) on USB port
Typically, the mouse needs replacement if it still does not work with another known good usb port or computer. If it's the other way around, then you may have USB port issues with your system.
Thank you for using Fixya.
Feb 20, 2011 | Computers & Internet
Spyder mouse won't work
I had a similar problem. I corrected by performing a manual connect as listed in the manual that came with the mouse.
Manual reconnect:
1. Plug in the receiver.
2. Turn on the mouse.
3. Press the button on the receiver.
4. Press the connect button on the mouse once within five seconds of pressing the button on the receiver.
This worked for me, and the mouse has worked fine since.
If this doesn't work. The manual suggested taking the batteries out of the mouse for 20 seconds and unplugging the receiver, then repeat the steps above.
If that doesn't work. reboot the computer and repeat the steps above.
Hope this helps.
Jul 21, 2009 | AVENUES The SPYDER SwissGear Wireless...
Any device connected through the usb ports causes the computer to freeze. I've reloaded the O.S and other drivers but it still does the same thing.
the best way is not to use usb mouse because 85% problems created by usb mouse.
if you want to use usb mouse and other things the good way is to buy a 4-port hub and plug the usb mouse in it and other things. and hope it will work for you
Mar 23, 2009 | Compaq Presario M2000 Notebook
I cant get any mouse to work on my dell laptop.
see the very first thing is that what u can try is that try and connect the same mouse that u had and that had worked and if works then the prob is with the mouse that u have right now and if that also doesnt work then the usb port on the laptop has gone bad and u need to replace the motherboard of the computer but before replacing the motherboard try and connect some other usb device on the same usb port.........
Jan 25, 2009 | KEIO PS2 Optical Scroll Mouse
Wireless mouse and usb game controller
It is faulty. Something internal is broken. I feel the only way to remedy this is replacement, sorry. I have seen this many times.
Oct 24, 2008 | Toshiba Satellite M45-S165 Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
