Question about Epson DLQ 3500 Matrix Printer
How to set ip address for epson dot matrix printers
How to remove the ip address,for dot matrix printer?
Posted on Feb 20, 2013
Niteesh
  • 65 Answers
SOURCE: Epson LQ-1050 Matrix Printer Problem
1. spread som lubricant on printers rod, in which head moves.
2. change your data cable, or remove it & connect it properly.
Posted on Feb 23, 2008
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Posted on Nov 24, 2008
  • 5 Answers
SOURCE: EPSON LQ-680 DOT MATRIX PRINTER
problem with detector cable or detector sensor
Posted on Jul 01, 2009
SOURCE: all LEDs of the of epson lq 1150 dot matrix
Head adjustment on Printer Epson LQ-1150II
Posted on Sep 23, 2010
muntejaya
  • 10421 Answers
SOURCE: Epson LX 300 Dot Matrix Printer driver for Mac
Please get it here : www.epson.co.id/epson/drivers/driver_download.htm
www.printcountry.com/drivers/EPSON_DRIVERS.asp
Jay wgft
Posted on Feb 12, 2011
Dot matrix printer
Panasonic and Epson are two different companies. If you want to know specific differences between two particular printer models, you'll need to specify the models.
Jul 24, 2013 | Computers & Internet
Tip
EPSON Impact Printers on a Mac
Connection Type : USB or TCP/IP
Driver : EPSON 9-pin or 24-pin Series 1.3
(resident CUPS / PPD driver - provided by Apple)
(no official EPSON driver)
>USB direct connection - check System Profiler-> under USB connection
>Got to Print & Fax and add the printer using the above driver
>TCP/IP connection - LAN set-up for printer configuration
>download EPSONNet Config Utility from http://support.epson.com
>run app and it will locate the printer regardless of IP address
>config to taste - default user/pass (it's blank, just hit OK button)
*the EPSONNet Config Utility is also available for Windows
(it's a neat utility)
on Jun 15, 2008 | Epson DFX-9000 Matrix Printer
I have one Epson TMU220PD printer. I have to set its IP address. how can I do it. Also, i want to know its default IP. Thanks, Saket
switch on your printer while pressing feed button.printer will print some pages and u can read ip address of printer in printed page.Then add same ip range in ur computer.connect printer to pc by network cable.test ping command to printer ip address.if ping succes then open internet explorer, type printer ip address in address bar, press enter key..there u can set ip adress from tcp ip options.
Oct 23, 2010 | Epson TM-U220 Matrix Printer
Printer epson lx300 can't stop printing
You need to reset the board, all dot matrix have some kind of a chip set as well that mostly can be remove. Just make sure you are grounded, its a last resort that I normally do for dot matrix that can't seems to stop printing or the panel are always lights on.
Oct 04, 2010 | Epson LX-300 Matrix Printer
I need a driver of Epson Dot Matrix LX-300+ II Printer
Go to www.epson.com and select the tab drivers and support. Then Epson Dot Matrix select the device that you need the driver for and the operating system. Here is the link I believe contains the correct driver but I do not garantee you http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=75683&infoType=Downloads
May 20, 2010 | Epson Dot Matrix LX-300+ II Printer
How do I get the macaddress of the Epson LQ-300+II?
If the dot matrix printer does not have a built-in network card then it will not have a MAC address. Dot matrix printers are very old printers and I have not come accros any with built-in network card or print servers.
The dot matrix can be connected to a network print server and this will have a MAC address and a configurable IP address.
Oct 22, 2009 | Epson Dot Matrix LQ-300+II Printer
What is the IP Address for Epson TM- U220PD
If you have the same model, on the back of the printer next to the ethernet port is a little button/ hole. Push and hold that down for a couple seconds until it starts printing. It will print out the IP address. Manually assign your computer to have an IP address in the same range (I.E. if the printer says 192.168.1.23, set your computer to 192.168.1.29 with the same subnet mask, etc.). Plug a network cable from your computer directly into the printer. Then, you can change the settings.
Jun 19, 2009 | Epson TM-U220 Matrix Printer
Epson DLQ 3500 Matrix Printer Logo
168 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
