I need the network security key for name:skynet,security type:WPA2-PSK,radio type:802.11n,ssid:skynet
SOURCE: tryiing to set up a wireless printer
You'll probably need to log in to the router with a computer. Usually opening your internet browser, and typing http://192.168.0.1 or http://192.168.1.1 will bring up a router config page. You may need to do an internet search to find the default password if you haven't changed it. Once in, you'll find a wireless config page which will have all of this info.
Posted on Dec 21, 2008
  • 23 Answers
SOURCE: Icouldn't access the internet. Your help tam, via
Please go in to your router and change the wireless setting from WPA2-PSK to WEP. Ansd then try to connect your laptop.
To windows after you change setting to WEP
(XP bottom right hand side you have system tray in that you have a wireless sign click on it. It ask for the password which you will change put that password click connect)
For laptop also same in case it not work then
(window icon>control panel>network and sharing center>wireless connection>properties>put the password click connect (then it will check out the wireless signal after sometime you will'be able to connect).
Hope this will resolve your issue.
Posted on Oct 23, 2009
  • 10406 Answers
SOURCE: Can't get the Linksys Router's list of Network Security Settings
The router has a built-in web-server.
So, just connect your web-browser to that web-server,
select the correct page, and click PRINT.
Posted on Jan 01, 2010
Testimonial: "Need more info...Thank you."
  • 94 Answers
SOURCE: how do I change the
Open Internet Explorer > On the address bar type 192.168,1.1 > When prompted for Username and Password, type admin and password > Once the Netgear page is up > Click on Wireless Setup > Change the Security settings from WPA2-PSK to WPA2-TKIP > Save the chages.
Revert back if further queries.
Posted on Oct 21, 2010
Pensivecoder
  • 86 Answers
SOURCE: Setting up wireless printer Brother
Log in to the management console, if the settings have changed you will have to reset the router to the most basic settings then start it up again, do this by turning to the back of the router, most routers have a pin sized hole in the back, stick a pin down that hole and hold it steadily pushed down for 5 to 10 seconds, release and wait 5 to 10 seconds and try again, hope this helps..
Posted on Oct 25, 2010
Wifi networks password
Turn over router and check in the bottom default access IP address and then type that IP address in to your
browser. Then it shall ask you for ID and password. Enter `Admin` or `admin` as ID and `Password` or `password`
as password. You will see a web based setup opened in front of you. Go to the Wireless Lan settings and then you
will SSID so change the SSID and this would be your network`s name. Then go to subsection security and select
WPA2-PSK or simple WPA-PSK then enter your desired network key. Once done with all these things the click apply
and reboot if prompted.
Mar 03, 2012 | Linksys SPA-2102 NA Analog VoIP Adapter...
Tip
How to achieve 300 Mbps speed in N standard routers ?
To achieve 300 Mbps speed in N standard routers:
In order to achieve 300Mbps speed between router and your wireless computer you must have an N standard router from belkin and also the wireless adapter on our computer should be an N standard (802.11n).
If you fulfill the above criteria then you can follow these simple steps to achieve 300Mbps speed between your computer and router.
  • Connect any Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Open internet explorer / Firefox any of your web browser (chrome will not support).
  • In the address bar type the default gateway address of Belkin router 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
Step 1: Wi-Fi Protected Setup (WPS)
In the Belkin router Setup page, on your left hand side, you will have Wi-Fi Protected Setup (WPS) below WIRELESS. Click on Wi-Fi Protected Setup. If it prompts you for a login password, leave it blank and Click on Submit.WPS will be enabled by default. Change it to Disabled and Click on Apply Changes. It may or may not take some time to save the Information and brings you back to the same page.
Step 2: Security
Select Security found on left side of router setup page.Security mode will have the following options,
  • WPA / WPA2 (PSK)
  • 64-bit WEP
  • 128-bit WEP
  • Disabled
Now select this way.....
  • Select the security mode as WPA/WPA2.
  • Select the authentication type as WPA2.
  • Select the encryption type as AES.
Then you will be able to see the pre-shared key (PSK) or passphrase (PSK), in this box you need to type at-least 8 characters as the network password.
After typing the password you can verify the password by un-checking obscure PSK. Password is case sensitive. Once you are done check obscure PSK and Click on Apply Changes.
You need to enter the same password in your computer to get connected to your wireless network.
Step 3: Channel and SSID:
Once you are done with that select Channel and SSID found on the left side of RSP.
Change the Wireless Channel to 1 or 6 or 11 (these are the best non-overlapping channels for wireless networks).
Change the SSID to any name as you wish, this will be your wireless network name (I recommend you to use a single word of any length. It can have letters, numbers or combination of both).
Check whether the option Broadcast SSID is checked / enabled (it must be enabled).
Protected mode should be OFF.
Bandwidth should be selected as 20/40 or 20+40 MHz
Once you are done click on Apply Changes.
Now connect the computer to your wireless network.
It will be connected at a speed of 300Mbps.
click here to know how to connect to the wireless network....
on May 19, 2010 | Computers & Internet
Tip
Wireless Part Configuration of Belkin routers without CD
Wireless Part Configuration:
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Open internet explorer / Firefox / chrome or any of your default web browser.
In the Belkin router Setup page, on your left hand side, you may have Wi-Fi Protected Setup (WPS) below WIRELESS. If you have WPS then click on it. If it prompts you for a login password, leave it blank and Click on Submit.WPS will be Enabled by default. Change it to Disabled and Click on Apply Changes. It may or may not take some time to save the Information and brings you back to the same page.
Step 2: Security
  • WPA / WPA2 (PSK)
  • 64-bit WEP
  • 128-bit WEP
  • Disabled
Usage of above security modes for various devices:
  • WPA / WPA2 (PSK) ------for vista & windows7 computers
  • 64-bit WEP -------for windows XP, MAC, XBOX, Play Stations, Ipods, Ipads (recommended)
  • 128-bit WEP ------same as 64bitwep, but not recommended
  • Disabled------to disable the wireless security
Disabled: If you think there is no need for security for your Wireless network or if you are willing to make it as a hot-spot then you can select the option as Disabled and Click on Apply Changes.
WPA/WPA2: If you are selecting the Security type as WPA/WPA2 then you will be able to see the pre-shared key (PSK) or passphrase (PSK), in this box you need to type at-least 8 characters as the network password.After typing the password you can verify the password by un-checking obscure PSK. Password is case sensitive. Once you are done check obscure PSK and Click on Apply Changes.
64bitWEP: If you are selecting the Security type as 64bitWEP then you will be able to see the Key 1 with 5 empty boxes. You need to type 2 numbers in each boxes of Key 1. You can also use letters A-F along with numbers 0-9 to make your password more secure. Password is case sensitive. After filling those details click on Apply Changes directly. You must not type anything in Passphrase and click on generate. If you do so, it will generate a password automatically.The 10digit value which you entered in key 1 is the password for your wireless network.You need to enter the same password without any spaces in between in your computer to get connected to your wireless network.
128bitWEP: If you are selecting 128bit WEP, then you need to follow the same instructions as above but you need to enter 26characters in 13 empty boxes.
  • Once you are done with that, select Channel and SSID found on the left side of RSP.
  • Change the Wireless Channel to 1 or 6 or 11 (these are the best non- overlapping channels for wireless networks).
  • Change the SSID to any name as you wish, this will be your wireless network name (I recommend you to use a single word of any length. It can have letters, numbers or combination of both).
  • Check whether the option Broadcast SSID is checked / enabled (it must be enabled).
  • Once you are done click on Apply Changes.
Now the Router is configured for wireless devices.
Connecting your wireless computer to the wireless network:Make sure the wireless switch is turn on in the laptop, now look for the available wireless Networks in range, select your network name, enter the security key and get connected.
on May 05, 2010 | Computers & Internet
How do I set up a security password
Here's a video on how I did it on my F9K1003V1.
Aug 09, 2011 | Belkin Basic Wireless Router
How to set up my router
Turn over router and check in the bottom default access IP address and then type that IP address in to your browser. Then it shall ask you for ID and password. Enter `Admin` or `admin` as ID and `Password` or `password` as password. You will see a web based setup opened in front of you. Go to the Wireless Lan settings and then you will SSID so change the SSID and this would be your network`s name. Then go to subsection security and select WPA2-PSK or simple WPA-PSK then enter your desired network key. Once done with all these things the click apply and reboot if prompted.
Aug 01, 2011 | Linksys Cable Modem
How to install the linksys
_________________________
Jul 17, 2011 | Linksys Cable Modem
How do i set up security lock
Setup steps:
1. Connect the computer to one of the four LAN ports on the router.
2. Open a web browser on the computer.
3. In the address bar of the web browser, type http://192.168.2.1
4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
5. Click on Security in the left-hand column under the Wireless heading.
6. Use the drop-down menu and select "WPA/WPA2-Personal (PSK)".
7. Select either WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2 as your Authentication; doing this will set the Encryption Technique automatically.
8. Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length. Note: The PSK (Pre-Shared Key) is case-sensitive ("A" is different than "a").
a. Unchecking the Obscure PSK box will allow you to see the security key that has been typed.
9. Click the "Apply Changes" button to save the settings.
Any/all wireless computers that connect to this network will be required to have this Pre-Shared Key (password).
Feb 28, 2011 | Belkin F5D7234-4 Router
Hi i have installed my router over a year ago now but am wondering how i set up security as others in my area can pick up my network easily without any passwords and it is slowing my computer down thanks.
In general, you can follow the basic steps below.
I would recomend using WPA2 or WPA secutity over WEP. (as this is a stronger type of wireless security)
- Open a web browser on the computer.
- In the address bar of the web browser, type http://192.168.2.1 (default router ip address, you may have changed this)
- Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit. (if you have already set up a password to login to the router then enter it here)
- Click on Security in the left-hand column under the Wireless heading.
- Use the drop-down menu and select "WPA/WPA2-Personal (PSK)".
- Select either WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2 as your Authentication; doing this will set the Encryption Technique automatically.
- Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length. Note: The PSK (Pre-Shared Key) is case-sensitive ("A" is different than "a").
*NOTE* Unchecking the Obscure PSK box will allow you to see the security key that has been typed.
= Click the "Apply Changes" button to save the settings.
If you need assistance with how to re-configure your computers, then please provide the version of windows that you are using.
Basic steps are:
-Disable the current Wireless Connection
-Enable the Wireless Connection
-Search for available wireless networks (look for your SSID wireless network name)
-you will be prompted to enter in your PSK and then save your settings
Jan 03, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I need to secure my router. I had payed to have it set up when I was getting my computer fixed only to find out that my son could log on with out a password. How can I fix this.
To set up wireless router security, there are four main steps, which are the same for most routers. These are:
1) Login to your router, using a wired connection
2) Change the router login password
3) Change the network name (SSID)
4) Enable WPA encryption.
************DETAILS************
1) Login to your router, using a wired (Ethernet) connection.
Make sure you have a cabled connection to your router. Then open a web browser, and type the router’s IP address into the address bar. For example, this is http://192.168.0.1
If you log in successfully, you should then see the router configuration screen.
2) Change the router login password.
To change the router password, find a menu option such as Setup, Tools, Administration, Basic Settings, Management, or Utilities.
Set and confirm a new login password. Click ‘Save/Apply’ when finished.
3) Change the SSID (network name):
The SSID or Network Name is the name you see when you are looking for an ‘available wireless network’.
To access this setting, find a menu option such as Wireless, Wireless Security, Security, or perhaps Advanced Settings.
Change the SSID from the default, to anything you like. It is case sensitive, and you can use up to 32 letters – but do not use something that could identify you, or your location. Click ‘Save’ or ‘Apply’ when finished.
Find the Wireless Security or Wireless Encryption Options section - often in the same section as the SSID (eg for Netgear – it’s still in Wireless Settings).
You may have a number of encryption options. Select WPA-PSK or WPA2-PSK (good choices to start with).
You then need to enter a network key. The box to enter this may be labelled Network Key: it may also be labelled WPA-PSK, WPA Shared Key, PSK, Security key, Passphrase, Pre-shared key, Authentication key .
Note down your network key carefully. You will need this to connect wirelessly. Click ‘Apply/Save’ when finished.
That's it - you have done enough to secure your network, and can close the screen.
Apr 08, 2009 | SMC Barricade 7004VWBR Wireless Router
Problem securing belkin wireless g plus router
you must enter the WEP key because if type in the pass-phrase it won't connect(don't know why)
Jul 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
