Question about Kenwood Car Audio & Video
No plug for kenwood amp kac-920
Kac 920
These people are idiots i am having the same problem with my 1020 i cant find one anywhere i am about to just go to radio shack and buy the clips and some wire and just by-pass it i have been looking for a couple years now and even my friend that works at a car audio place can not find me one
Posted on Feb 13, 2012
night71
  • 328 Answers
SOURCE: kenwood manual
Here is a free manual, just download it.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=e73fb2d3135db11ba752b002abe6f643&q=Kenwood+KAC-748
Posted on Oct 30, 2007
jhall1793
  • 60 Answers
SOURCE: how to hook up kenwood kac-7204 1000watt amp
I found the manual & have pasted the url here for you. some things to keep in mind. according to the instruction manual this unit is rated @ 500W, not 1000W. Also to maximize the output you should use 2ohm speakers for stereo applications. Also make sure if you need to extend the power wire, use 10 gauge copper & make sure it's connected to the car battery thru a 60 amp fuse. Also make sure the ground is attached to a clean metal frame or body part by using a bolt & nut not merely a screw. Good luck. If you need additional assistance let me know.
http://inform3.kenwoodusa.com/manuals%5Ckac7204.pdf
peace-out
Posted on Jan 06, 2009
etirbynnor
  • 655 Answers
SOURCE: To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Posted on Apr 28, 2009
97F350diesel
  • 1326 Answers
SOURCE: i have a kenwood amp. kac-7285 dont turn on
Not much to solve this one. Either blown fuse if fuse is good and you have solid ground (check continuity), power and remote (use volt meter) your amp is no good!!!
Posted on Sep 14, 2009
  • 52 Answers
SOURCE: how to hook up a kenwood amp.kac-5204
All amps are basicly the same. It should be plain as day where the speakers connect to.
The 12V screw connects to the main power from battery, be sure to fuse that wire and use a proper size wire, thicker is better,I suggest at least 8gauge with 40amp fuse. The GND is ground and should connect to car metal, file paint for soild connection. The REM is remote and connects to the remote of headunit or if you have a stock deck to the acc of car found in wire harness of headunit. Plug in the RCA's to head unit, or get a converter to plug into speaker wires from car if you have a stock headunit.
Posted on Mar 24, 2010
What size amp is the kenwood KAC-9103d amp
im not sure what you mean by what size amp....whether you mean physical size or wattage (power) so I have provided a website link for all the specifications that you require..........
http://my.kenwood.com/Car_Entertainment/Power_Amplifiers/KAC-9103D
PLease vote if you liked this response....
Aug 20, 2010 | Kenwood KAC-9103D Car Audio Amplifier
I have a kenwood kac-9152d running a 10 inch rockford fosgate power t1 and the amp keeps going into protect but i have a smaller kenwood kac-8102d running on another t1 and i have no issues with it why...
either the wiring your running is short circuting,or the amp is shot, or the subwoofer is shot, try hooking the same speaker up to the other amp. along with the other speaker to the other amp, see if the same thing happens.
Feb 04, 2010 | Kenwood KAC-9152D Car Audio Amplifier
Leads for old kenwood car stereo amps
Hey wdalley69, I've got the KAC-8070. My setup has the crossover module for it.
Oct 27, 2009 | Kenwood Car Audio & Video
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
920 Watt Kenwood Amp wont power on
Connect the remote wire to an accessory wire on your stereo.
Jul 08, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Hello laurogleal,
Hope this helps.
Apr 28, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood KAC-8103D Power Amplifier wont turn on
it sounds to me like its burnt.but with some amps the screws that hold it in place have to be screwed into the car chassisfor grounding. be careful not to srewe into hidden wires.
Apr 14, 2009 | Kenwood Car Audio & Video
Connecting subwoofer to kac-7201 kenwood amp
from your sub connect one short piece of cable from + on one side to - on the other side using the same diameter cable as you are running to the sub from amp . this will leave you with + and - on opposite sides of speaker these will then run to the amp +to+ and - to- on the mono side of connetor which is one left + and one - right and the amp switched to bridged
Mar 22, 2009 | Kenwood KAC-7201 Car Audio Amplifier
My kenwood amp
you need to check your wiring and check your rca wires to see if they are giving your amp a signal to put out
Mar 11, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Car Audio & Video Logo
482 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
