Question about Acer TravelMate 5520 Notebook
Acer aspire 5520-5334 error oxooooc1f5
When i start my laptop it gives the error oxooooc1f5 software or hardware not installed properly and then goes to the blue screen.......pls help
  • JDTec
    JDTec May 11, 2010
    Is this Vista or XP?
    It happens alot on Vista unit, It is due to the MBR (Master Boot Record) being corrupt.
    Are you getting a Blue screen?
CS-Vicky ควาย
Posted on Nov 06, 2008
  • 70 Answers
From what I've read, this is a bug with Vista.
http://support.microsoft.com/kb/946084
Try the hotfix.
Posted on Oct 22, 2008
My netbook (Acer Aspire One Netbook ao531h) goes to blue screen on start-up it has an unmountable boot volume error, codes shown below: STOP 0x000000ED (0x86B5C470, 0xc0000006, 0x00000000, ...
Its the problem with hardware driver software. Please remove last installed software/hardware in your system. To remove software run system in safe mode by pressing F8 on system starting and select safe mode then remove last installed hardware by opening device manager or remove software by opening add remove program from the control panel.Then restart system.
Any problem came ask again new question
************************Please RATE it *******************
Apr 25, 2011 | Acer Aspire One Netbook AO531h-1729 10.1...
My volume control doesnt work.
The volume control of your computer is not accessible because the Sound Device Software is not properly installed.
Check the System Properties for Installed Device in your computer:
  1. From your Desktop Screen, click on Start Menu
  2. Choose, Run ( In Windows Vista, Start Menu > Accessories > Run )
  3. Type, sysdm.cpl ( to open the System Properties Windows)
  4. In System Properties choose the Hardware tab
  5. Click the Device Manager button
All Hardware Device are listed in the Device Manager.
Install the missing driver for sound device, refer the software from the CD driver of your laptop.
Alternative Software Driver is also available through the Acer Support Download Website.
( http://www.global.acer.com/support/download.htm )
In Service Support Page, select your location to proceed.
In the software driver downloads, it is important to select the right model of your laptop and the operating system you're using to avoid system errors and driver conflicts.
Feb 20, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have an Acer Extensa 4620 laptop that is giving problems
Try looking at this information from Microsoft regarding this issue. You may have an incompatible software driver that was installed when you upgraded or installed / reinstalled some software.
http://support.microsoft.com/?kbid=317445
Jan 06, 2010 | Acer Extensa 4620 Notebook
ACER 5570 won't load Windows XP keep getting error
Hello shannon_enns,
You might need to go to your BIOS first. When you power on your laptop, keep pressing F2.
Once you're on your BIOS, go to the hard drive & choose "Compatible" since you have Windows XP.
If you have Vista, you'll need to choose "Enhanced."
After that, you may need to reformat your laptop one more time.
Here's a guide on how you can reformat your laptop,
http://helpdesk.its.uiowa.edu/windows/instructions/reformat.htm
Hope this helps & best of luck!
Art Pena
Tech Support
Nov 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
My acer aspire 4710 is not getting started,and
This laptop needs to be serviced if its showing a hardware error. You did not go into detail on the error message so its hard to tell what diagnoses to give. I would call Acer directly and have the laptop repaired if its still under warrenty,
Any hardware error in a laptop can be complex so look into repair locally would be my best suggestion. Please do rate my solution as we strive for ratings- Thanks
Aug 19, 2009 | Computers & Internet
Laptop start up error
This error comes when there is memory issue .
Harddisk issue or RAM issue.
For that if you have windows recovery disk you need to run disk checking program
Most of this error comes becuase of hardddisk error.
Boot your computer with windows xp disk then enter in recovery console mode then type in prompt "chkdsk /r"
then press "y"
then it checks disk andf fix error if found any error on harddisk.
then you can boot your windows.
Thanks for using fixya.
Please rate my solution if it hleps.
Pls let me know if you need more assistanse.
Many Thanks .
Jul 24, 2009 | Acer Aspire 4315-2963 Notebook
Acer aspire 3680 "unmountable_boot_volume" (please help!!)
Contact Acer and they can send you the disk that came with that computer. Then you can run some commands. Let me know when you get the disk.
Have you tried safe mode by hitting the f8 key at start up?
Jul 05, 2008 | Acer Aspire 3680 Laptop
Acer 3680 will not boot up.
try to boot in safe mode, if you can then from there try to remove the latest software or hardware you install.
if you are unable to boot in safe mode, then try to repair or reinstall the os.
plz post your findings
Jun 06, 2008 | Acer Aspire 3680 Laptop
About sound in aspire 4520
dear friend
if u install a driver and it's not working and if u don't her any kind of sound then yr driver is not proper install first of all u chek device manager in coutrol panel then system then device manager and chek sound driver is install proper ( not showing yellow symbol show ) if it's show's then uninstall it and reinstall audio driver
try this one thanks for using fixya
Jo_chinmay
Apr 04, 2008 | Acer Aspire 5610-4648 Notebook
Acer TravelMate 5520 Notebook Logo
295 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
