Question about Philips Magnavox 51MP392H Rear Projection Television
Magnavox FP5210W103 Tv started popping when i turned it on the piture started flashing. I taken front off tv look and seen sparks at box left hand side the number on part was sanyo 220709-1 9436 thank steve
    President:
  • 3,130 Answers
Thats the flyback(high voltage transformer) Or the Focus/High Voltage distribution block. In ant case your shouldnt touch eather as there is enough Hi voltage there to kill you. Please seek out a pro to assist you in this repir. A tv set is not a place to experiment with. Good Luck
Posted on Jul 30, 2006
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums
    ths.gardenweb.com > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3
    www.consumeraffairs.com > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
    https://support.apple.com/en-us/HT200197
    Apple
Jan 28, 2016 | Televison & Video
Menu pops on and off for about a minute when i first turn the tv on
the self diadnostic program in the tv is going bad.. may be time to replace the tv or dont shut it off completely
Jan 21, 2014 | Samsung LNT4665F 46inch 1080p LCD HDTV
Have a Magnavox 37mf321d LCD TV, one day, went to turn it on, and the green power light came on, along with the screen (which just flashed), and then went off. Waited a few seconds and tried again, the...
Although a capacitor may look good, it may be weak or bad. Here is what you will have to do. Replace capacitor (location) 2074 which is a 25 volt 2200Mf at 105 degrees. Replace capacitor (location) 2081 which is a 35 volt 1200 Mf at 105 degrees. And you should change capacitor 2066 which is a 16 volt 10Mf at 105 degrees. Please be careful with the last cap mentioned. You can easily tear the PCB trace if you are not extremely careful. This should bring your TV back to life. Thanks for asking and show a few hands of support!
Dec 25, 2010 | Toymax Magnavox 37MF231D 37 in. LCD TV
I have a magnavox flat screen lcd tv. It says the model number is 26mf23id/37. A few weeks ago the switch that controls the outlet the TV was hooked up to was turned off while the TV was on, and since then...
Now,hook ur tv Air broscasting incommig tv signal.Give it power.Now,tv turn on have picture flashes few sec. than dies just have only sound left?Yes,than the long LCD inverter board is dead.The long LCD inverter board,help the LCD screen to get a baklight to get a picture.Tries websites like shopjimmy.com,Ebay,com to buy a refurbish LCD inverter board for the replacement.
Jul 29, 2010 | Audiovox Televison & Video
I have a 27" magnavox tv and it's on standby and i don't have the remote to turn it on is there any way i can get it to turn back on without the remote or can i get a a universal remote or anything please...
if there is any buttons on tv some tvs have cover over then on frount or side of any press ch.up or ch.down
is no buttons can be seen you can find remote on chylse hyde and son web site (CHS) tou will need make and model of tv
hope this helps
MERRY CHRISTMAS
Dec 14, 2009 | Philips Magnavox 27MS343S 27" TV
Describe how to replace bulb for magnavox hdtv #50ml6200d37
easy. pop off the front cover.. Start at the right edge. The front part that covers the speakers comes off as a complete cover. Then there is a square panel that must be removed on the left side front about three screws. once the panel is off there is three thumb screws .. loosen them.. they do not come out. then when they are loose pull on the panel handle and out comes the bulb unit. then follow the install instructions of the new bulb. Do not touch the bulb with your hands... It goes back the same way .. The exterior panel must be in place for the tv bulb to fire up..
Oct 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Can't receive pic and sound with converter box.
Connect the RF output of the Magnavox to the VHF/UHF (ANT) input at the back of the TV. Select channel 3 or 4 on the TV. An alternate is to connect the component output (red-white-yellow) to the Audio/Video In jacks at the front of the TV (the red or the white would be left unconnected) and use the TV/Video button on the remote to select that input.
Jul 08, 2009 | Toshiba 13A24 13" TV
TV will not turn on model aquos LC-46X20 Went away for a long weekend, did not turn power off left TV on stand by. Came back and power LED on front of TV is flashing and will not show any form of piture...
hello. here is something you can try , unplug the set and let it set. for about 10 mins. then plug it back and try tpo turn it on. hope this help's you. let me know "GOOD LUCK"
Jul 27, 2008 | Sharp Televison & Video
36 magnavox tv shuts off by itself
MAGNAVOX TV ONLY. 5-10 SECONDS AFTER TURN ON AUTO TURNS OFF-NO LIGHT STAYS ON-I AM FRUSTRATED BUT IT SEEMS LIKE THE OFF ON SWITCH JUST CLICKS BACK TO OFF-ALSO DOES SAME THING BY REMOTE
Jan 16, 2008 | Philips Magnavox MS3652S 36" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
146 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
