Question about Shure Distribution Shure PGX4 Wireless Diversity Receiver H6
SHURE PGX4 I PLUGED IT IN AND ALL THAT TURNS ON IS THE AUDIO LIGHT FLASHING RED
  • thervspa
    thervspa Feb 08, 2012
    how can I sync if the channel display wont come on period.? thank you
    Genius:
  • 1,212 Answers
Have you synchronized the microphones to the base yet?
If you do not have manuals. you can download them here:
http://www.shure.com/americas/support/user-guides/all-user-guides/index.htm?PageNumber=15
and http://www.shure.com/americas/support/user-guides/all-user-guides/index.htm?PageNumber=14
You essentially want all the "PGX" manuals in the language of your choice as they did not distinguish the spec sheets from the manuals in the list.
Posted on Feb 07, 2012
  • John McPherson Feb 08, 2012
    There are a couple possibilities if the microphone batteries were new and functional,
    1) Too much RF noise in the area that prevents the base from finding a clear channel.
    2) Base power supply related, the base may not be seeing adequate power. Might be the power supply itself, might be the mains power is inadequate. It might also be the power plug connections in the base itself- maybe they tore awy from the board enough to prevent adequate power flow to unit- which may be the case if the base was not unplugged from power supply when loaded in the transport case.
    3) The base may have an internal fault from a bad solder connection to a destroyed control IC. It might also be the transmitter/reviever board connector fell off.
All I get is a flashing red light, please help
We cannot help you with more information as to at least the make and model of whatever it is you're asking about and what you weredoing when what ever light you're asking about started flashing. Please re-post your question with the additional info.
Mar 25, 2016 | Music
How can i fix my zoom G2.1u red light flashing on screen?
if you are using batteries then, it is a sign that batteries are running low. just use DC or replace with new Batts
Dec 06, 2013 | Zoom G2 MultiEffects Guitar Pedal
Yamaha clavinova
If any jacks are connected to the output , unpluged it. And be shure that device pluged its own spakers.
Sep 14, 2013 | Music
Hi. I have a M-Audio FW2626 and it was by mistake pluged in a higher V tension, and now it doesn't work anymore. Perhaps I found the problem, but I need its Diagram Block. If you can help, I...
The external power supply is probably damaged and will need to be replaced. It appears to be a 12 volt DC, 3.5 amp, center positive unit. I would replace with a new one from the M-Audio parts supply as the ratings of this are far above standard universal units.
Sep 19, 2011 | M-Audio Maudio Profire 2626 Profire2626 In...
After we switch from the auto to another manual mixing board the volume on one of the mics is decreased dramatically. all other mics are not effected. both boards are linked and we have a toggle switch to...
Check the cables. If one lead of an XLR-XLR cable is shorted to ground, 6 DB gain is lost. You haven't really supplied enough information regarding cables and model of the manual mixer for us to help much. Do check that ALL of your audio interconnections are BALANCED lines either XLR to XLR or TRS cables. Grounding one side of a balanced line reduces gain 6 DB. Try swapping mic cables and channels to test where the problem is in the system.
Aug 31, 2011 | Shure Distribution Shure SCM810 8 Channel...
Lexicon Alpha got phantom?
The Lexicon Alpha does NOT have phantom power. The mic input expects a standard mic or a "self-powered" condensor mic. This means that you will neex external phantom power. There are power units available that use 9V batteries for this.
Dan
Sep 09, 2010 | Lexicon Alpha Personal Recording Studio
My tuner shows a green flashing light, the battery is new, even checked it with another one. No matter what i do it just shows a green flashing light. picking the strings for sounds makes no difference at...
Often, the flashing green light indicates that the tuner is NOT receiving a signal and is a warning that the tuner is turned on.
First thing is to check if you have normal output from the guitar from the pickup. If the output is normal, there MAY be a failure in the tuner.
ALSO, just because a battery is new doesn't mean the battery isn't depleted... either try another from a different batch or use a voltmeter to check it. I have seen people chasing their tails due to a brand new bad battery.
When you select the tuner does the audio OUT of the guitar cut off as it is supposed to?
Sep 03, 2010 | Washburn D10sbc Acoustic Guitar
No sound
You would NOT use a stereo cable to plug in your guitar.
The stereo cable would carry the battery voltage back to the amp and MAYBE cause the fuse to blow.
You use a MONO instrument cable for your guitar.
The ring connection is use to complete the circuit to turn on the battery in most guitars.
Replace the fuse ONCE and get the proper instrument cable (NOT consumer audio cable) for your guitar.
If fuse blows again, take amp to shop for service.
May 30, 2010 | Peavey Valveking Head
Pioneer DJM-400 mixer turns on, but channels aren't working
could be a few things , what have you tried to trouble shoot the problem ?
My steps would be ;
check all leads (even if you KNOW u pluged them in)
check the gain is set corectly .
check the line phono slectors are set to what ever you have you leads pluged into on the back of the mixer ( there is 4 red and white RCA plugs , 2 for phono,2 for line CDJs shold be using line )
if you are using digital cables to conect your CDJs , on the back on the mixer there is a small switch marked "CD or digital" make sure that is sleceted "digital " . if ur not using digital cables make sure it is on "CD" .
the info iv put here is based on the DJM-800 so your mixer my not have some of these featers as iv never used a 400 . hope this helps dued . check out www.djtutor.com for more tricks and tips . Pratices'N'enjoy !
Dec 28, 2008 | Pioneer DJm 400 Professional DJ Mixer
Shure Distribution Shure PGX4 Wireless Diversity Receiver H6 Logo
515 people viewed this question
Top Shure Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Shure Music Expert? Answer questions, earn points and help others
