Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
Officejet 6500 disassembly
Please, need manual to disassemble the printer and locate the battery
SOURCE: disassembly or assembly guide
I disassembled HP f380 myself without a manual.
Posted on Mar 07, 2009
  • 54 Answers
SOURCE: HB Officejet 6500 scan button not working
Follow these steps to perform a partial reset of your product.
  1. Unplug the power cord from the product, and wait 20 seconds.
  2. Press and hold # and 3 while plugging in the power cord to the product.
  3. Release the buttons after the product starts up. The product will now be reset to factory defaults.
Posted on Sep 05, 2009
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
Mhinhi
  • 10 Answers
SOURCE: HP Officejet 6500 will not print after sleep mode
Move the printer to a different location and keep it closer to the connected device (e.g. router) and away from large metal objects / other electromagnetic devices for stronger signal strength.
Posted on Mar 01, 2010
  • 145 Answers
SOURCE: HP Officejet 6500 E709 (new printer) will not
Hi ladarlak
There is no full feature driver for Windows 7 yet. Meanwhile HP have printed a workaround at http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01796879&lc=en&dlc=en&cc=us&lang=en&product=90764
Posted on May 09, 2010
Reseting ink 920 cartriges
Download the manual for HP 6500,
HP OfficeJet 6500 Wireless Manual.
It is clearly mentioned in it.
-Rate if it helped you.
Apr 10, 2010 | HP Officejet 6500 Wireless All-in-One...
Paper jam on a officejet 6500 wireless
Unplug the power cord and open the cover and remove all the cartridge and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
Feb 10, 2010 | HP Officejet 6500 Wireless All-in-One...
Need operating instructions for HP Officejet 6500 E709. How do you send a fax?
Hi:
You can go to www.hp.com Click on the support and drivers tab, type in the model of your HP officejet 6500, and you can download the entire manual for free.
Nov 10, 2009 | HP Officejet 6500 Wireless All-in-One...
Dismantle and remove battery officejet 5610
It would be extremely difficult to disassemble the printer, and the battery is usually not replaceable. Why did you want to replace it anyway? It should last the life of the printer.
Nov 30, 2008 | HP Officejet 5610 All-In-One InkJet...
Document Feeder Problem
There is no such manual for the HP OJ G85. Disassembly is not complicated. Just take your time.
Inkworks
866-381-0541
Sep 10, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
354 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
