Question about Samsung Televison & Video
Samsung ln32a330j1dxza has no color
Has barely any color colors showing up as blue, grey and gold/copper
jerryg50
  • 1667 Answers
SOURCE: Blue Shades
There may be a failure starting on the video or matrix driver boards. This has to be verified at the service center. The fix will be done by swapping in a new board to replace the failing one(s), and re-doing the factory setups to make sure that the default colour temperature and levels are correct.
I suggest that if the set is out of warranty ask for an estimate first.
Jerry G.
Posted on Apr 13, 2008
SOURCE: Loss of Color
Have two basic colors blue and yellow or green as the combination all other colors are grey. What are my options...The Boston Celtics Colors are Grey. All others colors are good.
Posted on Jun 16, 2008
Roshan89
  • 271 Answers
SOURCE: viewsonic n2750w 27" turn on the tv it gets 4 different colors
if you have a reset button (might be hidden)...hit dat
Posted on Dec 17, 2008
boltthedog
  • 24 Answers
SOURCE: Blue tint - is it our color wheel?
possibly your color wheel
Posted on Sep 19, 2009
SOURCE: My tv no longer shows the color red. No idea what
I have sound but my tv screen is black. Sometimes when I turn on the tv I get a picture but after 15 minutes or so the screen goes black again.
It's a 4 year old LCD.
Posted on Jan 05, 2010
How to hook up electrical? 220v single phase? What color wires on which connections of the plug?
Identify the prongs. If you have wired a 110-volt fixture or plug, then you are aware that the different prongs connect to different colors of wires. The same principle holds true for 220-volt plugs, and this is very important to keep from tripping the circuit breaker. A three-prong plug will connect to two colored wires that each supply 110 volts and a bare copper wire which is the ground. One of these colored wires will be black, while the other one should be red, white, or blue. The four-prong plugs connect to a black and a red wire that each supply 110 volts, a white neutral wire, and a bare copper ground wire.
Read more : http://www.ehow.com/how_6830969_wire-220_volt-ac-plug.html
How to Wire 220 Volt AC Plug eHow
Dec 16, 2015 | Ovens
I have a ccd color camera with a broken cable, the unmatched colors are red, white yellow, black and bare copper. the end line it needs to connect to has red, white, yellow, blue, green and bare copper,...
sorry partner you have a prob. no changing wires will ever work in the corder . try the shopping for systems that are compatible to the tv monitor hook up .. looks like a really nice camera too .
Aug 21, 2013 | Clover Corporation Home Security
Belling cooker d841 top oven
The US National Electrical Code only mandates white (or grey) for the neutral power conductor and bare copper, green, or green with yellow stripes for the protective ground. Power will generally be black or red. 3 phase power will have three colored lines, the first is generally black or brown, the second red or orange, and the third blue or yellow..
i,e,
Yellow/Green is Earth so 'E'. Brown is live so 'L', and Blue is neutral so 'N'.
May 08, 2012 | Belling XOU174 Electric Single Oven
Vga cable color code of 17" monitor of samsung SyncMaster can u send color code pichear
1 - Red
2 - Green
3 - Blue
4 - NC
5 - DDC Return
6 - GND (R)
7 - GND (G)
8 - GND (B)
9 - NC
10 - GND-Sync/Self raster
11 - NC
12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
The wire colours in the actual cable are:
Red (foil wrapped with 1 bare ground wire)
Green (foil wrapped with 1 bare ground wire)
Blue (foil wrapped with 1 bare ground wire)
Transparent (foil wrapped with 1 bare ground wire)
All the above go to the corresponding Gun Color, the Bare wire goes the one GND pin.
Purple
Yellow
Black
Orange
White
Bare braided outer ground wire. Combine ALL earths to a single point.
You will have to open up the unit, to see what colors are used for the 5 - DDC Return 10 - GND-Sync/Self raster 12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
Settings they are marked on the motherboard.
Aug 03, 2010 | SAMTRON 55V 15" CRT Monitor
Hello sir i am sasi from india pls tel me international color codes electrical wiring
Well colors can vary, but basically bare copper or green are grounds, white is the neutral wire (but it is powered in a switch loop, and when used in a switch loop it is taped with a piece of electrical tape to show it is powered). Black, red, blue, brown, and pretty much any other color except green and white can be a power wire (black red and blue are the most common colors used).
May 26, 2010 | General Electric GE ELECTRICAL TQD22200X2...
Wiring problem
yes that is right, color to color turn of breaker before touching wires. green and bare copper go together.
Nov 01, 2008 | Jenn-Air JED8430 Electric Cooktop
Samsung HLP5063W Tv
while replacing the color wheel you know you see two cords running from it the blue/white cord and that copper cord. if you replaced both the color wheel and lamp, then it could be that copper cord just switch it around i did that and now my tv works
Jul 15, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Loss of Color
Jan 24, 2008 | Maxent MX-26X3 Television
Televison & Video Logo
66 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
