SOURCE: my phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
SOURCE: my F480 doesn't ring when called
Go to call settings and cancel all the call settings information..
note: you will see call barring , call forwarding, call waiting options
just cancel all of them if it will not work, in the phone settings look for the answer call and change the settings there
SOURCE: Incoming calls ring 3 times
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
SOURCE: the problem is every incoming
Please check if any call divert or incoming call barring (found at settings menu) are actives .
