Looking for a LG Intellowasher WD8013F manual
I have just moved house. The drum of my washing machine was unrestrained and knocked a protruding component out of the circuit board. After trying to commence a cycle, the lights all just started flashing I have replaced the electronic board and now the washing machine seems to start through a cycle and then hangs up before the water valve opens (I think this is the first step?) I can hear clicks coming from the board so I presume some switch thing comes on, but I do not get a voltage at the inlet valve, and the machine panel lights all go out at this point, as though it has shut itself down. I have checked the interconnecting wires for other damage, but they all appear to be good. So now I am stumped! Can anyone suggest something to try? Regards Nigel
SOURCE: LG WF-764STP
Your problem might be the motor capacitor
Posted on Aug 31, 2007
  • 209 Answers
SOURCE: Washing machine not filling with water not washing but will empty and will spin
like the anchor idea?, no sorry, this does sound like the water is not getting to the machine, so, when you turn the machine on does it make a slight buzzing noise, if so the fault is no water in the pipes to the machine (from the house), if no buzzing check the solenoids with a multimeter for open circuit (removing the 2 wires first) oh and the plug obviously / replace solenoid if needed, i am sure this will cure your problem, if so rate me please, thank you
Posted on Sep 18, 2007
  • 1294 Answers
SOURCE: LG INTELLOWASHER STOPPED SPINNING
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 02, 2008
  • 38 Answers
SOURCE: Hotpoint WF321 during rinse and spin, will not go into full spin as machine keeps filling with water.
you should check your pressure switch hose for a pin hole or better still just replace the hose and it should sort your problem out good luck hamstel
Posted on Nov 05, 2008
wayneard
  • 1901 Answers
SOURCE: I need a manual for my (excellent) LG WD8013F Intellowasher front
Here is a link to LG's Support Site:
WD8013F Manual Page
This file is in .djvu format. You will need to install the Djvu Viewer if you do not have it installed. There is a link on the page to do so. Install the viewer and then go back and click on the manual link to open it.
Posted on Dec 03, 2008
Main power flicks off when my LG wd8013f starts
There is something grounded in your washing machine.
Jul 13, 2012 | LG Washing Machines
I need an operators manual for lg intellowasher model WD8013f
you can try and go to this webs site.appliancerepairplanet.vstore.ca and see if they can help you in this matter.shane
Dec 29, 2010 | Washing Machines
My LG 7kg frontloader intellowasher WD8013F is leaking from underneath and no water is going into the washing machine. Please help?
i removed the filter off the front of my lg intello washer to clean and now it keeps leaking water from the filter what have i done ?
Jul 12, 2010 | LG Washing Machines
LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Apr 07, 2010 | Washing Machines
Lg intellowasher wd-8013f is very noisy
You suspect right.
It is a complete strip down job. I have just finished mine.
taking apart and reassembling is not too dificult.but you need to make up a tool to remove and replace the bearings which are two different sizes. It consists of a lenghth of studding, bolts and washers.
Download the manual from LG.
Good Luck
Mar 17, 2010 | Washing Machines
Blows main fuse under load when going to spin
Sounds like it's scraping against your heater element.Remove back panel then remove heater element(two prongs with nut in centre)you will be able to see signs of damage if so that will have to be replaced. £20 - £30.00p. Your either overloading your machine or your bearings are have gone, to check bearings pull inner drum while holding outer drum if get movement and knocking they will also need replacing.
May 19, 2009 | LG Washing Machines
WD8013F Manual Page
Dec 03, 2008 | Washing Machines
Jan 02, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
