Question about RCA P52920BL 52" Rear Projection Television
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
I have a RCA 52" Proj TV, while watching tv one day the tv shut down and would not come on again, I opened the rear and noticed the fuse next to the power supply was blown, I went to Radio Shack and bought a new fuse and replaced it, when i powered the tv back on the on screen picture was bowed, any help would be great. thanks, mike
  • s1puppy Nov 13, 2008
    I have the exact same problem need tech manual !!!
  • lrcaw Mar 22, 2009
    I did the same thing. The tv shut off and after replacing the fuse, the picture has a bad bow in it and also the three colors are not lined up
    President:
  • 3,130 Answers
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Posted on Jul 30, 2006
Our TV picture is bowed inward and lettering is 3D. How do we fix this problem?
Go to Menu then to setup if you do not see Convergence in the menu then you have a blowed Fuse FL231 it will be on right hand side of FBT flyback Transfomer there is 3 in a roll it will be the Middle one they are small brown rectrangler Looking caps but are Fuses Located on the Deflection board Bottom Left hand Board.
Dec 24, 2009 | RCA Televison & Video
I have a 52' big screen and the picture is shoing
Ur convergence is dead,go to ebay.com buy the convergence repair kit.Find out ur make and models,and manufactures of ur TV buy it.
All big projection DLP have this prob. one time or other every manufactures,Sony,Samsung,RCA,many others.
Aug 26, 2009 | Televison & Video
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA P52920BL (1999)
The fuse fails when the convergence power supply fails,putting a new fuse in the set will let the unit come back on but convergence is not working,check in screens in the menu to see if you have adj. projection t.v.,if the is not in the menu,replace reg ic part number 215530 on the convergence power supply,this board is above the right module mounted on the black plastic.,hope this helps
Feb 28, 2008 | RCA P52920BL 52" Rear Projection...
Rca projection
Conversion problem most likely. Do your conversion controls work both colors in all 4 directions.
Jan 04, 2008 | RCA P52926 52" Rear Projection Television
RCA P52920BL
F32 or F36650 = same transformer = 257805 or Asti 2078
P52920BL = need service number = P52920BLXXX then I will
confirm flyback part #..................................T.
Dec 26, 2007 | RCA F36650 36" TV
RCA P52920BL
i'd like to help.that model# looks familiar.but that chassis num you gave looks more like a serial num all my rca prints go buy chassis # is there anothe num like ctc197 exet or ptk19 doc
Aug 25, 2007 | RCA P52921 52" Rear Projection Television
Televison & Video Logo
1,478 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
