Question about Refrigerators
Need WR55X10942 instruction sheet.
Hi I need WR55X10942 instruction sheet. I think I forgot to clip a jumper wire. I no longer have the sheet. tektron@charter.net. TIA Thanks in advance
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
The sheet can be downloaded from the link below!
http://www.mediafire.com/view/?7nvhv5n98a36ytj
Posted on Jul 25, 2012
How do I program charter remote to work with the Sharp Roku smart tv?
Hi Cathy.
If you go to this site
Charter net Charter Remote Controls 1060BC2 1060BC3 and put in Sharp as the TV type, it both gives you instructions on programming the Charter remote, and gives you the codes for Sharp TVs (10818, 10093, 10688, 10851, 11602, 12360 in this case)
Hope that gets you up and running!
D
Dec 03, 2015 | Sharp Televison & Video
Replace motherboard for gsh25vgrbcc
Your refrigerator uses the common GE WR55X10942 control board. On most models you can just swap out the control boards. Some models require a few additional steps, you will have to check your serial number to see if that applies to your model (see instruction sheet included with the control board).
First unplug the refrigerator.
On the back of the refrigerator, there is a panel. Remove the screws and the panel cover.
Unplug wires from the old control board (note where the wires go), and plug them into the new control board.
Plug refrigerator back in and test out.
For more detailed instructions, and pictures click the link below.
How to replace WR55X10942 control board
Jan 25, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
My Toyota Sienna shows VSC light on the broad. What Should I do?
If you've had your vehicle computer codes read and determined no issue with the VSC circuit, then you just need to cancel the warning light.
I've made up the following instructions, on how to clear VSC & TRAC Warning lights:
Zero Point Calibration of Yaw Rate and Deceleration Sensors Using Paper Clips (or jumper wires).
First, locate the 16-pin ODB II connector under the steering wheel (beneath the dash). The pins are numbered sequentially backwards from right to left (from the wide side of the connector looking at it from underneath).
Take two normal-sized paper clips (or suitable jumper wires). If using paper clips, straighten one edge of one of the paper clips. For the other, bend it open to a 90-degree angle (like an elbow).
Insert one paper clip/wire into pin # 14 (Ts), and the other paper clip/wire into pin # 4 (CG) of the OBD II connector - DO NOT allow the paper clips/wires to make contact at this point.
Refer to diagram below:
1. Ensure the shift lever is in "P" range.
2. Turn the ignition switch to "ON" (not start).
3. Momentarily touch the two paper clips/wires together (short) and separate again (open) - Repeat this process 5 times (within 8 seconds of turning ignition on).
Verify that the VSC indicator light is illuminated, indicating the Recorded Zero point is erased.
4. Turn the ignition switch "OFF".
5. Remove both paper clips/jumper wires from the OBD II connector.
6. Turn the ignition switch "ON" (not start) - wait until VSC warning light turns off (approx. 20 seconds), then wait 2 seconds.
7. Turn the ignition switch "OFF".
9. Re-insert paper clips/jumper wires to terminals #4 & #14 of the OBD II connector (as per above diagram).
10. Turn the ignition switch "ON" (not start) - VSC warning light should remain illuminated for 4 seconds, then start flashing at 0.13 second intervals.
12. After VSC warning light flashes for 2 seconds, turn the ignition switch "OFF".
13. Remove paper clips/jumper wires from the OBD II connector.
Drive your vehicle to confirm VSC & TRAC warning lights have been reset and no longer illuminate.
"If this has helped you resolve your issue, please be kind enough to leave a testimonial"
Jun 10, 2011 | 2001 Toyota Sienna
HI, I GOT PANASONIC DLP TV MODEL # PT-50DL54J, I CHANGE THE LAMP BUT, POWER GREEN LIGHT IS KEEP BLINKING. PL HELP.
On a HP 4266w, Jumper is behind the sheet metal where the cooling fan and radiator is located. You need to remove the three spring screws, fan and sheet metal screws (3), one is deep on the right. Once you remove the clip, holding the radiator, the sheet metal will come off and the dip switch, jumper, is marked. Take the clip off the top and you are ready to go. The radiator clip is tricky to get off as it has a swivel type clip on both ends. I Pushed down one end and lifted the other off.; Take your time. Hope this helps.
Feb 24, 2011 | Panasonic Televison & Video
Digitai temp display dead fridge makes clicking noise
This sounds as if you have lost the low voltage side of the motherboard. You can look over the motherboard by unplugging refrigerator and pulling away from the wall. In photo Here=> PDS22MFSACC GE Cabinet Parts You can see item number 801 in the photo that is the motherboard location. Look it over closely back and front while power is disconnected. You may just see burn marks. The motherboard part number=> WR55X10942 where there is no photo and here where I have a photo=> WR55X10942 in right sidebar half way down that page.
Couple things really are important are the tech sheet and wiring diagram
Here
I know yours is a bottom freezer but clicking on the wiring diagram opens into a new tab GE Service Manual. You can follow with me on that if you would like to do
it yourself. Let me know, Thanks, Sea Breeze
Jan 17, 2011 | GE PDS22MFS Bottom Freezer Refrigerator
The Uniden Refurbished site for downloading instructions manuals does not list the model I just bought from Heartland. My model is the DECT2185-3, and it doesnt show on the list. Do the manuals for other...
You can download and print the instruction manual in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Thanks for using FixYa.
Sep 16, 2010 | Uniden Cordless Phone
Subsidy pw for moto w376g
Use this software. search on the net to get proper usage instructions. you need a USB cable. Its absolutely free and works!
Regards
Feb 11, 2010 | Motorola Mobility W376 Cell Phone
Refrigerators Logo
378 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
