Question about Sunpentown 1.6 cu. ft. Upright Freezer UF160S Stainless Steel
How to replace the fuse for spt freezer uf-160s
Power
I have a Frigidaire UF-21H upright freezer. It frosts over inside very quickly. Suggestions?
Check the seal around the door and make sure that its in good shape and not leaking. Also make sure that the food or anything (ice included)have the door partly open.
Mar 02, 2015 | Frigidaire Freezers
Capacitor part number for vestfrost SE325 freezer
Read the old one. This will give you the specifications to buy a new one. You need uF and volts. Larger is OK.
Feb 12, 2015 | Freezers
Freezer not working
  • Make sure the freezer is plugged in
  • Check for a blown fuse or tripped circuit breaker
  • Test the power outlet for voltage
  • Inspect the electrical cord for damage
  • Eliminate use of an extension cord, if any is being used
  • Check the outage votageIf power is reaching the electrical outlet, trace the freezer wiring and test components as you go. Either there is a short, which must be located and repaired, or the freezer has sustained electrical damage.
Thanks.
Jun 26, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kelvinator Model UF 510 caught fire on top of the compressor. Is this a common failure.
No, It is very unusual for a freezer compressor to catch fire...while they can run very warm alot they do not get that hot unless there is the failure of a couple of things at once..
heatman101
Mar 04, 2010 | Maytag 14.8 cu. ft. / 419 liter Chest...
I have a victory the defrost timer was replaced and noticed start cap. was bad, replaced but turn on and nothing runs? evap.and condenser fans dont run.nothing?
You might check the defrost timer. They come set on defrost. You can usually use a screwdriver to turn the timer manually to get it to immediately start. I did not check the schematics for yours but you may also check that the cap. is of the correct uf rating and that the wires are in their correct position.
Aug 04, 2009 | Victory Freezer Freezer Roll Thru two...
Please help my indesit ta 5 fnf s is dead with no warning. no lights no power nothing. its not fuse power or socket
Had the same problem with my TA5FNFS once you have confirmed as there is power in the wall socket and the fuse in the plug and cable are ok, I found as the PCB control board had burnt out costs about £60 for a replacement board
Apr 30, 2009 | Freezers
Bosch Fridge Freezer Freedom Classixx
Hi there seems that the power supply unit has a fault and will need replacing suggestion to call an engineer.
Thanks J
Jan 01, 2008 | Freezers
Sunpentown 1.6 cu. ft. Upright Freezer UF160S Stainless Steel Logo
78 people viewed this question
Top Sunpentown Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Sunpentown Freezer Expert? Answer questions, earn points and help others
