Hi, I fried my pcb board on my Segate drive and need to get a new one, i tried calling Segate and they are no help i searched and called a few random companies and they were not much better. Does anyone know where i can buy one? I really don't want to lose all my data. Thanks
    Novelist:
  • 70 Answers
Hi sc-w,
Since most companies are not going to sell you just parts of a hard drive. Well the only option I can see for you here is that you have to buy the same model hard drive from a local store or online store wherever it is available and then you need to cannibalize the good hard drive and put the parts on the defective hard drive. As long as you are sure that the only damage to your drive is the PCB, it should work and your data should still be intact (no guarantees though!). Though this might become expensive for you, but like you said your data is what matters most to you right?!
This is the same procedure that most data recovery company do to salvage information from broken hard drives.
Hope this helps!
Peace! :)
Posted on Oct 22, 2008
  • 749 Answers
The Printed Circuit Board controls many functions to operate the hard disk drive, There are 5 main features of a the electronics that can be unique to each drive that is likely to fail, the first being:
POWER INPUT The most problems we see here are mostly human era... forcing the power plug in the wrong way Unfortunately apart from a few notebook PCB's the is no protection fuse to prevent PCB Damage There is also risk of power surges making it through to the electronics as well
FIRMWARE Firmware is unique to the PCB this controls calibration and track information so it is very rare to be able to interchange the same model PCB with one that has another firmware revision... so what this means, if your board shorts out the firmware unique to the drive, you will be in trouble. Of course a good main stream data recovery company will be able to replace this and manually reprogram this chip
SPINDLE IC This controls the speed and rotation of the spindle rotating the platters internal to the hard drive assembly or HDA These intend to get very hot at times and can often short out… The most famous of models to this was the good old quantum LCT, particularly the TDA5247HT Chip; this would go up in smoke and leave a pin hole or a very big mess on or over the IC
MICRO CONTROLLER These rarely fail unless there has been an extreme hit by power such as a lightning strike that may cause voltage through the IDE Cable. If this does fail you would normally find visible damage
TRACKS Internal track are the thin Copper ribbons that run through the board that connect each component these can be easily damaged bay any of the above case scenarios, but one of the most common that I have seen is Corrosion Below is a great Example of how quickly chemicals in the air from industrial workshops or even sulfa in the air from volcanic regions can cause havoc... but for most residential computer hard drives its condensation that damages a PCB
In this example this PCB was only 6 months old
WARNING IF YOU CHANGE A PRINTED CIRCUIT BOARD WITH A NON MATCHING PCB... SUCH AS DIFFERENT FIRMWARE, LAYOUT, OR MICRO CONTROLLER NUMBERS, YOU WILL RUN A HIGH RISK OF FAILURE AND FURTHER DAMAGE!
Yes there's a high chance...
YOU WILL SEE SMOKE!!!!!! If you have an exact match to the PCB you want to attempt swapping, the risk will be minimal but what allot of people don’t realize, is that code can change overtime even with exact matching parts.
What this means is... if you were to purchase two NEW exact hard drives at the same time from the same batch and then swapped there PCB's to each other, you would most likely be successful!
Try that same scenario 6 months after heavy use... and results will could be very different There's a high chance that each PCB has made themselves unique to each drive!
How can this be? Its called SMART Technology where the hard drive is designed to reconfigure itself during operation to maximizing performance and protecting data. If a sector is read slow but functional the drive will remap this sector as bad and move this sector creating changes to track and sector information in firmware Now this new reconfigured information is unique to the drive, and can cause this PCB to be incompatible with any other drive of matching numbers.
As a data recovery engineer it is always best to repair the Original electronics of a failed hard disk drive That way you get maximum results with very little risk, Most high end data recovery companies have the expertise to replace many, if not all components on the PCB.. but not only physically but replacement, but this may also involve new components and reprogramming.
The circuitboard on my hard drive has fryed and need a new one
Because of this customized firmware, however, it's not possible to switch out a PCB board in many cases; of course, this varies depending on the manufacturer of a drive. For instance, some older drives have the same basic information on two PCB boards of the same model, provided that both drives were made at about the same time, before more unique adaptives were programmed into the next line of drives. If one of the PCBs fails, there is some chance of making a recovery by simply swapping the boards of the two drives. However, hard drives have contained "customized" firmware on at least an occasional basis since they've become a consumer product, so the chances of a straight "board swap" working are very low. In addition, because of the unique adaptives, it is highly possible to damage a drive further by the placement of a foreign PCB. Data recovery companies must rebuild the firmware information in many situations when the PCB of a drive fails. In addition, occasionally PCB failures cause damage to other hard drive components, such as the heads of the drive (and subsequently the platters, in certain situations). Professional data recovery companies have special processes to treat these problems as well. If you think that your hard drive has a problem with its PCB board, it's important that you don't try to operate the drive any further or try switching out the PCB board with another drive's. Get your hard drive to a reputable data recovery company immediately for an evaluation. A good data recovery company will be able to quickly diagnose the drive's issues and let you know what your options are from that point. http://www.onepcbsolution.com/ http://www.youtube.com/watch?v=du0Qd_3wFWM
Feb 28, 2013 | Iomega Computers & Internet
Wd2500 500gb light flashes when plugged in. does not engage no communication with computer
I found some solutions already listed here on FixYa that really worked. Here's the link:
http://www.fixya.com/support/t2950434-wd_elements_usb_drive_not_recognized
I also left a comment on exactly what I did to fix my problem using the instructions that were listed thanks to etcrCustomPC. I had tried everything for days including "Safely Removing" the USB Mass Storage Device, and restarting Windows; downloading updated drivers, scanning for changes, and updating drivers on "Device Manager". I went online but did not find anything helpful other than what I had already attempted. I saw "FixYa", and decided to try it out. I kept clicking on all the different sites on "FixYa" listed. Yes, I will go literally through the web until I find or figure out a solution. You could call me a "research investigator". I may not know how to solve the problem, but I will search diligently through lots of "Trial and Error" information until I find one that works. This one definitely worked for me. I hoped this helped. If it does not, I will post all the related links later so it makes searching for a solution a lot easier. Thanks FixYa. I have fallen in love with this website, and adding it to my "Favorites".
Feb 20, 2011 | Western Digital Passport WDXML800UE...
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very low....
Thanks for the details. I have used K8V-MX Asus motherboard and found it very reliable with quite reasonable performance. It definately supports 500 GB Sata drive and there must not be any issues after increasing just the storage. However, Operating System upgrade may result in sluggish performance. Drivers dont seem to be an issue to me either.
I suggest to review a few points detailed as under: -
- K8V-MX Asus Supports RAID, so, check for any RAID Drivers/ settings. (You dont have to use RAID for two Hard Drives of different make, capacity and speed). Try using one disk at a time having same Operating System (e.g. Windows XP) and compare the performance.
- Infact SATA Drives have better data transfer rate than IDE, which results in enhanced performance.
- Some Programs (that you may not be using with 80GB drive) Like antivirus may result in decreased performance.
- Please Review you Operating System environment and software installed. Make sure that the new drive & Operating System are free of any virus, which results in CPU Utilization upto 100%.
- Also, motherboard supports Max 2GB RAM, so you may consider adding more RAM.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Jan 27, 2011 | ASUS K8V-MX Motherboard
How Find out Segate 160 gb HDD Warrenty
you can find it by serial no of HDD. You can call in segate service center & provide the serial no to them.
Dec 18, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
WD3200JS Electrical failure? No spinning, overheating of board
Hi Indro,
HEat issues like that can be caused either by a failure on the PCB or internally. Remove the PCB board and inspect it, if it's an issue I have seen occasionally you will have a hard time removing the PCB as it will have blown out a chip near the contact point for the drive and will be somewhat fused to the padding between the PCB and the drive chassis.
If this is the case a new board runs about 50% chance of fixing the issue, try finding one on eBay and replacing it. If that fails or if there's no noticable failure on the PCB, chances are the failure is internal and you will need the help of a professional facility with a clean room to get your files back. If this is the case and you don't mind spending a few bucks for the file, respond with your location(Country, State and City) and I will refer you to a nearby facility that has the appropriate equipment to assist you.
Hope this helps FixYa,
Chris
Sep 29, 2009 | Western Digital (WD3200JS) 320 GB Hard...
My 360 wont read COD WAW
The CD rom has weak laser, new laser 20.00- 30.00
One of the two motors is weak and
the drive need to be replace , and the
old drive's P.C.B has to be put in
the new drive. 40.00-50.00
That's it
Jul 06, 2009 | Microsoft Xbox 360 Console
Freeagent doesnt start
I think you have already diagnosed the problem sufficiently, the tolerance of the free Agent is less than +/- 1.5v so you have undoubtably fried the controller board in the freeagent case. The real question is wether the PCB board in the case was kind enough to blow out quickly and save the drive itself.
First step is to take it to the local computer shop and have the hdd swapped into a fresh case. If it works in the new case you're done, if not, you'll likely need the help of a pro to recover the data off the drive.
Give it a shot and report back, if it's not successful, let me know what country, state and city you're located in and I'll make a recommendation for a professional facility that can help you with the recovery.
Chris
Jun 07, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Ilo-32HD Main PCB Assy
Hey, you can try http://www.discount-merchant.com/ They have may parts. just remember that the board you are looking for may be made buy another manufacturer and used in other displays. Part numbers might be differen but the same power supply. You can call them and ask them, they have free tech support.
Mar 23, 2009 | iLO 3200 32 in. LCD Television
Can't find parts
http://www.mouser.com/index.cfm?handler=home http://www.mcmelectronics.com
http://www.bdent.com
http://www.electronix.com
Jan 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Computers & Internet Logo
680 people viewed this question
David Payne
David Payne
