Question about Campbell Hausfeld 04 Gallon Twin Stack Compressor HL5502
Pressure switch diagram - Campbell Hausfeld 04 Gallon Twin Stack Compressor HL5502
  • fred Feb 07, 2012
    wiring diagram for the pressure switch
Unit has developed a continuous leak
need to replace pressure switch as the leak is a worn needle valve assembly. it usually unloads from there when the machine stops
Sep 06, 2012 | Clarke Power Products Inc AC2001 2HP 4...
Why my air compressor want shut off after building up pressure
If it is building up to the full rated pressure and there are no air leaks in the hoses then it is most likely the pressure switch. It is item 111 in this parts diagram.
Porter Cable C2002 diagram
Aug 25, 2012 | Porter Cable C2002 150 Psi 6 Gal...
1990 dodge dakota a/c diagram/ schematic
Hi Gunny, have the gas pressure checked first. If the pressure is low the electro clutch for the compressor will not engage. The system is protected with inhibitor pressure switches mounted into the high pressure line. Regards John
Jun 24, 2012 | Dodge Cars & Trucks
Where located fuel sensor Suzuki Ario 2003
Component location diagrams for most 2003 Suzuki Aerio cars and light trucks sold in the U.S. from 1990+.
clsk2003aeri003.gifIgnition System Components Location Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
Components on diagram:
  • TP Sensor
  • Ignition Coil
  • ECM
  • MAF Sensor
  • CMP Sensor
  • clsk2003aeri007.gifElectronic Shift Control System Components Location Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Data Link Connector
  • Transmission Range Sensor
  • Throttle Position Sensor
  • Pressure Control Solenoid Valve
  • Battery
  • clsk2003aeri010.gifInstrument Panel For Connector Layout Diagram Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Clutch Switch
  • Thermistor
  • Brake Light Switch
  • Blower Motor Relay
  • Heater Fan Motor
  • clsk2003aeri011.gifInstrument Panel Harness Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Wiper Switch
  • Washer Switch
  • Turn Signal Relay
  • Radio
  • clsk2003aeri015.gifHeadlight System Location Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Headlight Relay
  • Headlight
  • Clearance Light
  • Headlight Diode
  • Clearance Light Relay
  • clsk2003aeri022.gifFuel System Components Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Fuel Pump Relay
  • Fuel Tank Pressure Sensor
  • EVAP Canister
  • Fuel Tank Pressure Control Valve
  • Fuel Filler Cap
  • clsk2003aeri027.gifFloor For Single Unit Parts Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Wheel Speed Sensor
  • ABS Control Module
  • G Sensor
  • Air Bag Control Module
  • EVAP Canister Vent Valve
  • clsk2003aeri030.gifInstrument Panel For Ground Point Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Instrument Panel Ground Points
  • clsk2003aeri036.gifEngine Compartment For Single Unit Parts Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Horn Relay
  • Radiator Fan Control Relay
  • Cruise Control Module
  • Condenser Fan Relay
  • clsk2003aeri037.gifEngine Compartment Components Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • MAP Sensor
  • Knock Sensor
  • Noise Suppressor
  • Heated Oxygen Sensor
  • Sep 18, 2011 | 2003 Suzuki Aerio
    I have a kenmore elite electric washer Model #229 42 101 CM 4905520 the spin will not spin on ocassions and it only hums and the tub does not turn. when it does spin does not spin all the water out the...
    Hi.
    From description it looks like a drain problem. Check drain filter, drain hose and pressure switch.
    Check motor, motor control unit, drain system and pressure switch. Start checking from drain system and pressure switch. The pressure switch determines water level. The timer checks the output from pressure switch to decide that drain is complete and advance cycle to spin.
    Check also the position of the drain hose. Ensure that the height is as specified by the manual or you get siphoning and drain does not end.
    Here a page about drain/spin problem.
    Start checking drain and pressure switch, then test the other parts.
    If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
    Regards.
    Ginko
    Sep 09, 2011 | Kenmore Dryers
    GE washing machine model#WJRE5550H1WW machine will drain but wont spin
    Hi.
    Check motor, motor control unit, drain system (I know it drains) and pressure switch. Start checking from drain system and pressure switch. The pressure switch determines water level. The timer checks the output from pressure switch to decide that drain is complete and advance cycle to spin.
    Regards.
    Ginko
    Sep 09, 2011 | GE Washing Machines
    Porter cable 3hp 130psi air compressor when the pressure drops th e compressor will not kick on to build the pressure back up we have replaced the switch 3 times did not help either time no model # visible
    I am taking a guess that you have a model C2002. Did you replace the on/off switch or the pressure switch? It sounds like a bad pressure switch which is item #111, part #N003307SV on the following parts diagram. Here is the link to the diagram.
    http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=C2002&selectedType=23221#pp-parts
    Jul 27, 2011 | Porter Cable Air Tools & Compressors
    I have a paragon 8145-20 defrost timer. do you wire the compressor to the timer? I cant seem to find a wiring diagram on how to wire this correctly
    Link below has wiring diagrams and wiring manuals for 240V 8145-20
    http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
    I am not expert installing defrost timers.
    According to information from Paragon, 8145 is for hot gas defrosting. 8140 series are time initiated, and pressure-or-temperature terminated.
    Wiring diagram does not show compressor wired to timer.
    The cycle works like this:
    Timer is running but defrost is not switched ON.
    Fan is ON.
    Timer switches ON and activates defrost cycle.
    Fan turns OFF. Hot gas valve turns ON for defrosting.
    Cycle limit switch is temperature or pressure sensitive.
    Cycle limit switch reaches trip point, timer switches OFF.
    Hot gas valve turns OFF. Fan turns ON.
    So fan is off during defrost cycle.
    Hot gas valve turns ON when timer switches ON.
    Timer is switched OFF by pressure-or-temperature limit switch.
    Dec 09, 2010 | Paragon 8145-20 Defrost Timer
    I need a diagram to help determine what the two switches or units are that sit atop of the oil filter unit. 1989 Volkswagen GTI 16 valve
    If you are referring to the single terminal switches, one brown and the other white, those are oil pressure switches. The brown one is the low pressure switch [replacement switch is blue] and the white one is the high pressure switch.
    Jul 01, 2010 | 1989 Volkswagen GTI
    Campbell Hausfeld 04 Gallon  Twin Stack Compressor HL5502 Logo
    109 people viewed this question
    Top Campbell Hausfeld Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
