Question about Panasonic Toughbook CF-27 Notebook
Ugrading I have a CF-27 with no hard drive or OS. After the setup screen a red message box appears saying "partition table not found or corrupt". How do i fix the problem if possible?
  • fundaplatnum Oct 22, 2008
    Ok. I have an XP disc and Linux Ubuntu and Freespire and Puppy. How do i get an OS on the CF-27? I also have a external cd-rom.
    Brigadier General:
  • 6,966 Answers
The message would be expected since there is no hard drive. Partition Table refers to information about primary partitions and an extended partition a 64-byte data structure located in the same sector as the Master Boot Record inside the hard drive.
This might be of additional help.
Hope that this be of initial idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 22, 2008
  • Louie  Role
    Louie Role Oct 22, 2008
    The initially posted link details how to get an OS installed on an M34 which should also work for a CF-27. Additional insights maybe sourced from here.
Can a power interrupt during hard drive installation cause a "Boot manager missing" message?
You do not say what OS you were installing, and Windows limits what you can do with the hard drive during installation.
As you have found out, any power interruption during an installation will likely corrupt the process and make the system unbootable.
If you can restart the install at the very beginning that may work for you. However, I believe the simplest fix will be to use a live system bootable disk and erase the corrupted partition table on the drive then restart the install as if it were a brand new hard drive.
For that type of recovery I use gparted, which can be downloaded for free from http://gparted.org/livecd.php
Gparted live can be used on CD, hard disk, USB, or even pxe boot. I would delete all the existing partitions that were created during the failed install, then restart the install from the very beginning as if it were a new disk.
Mar 10, 2017 | Seagate BARRACUDA Computers & Internet
Acer Netbook OS
if you are getting this message about corrupted partitions, you need to check and possibly replace the hard drive. There is a program to check the hard drive called Hard Disk Sentinel. It is designed for SSD hard drives like the Acer Aspire One has. Yours has a 160GB hard drive in it now.
Mar 26, 2010 | Acer Aspire One Netbook 8.9" Notebook
I power it on and it display ''Corrupted hard drive No operating system found "
kindly check the cmos setup by using del key and follow up on the drive dection make sure ur hard drive is displaying or not on cemos setup
Nov 01, 2009 | Panasonic Toughbook CF-27 Notebook
Unable to install OS on Hard drive. Error PXE-E61: Media test failure, check cable. PXE-MOF: Exiting PXE ROM. Invalid partition table
When your computer failed to boot from the disk-drive, it tried to connect to a network-accessible "boot-server" via the Ethernet adapter.
However, if there's no cable connected to the computer's Ethernet port, you will get the "check the cable" error-message.
So, your real problem is "invalid partition table", which means that the very first record on the disk-drive is either missing or corrupt.
That first record contains the "partition table", which lists the size of the hard-drive, and the size of each partition (usually only one) on the hard-drive.
So, you'll need to buy an adapter that has a USB-plug on one end, and a connector for your "SATA" or "IDE" hard-drive at the other end.
Remove the hard-drive from your computer, attach it to the connector, and plug-in the USB connector to a USB port on another computer, and then use software to delete and then reconstruct the partition table.
Or, the hard-drive is failing, and must be replaced (maybe under warranty???).
Oct 22, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
It keeps saying that ntoskrn1.exe is missing
It is pretty much crashed....hard. Might want to reload the OS. Yes you can recover from that, but it is not worth the time and frustration to do it...Provided you can afford to lose whatever you had on the primary partition (C:\) drive. Let me know if you need other asst. It is a little complicated to explain. How many machines is this affecting? All of your E-Machines?
Aug 13, 2009 | Computers & Internet
Os not found message appearing on the screen
Can you get in to your bios setup screen? If yes, then check that your hard drive is on the boot order list.
Your boot order list should be:
CD/DVD
hard drive
other (different bios have different options here)
If your boot order doesn't show your hard drive or the proper drive if you have more than one, change it to the proper drive.
Apr 23, 2009 | Computers & Internet
Dell inspiron 6400 rebooting
it is an issue with your software which is not able to find the os in hard drive please perform a operating system reinstall
  1. Ensure all of the Windows XP installation discs and information are present.
  2. Install the Windows XP disc.
  3. Press and hold <Ctrl>+<Alt>+<Del> at the same time to restart the computer.
  4. When the computer restarts and the Dell splash screen appears, press <F12>.
  5. In the Boot menu, use the <Up> and <Down> arrows to select either CD or DVD, and then press <Enter> to continue.
  6. If prompted, press any key to continue. If you do not press a key, the computer starts from the hard drive. In that case, wait until Windows has completed started up, and then begin again.
  7. At the Windows XP setup window, select To set up Windows XP now, press Enter, and then press <Enter>.
  8. Press <F8> to accept the terms and conditions specified in the license agreement.
    new_note.jpg Note: By default, unpartitioned space is highlighted. If any other partitions appear that were not previously created by you, they may include a PC Restore partition or a Media Direct partition.
  9. In the Windows Setup Partition screen, press <Enter> to partition the hard drive. On this screen, review the listed partitions. Usually, the original operating system partition is labeled (OS) and is also the largest partition.
  10. Use the <Up> and <Down> arrows on your keyboard to highlight the OS partition and press <D> to delete the partition.
  11. When the Confirmation screen appears, review the warnings and press <Enter>to continue. You will now be returned to the previous screen.
  12. Use the <Up> and <Down> arrows to highlight the unpartitioned space and press <Enter> to set up Windows XP. The Windows XP Setup appears with the following information highlighted: Format the partition using the NTFS system.
  13. Press <Enter> to continue. On the next screen, a progress bar shows the format process. When the format is complete, the setup files are copied to the hard drive.
    The following message appears: Please wait while setup copies files to the Windows installation folders. This might take several minutes.
    Then follows Setup is copying files…. The status bar displays the percentage complete. When complete, the computer reboots and the set up wizard appears.
  14. When the Regional and Language Options window appears, change as needed, then click Next.
  15. When the Personalize Your Software window appears, enter a name and organization if wanted, then click Next.
  16. When the Product Key window appears, enter the product key, then click Next.
  17. When the Computer Name and Administrator Password window appears, enter a password if wanted, then click Next.
    When you enter the password, be sure the caps lock is off; passwords are case sensitive.
  18. When the Date and Time Setting window appears, change as needed, then click Next.Windows is installed, a progress bar indicates approximately how much of the task is complete.
  19. The computer reboots.
    The Windows XP operating system is fully installed.
Aug 14, 2008 | Dell Inspiron 6400 Notebook
Laptop crashed after updating Incredimail and now it says media failure and operating system not found.
  4. When the computer restarts and the splash screen appears, press
    Note: you will have to reformat the entire hard drive/disc
Aug 14, 2008 | HP Computers & Internet
Laptop
when u say setup screen I assume you mean the bios setup screen;which probably means ur hard drive is corrupted.
Make sure u have a os cd in drive and turn pc on to boot from disk,if you get a message in the black screen saying no operation system or no drive,turn off pc and remove hard drive ,check for dust and bent pins and replace making sure its seated(fitted)properly.the action of removing hd and refitting usually does the trick due to small particles of dust which act like conductors and can cause shorts.
if u dont see that message but have the option to install ;go ahead and install in next screen(blue setup)sys checks for exististing os ;if it finds one it asks to confirm install or repair,you can choose either one,both options take about the same time.though I always prefer to install clean (new) copy and delete partition,create new partition and format before install.
Apr 01, 2008 | HP Pavilion dv6000z Notebook
Panasonic Toughbook CF-27 Notebook Logo
289 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
