Question about Royal 435dx Electronic Cash Register
Error code Re EL
Trying to program the unit. It accepts the date & time, and appears to accept the clerck security codes, but after doing so and going to the registers modes, an audible error comes up and a display of "Re EL" How can I fix this?
I have the same proble with my royal 435dx i thought the error mesage was e1 but ut could be el....did you get a solution? i looked up the manuel online no help and i called their tech support which is outsource and barely understandable....no help
Posted on Apr 22, 2012
Why is my activation code not being accepted by mcafee. due for renewal
the code you are trying to put in should be only for the new program
old codes will not work for new programs
next , with most security programs you have to uninstall the existing program then install the new one and then put in the code
call mcfee help desk for assistance
May 08, 2016 | Mcafee 2009 Internet Security - 3 User...
Does not overwrite old codes, just keeps accepting new ones. How can I clear all existing codes?
First, I fix this problem after an hour of try.
I conclude that this dorr lock is better that is appear. Is not a 2 codes door lock, it's a 3 codes one.. and the problem you have is the third code not reset. You can put the same code in each third emplacement. you have just to press the program button 3 time for the third code...
I determinate that I put the third code by error the was i program it the firs time.
I guide you...
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Jan 27, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
We have a Panasonix KX-T7731 phone system with 7 different extensions. How do I program each individual phone so that the date and time appear on the phone display?
With the handset on the cradle:
Press Program button
Enter *#
Enter the system password - system default is 1234
Enter 000
Press the Auto Dial/Store button
Enter date using the Scroll button (the round one used for spkr volume) to move to right and left to next field
Press Auto Dial/Store button to accept setting
Press Redial button to move to time
Enter time using Scroll button (the round one used for spkr volume) to move to right and left to next field
Press Auto Ans/Mute to exit Date & Time
Press Program Button to complete
Dec 30, 2010 | Panasonic KX-T7731 Corded Phone
We are trying to reset a security code for our existing weiser lock and it isn't taking the new code entered.
Good lock
Good unlock
Nov 08, 2010 | Weiser Lock Powerbolt 1000 Lock
The original code will not clear from my Weiser lock electronic lock. I have entered multiple codes and the original still stays. How do I get the original to clear.
I guide you...
May 04, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
GE/ADT DIY system will not accept master code./beeps twice/2 hour
Press the system status button on the top right and the system should announce the error message that is keeping it from accepting the code.
Feb 17, 2010 | GE Security Simon 3 Wireless Home Security...
Have a Rona electronic lock (Weiser) and the key works... will lock electronicly... but do not know the code... I have removed it from the door and replaced, but is there a way to reset the code?
I guide you...
Jan 23, 2010 | Weiser Lock Powerbolt 1000 Lock
Can not program both keypad & remote to operate at the same time
One of your units has reverted from "rolling code" to "billion code" and as you have found they will each work but will not work with each other. The problem is finding out which unit reverted. The most common one is the hand remote but that could be wrong.
Aug 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programming code not working
Go to this web page to find the text answer below: http://www.fixya.com/support/t233614-reprogram_hv_board
HERE TIS RIGHT OFF THE INSTRUCTION SHEET.  THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 :WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
Aug 03, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Royal 435dx Electronic Cash Register Logo
354 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
