Question about Asko 24 in. 1895 Built-in Dishwasher
Viking dishwasher dw20.3 keeps running - seems to be a draining issue?
Dishwasher keeps making suction sound though cleaning cycle is done
You made have a leak causing the drain pump to keep running, if you never worked on this unit before I would suggest you call a professional. If you have worked on this before then look for water in drain pan to unit, the reason is water has entered drain pan and caused the float to turn on pump, could be from the drain hose, leak in a hose, or the diverter. all this part are located unit unit in access area (small panel under large door).
Good Luck, I hope this helps...
Jul 21, 2011 | Viking 24 in. Professional Series VUD040...
The dishwasher doesn't seem to drain water.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
May 10, 2011 | Viking DFUD04 Built-in Dishwasher
The red arrow keeps blinking and washer does not run, cycle starts then stops leaving water on bottom....
You either have a blocked drain line drain pump, or water is in the base pan. behind the toe kick is a base pan that will catch water if the flood switch is activated this condition will occur. I know this dishwasher very well can help you fix it yourself.
http://www.appliancerepairlesson.com/
Mar 01, 2011 | Viking VDB450 Dishwasher
Motor keeps running and we can't operate the dishwasher
Look for water accumulating under the dishwasher. It has a tray that will catch any leaking water before it gets to your floor. If this is the case the most likely cause for the leak is the drain hose (located behind the main pump housing).
Jan 12, 2011 | Viking 24 in. Professional Series DFUD140...
Viking dishwasher that does not stop draining cycle - keeps on running
I have the same thing, unit pump keeps running, when I pulled it from under the cabinet, if you tilt it back a little it stops, as soon as you lower it back down the pump starts to run again. Getting code as too much water in the tank even though it is empty. PLEASE HELP!!!!!
May 17, 2009 | Viking DFUD042 Built-in Dishwasher
Viking dishwasher quit working
Possible bad door switch, thermostat or timer issue, call for service, make sure the tech. knows how to fix Asko dishwashers as that is what is in on the inside. Be sure that you are getting power to the unit.
Jul 16, 2008 | Viking 24 in. Professional Series VUD040...
Viking VUD040 dishwasher seems like no power
My viking dishwasher only runs for about a minute and then shuts off. Circuit breakers are not the problem
Nov 06, 2007 | Viking 24 in. Professional Series VUD040...
Eaton viking dishwasher
it may not be the pump.if it leaks when you run a wash cycle then the pump seal may be bad but if it only leaks when you drain it,it seems that its a drain hose/piping connection.
Nov 03, 2007 | Dishwashers
Dishwashers Logo
212 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
