Question about SNK Skyworth SLC1963A 19 in. LCD TV/DVD Combo
Wont change input
Whenever i turn my tv on it automatically turns the volume up, i try to turn it down with my remote but it wont work, the batteries are new, how can i fix the problem, oh yeah i also tried the buttons on the tv still wont work
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 139 Answers
Sounds like the volume up button is stuck on the tv , try fiddeling with it on and off , because it is locked down the other controls will not function
Posted on Feb 07, 2012
My MXQ-4K remote automatically connceted to my tv but it’s messed up. The down arrow on the remote turns the volume up, the left arrow changes the input, the up arrow opens the menu, menu turns the volume...
First I'm not an MXQ remote tech, but I am familiar with electronics and IR programing.
* If you still have the old remote then use the "learning" method
https://www.youtube.com/watch?v=NTQZWkMktSo
* Other wise check your paper work on the remote or updated codes on the MFR help line. Many codes are just what the MFR was given by the TV MFR and probably changed during the making of this model.
* You will probably have to try all the codes for the brand that you have. Note that other options (like VCR, DVD) buttons can be used to replace the TV button. Though it would probably work the best when programing with the TV button.
* Last resort; go through all (yeah like 999 possible combinations) the codes to find the right one. WRITE it down once you find it as you will need it again when you change batteries on the remote. Didn't learn after 2 battery changes or just dropping it on the floor and battery fall out.
* There may be a possible option to auto search to "turn off" the TV set to find the correct setting. But though this may work for you, the problem is, you don't know the combination and have to do the auto search every time you change the battery. It does take a while (20 mins) but it's better than punching in combos 1000 times.
Aloha, ukeboy57
PS you may find a replacement remote for your set brand/model on Amazon.com and forgo all the problems.
May 11, 2018 | Televison & Video
Volume, device inpute issues
Try new battery's in the remote, and check all volume buttons, one may be stuck down.
Mar 23, 2014 | Mitsubishi WS-65511 65" Rear Projection...
Remote will not change channels
If you are using the original remote, it has failed.
Sep 26, 2017 | Pioneer PDP-5080HD 50 in. Plasma HDTV
Input menu will not disappear
  • This happens because a part in your remote is holding the input button down find what is and find a way for it to stop doing that.
Dec 13, 2017 | ViewSonic N2635w 26 in. LCD Television
Can not turn off and volume turns down by it self changed batteries in remote
Need more info to assist you with the issue. Does the tv work except the volume turns down by itself even with the batteries removed from the remote? If so its either the Tact switch for the vol down has an issue or the main board has an issue. If the remote wont work the tv properly either or not at all too then i would say the main board is causing both conditions. If you require further assistance please let me know.
Jan 01, 2013 | Samsung 50 in. Plasma TV
Remote sensor on tv not responding
the problem is the s/w on the tv if you have some solder experience this is easy to fix just repalce the s/w
Feb 12, 2012 | Sylvania LC420SS8 LCD TV
My remote wont operate my sony TV volume
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 25, 2009 | Sony RMT-D155A Remote Control
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
I have a philips Matchline tv (29pt6361/79r) the tv works fine except it automatically turns the volume down without any buttons on the remote or tv being pushed
well depends on how far it turns the volume down as to what the cause is and if the volume bar on screen display comes on when the vol. goes down. if it just goes down a little you probably have the "smart sound" setting turned on in the audio menu turn it off and see if prob. goes away. if the vol. bar comes on the screen whenever the vol. goes down the you most likely have a bad button on your front panel and it doesn't have to be the vol. down button. it you think it is the button it would need solder work to be changed most likely shop job.
Mar 08, 2008 | Televison & Video
Front panel controls are unresponsive
Check volume up switch in front panel locked continuously. If it is not take away the remote control from the TV or remove the battery in the remote. Because maybe the remote continuously sending volume up commands. Rarely this type problem occurs through remote control also. Even problem is not sorted there is problem in EEPROM ic (memory ic). This can be sorted out by the technical persons only. I hope this useful to you.
Aug 31, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
SNK Skyworth SLC1963A 19 in. LCD TV/DVD Combo Logo
215 people viewed this question
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
