Question about HP Computers & Internet
Tc1100 tablet PC. The jog dial, which is used to change the backlight level works only to lower the level of the light. The jog dial will not go up. The jog dial is also used to move web pages up and down. Currently, the dial only moves the pages down. The jog dial is the only way to increase screen brightness on that computer and the jog dial will not permit an increase. I can no longer use the computer. Thank you
  • dcchavers Oct 25, 2008
    Thanks for your response. I have tried to change the assigments for the buttons. I've restored the system to a much earlier date without success. I changed the jog dial down to up in the hope that it would then brighten the light. Finally, I re-installed the q menu software. I have not reintalled the button driver software. I'll give that a try and let you know. Thanks.
  • 749 Answers
Did you check the settings with the applet for "Tablet and buttons" (from the control panel)?
Did you install anything recently or make any other system changes?
Perhaps a rollback (system recovery) might fix the problem. This works the majority of the time.
dont give up...it may take three or four restore attemps before you find one that works..pick a recent date from when it was working correctly and restore to then, if it doesnt work go back a few days earlier.
The drivers for the buttons would be:
Tablet PC Button Driver version 1.00 B (8 Nov 03)
SP24241
http://h18007.www1.hp.com/support/files/Compaqtabletpc/us/download/19713.html
All of the drivers and software add-ons are here:
http://h18007.www1.hp.com/support/files/Compaqtabletpc/us/locate/97_5840.html
Posted on Oct 22, 2008
Can i get help with my tc1100
The official site for download of all TC1100 tablet pc is available at this link.
HP Compaq tc1100 Tablet PC
These drivers are compatible only for Window XP. If you are trying Windows 7 then you will have to take a chance. It may or may not work.
See this article.
HP TC1100 Windows 7 Installation Notes
Sep 23, 2014 | HEWLETT-PACKARD HP Compaq TC1100 Tablet PC...
TC 1100 UNSUPPORTTED WIRELESS DEVICE
Have you got the drivers installed for the OS you are using?
Jun 23, 2014 | HEWLETT-PACKARD Hewlett Packard 348349-001...
I am in the "s" mode for shutter speed priority and i cant change the shutter speed i use the scroll to get the arrow above the shutter speed on the view finder and from then i cant figure out how to...
Are you pressing the jog dial to save the setting? Here's what your book says:
  1. Turn the Mode dial to P, A, S, M, or C.
    The mode options are displayed.
  2. Use the jog dial:
    • Press the jog dial to open a setting.
    • Press the jog dial to save the setting.
    NOTE: Available options are white. Unavailable options are grey. Red options are out of range and may cause unacceptable image/print quality. Adjust the value higher or lower until it turns yellow.
Jun 11, 2010 | Kodak EasyShare DX7630 Digital Camera
Power switch of HP Compaq tct 1100 Tablet PC
http://www.jksalesinc.com/catalog/images/TC1100.jpg
heres wat u need, go to the above link..
Nov 03, 2009 | Compaq Tablet TC1100: Tablet TC1100 P-M...
Tc1100 Blank Screen
You have identified your problem/fault by plugging in an external monitor and the image is OK. This proves the video card is OK and the fault could be the inverter or most likely the CCFL lamp.
The flickering screen indicated the CCFL lamp is faulty, it is a mini fluro tube which provides the back-light to the LCD. The inverter supplies high voltage to the CCFL lamp. It could be faulty and it is easier to replace.
For service, parts and DIY info check out LCD Parts - use this link to their WEB site : -
www.lcdparts.net
Oct 10, 2009 | Compaq tc1100 Tablet PC
Blank screen on laptop
Maybe the OS is corrupted, try to reinstall the OS
Jun 24, 2009 | Compaq tc1100 Tablet PC
TC1100 does not turn on!
Check the wall outlet to be sure it is providing power. Use a lamp or a fan or other electrical device to be sure that outlet provides power. Check the power surge supression strip, and ensure it is switched on if it has a switch, and it it has a fuse reset button, push that in or push it to the reset position. Recheck the connection of the wall connector cable to the small DC converter box. Finally recheck the connection of the end of the power cable where it connects to the PC. If the Tablet still does not show a green light indicator on the front, try removing the battery. The TC1100 works with the battery completely removed. If you have power but no display, then the problem could be with the display. I suggest that since there are a lot of problems with the older tablet PCs, that if you still have problems with it and do not really need that type, check out the new low priced Atom processor netbooks and the new moderately priced Intel Core2 Duo notebook PCs and AMD dual core and tri-core notebook PCs, with plenty of RAM like 2GB or more, and preferably dedicated video RAM, like an NVideo or ATI video that provides 64MB or 128MB or 256 MB or 512MB or more of dedicated video memory. Back to your TC, ensure it has good power, then look to possible bigger issues that power or power adapter - the CPU or board could be bad, or it may boot up but not display because of a problem with video on board or in the connector to the screen or in the screen circuitry.
Mar 08, 2009 | HP 303178-001 Compaq TC1000 TC1100 Tablet...
Multimedia audio controllr driver
You can try a manual Microsoft Update and choose "Custom" rather than Express and once the scan is done check and see if there's an additional hardware update that points to your Audio/Multimedia hardware.
Feb 06, 2009 | Compaq tc1100 Tablet PC
HP TC1100
Try plugging in the tablet with the battery not installed. If there is no battery the tablet should turn on with just the AC adapter. If that works there might be a dead short in the battery and you would have to replace it
Jan 27, 2009 | HP DG937A - HP Tablet PC TC1100 Tethered...
Change ID,servicetag and asset tag for HP TABLET TC1100
you can change both of those in the bios which you get to by tapping either del key or f1 or f2 key one not all it will have them just edit hit f10 to save
Jan 25, 2009 | HP Compaq d530S PC Desktop
Computers & Internet Logo
124 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
